LSP_Kevin Posted January 5, 2018 Posted January 5, 2018 I alluded to having started this kit in my long-running 1/32 Fw 190S conversion thread in the WiP forum, but I've decided it deserves a WiP thread of its own, so here goes. Here's the kit in question: The flimsy box was getting pretty crushed, so along with having some synergies with my 1/32 build, it also seemed a good time to finally start this one lest the parts inside become damaged or lost. While it's definitely a short-run kit (and my very first build of a kit of this type, believe it or not), I think it's actually pretty decent, though it does have its issues. Most of these are just the usual limitations of this type of kit - no locating pins, rough mating surfaces, lots of flash, agricultural fit in places, variable quality surface detail, etc. On the plus side, it comes with some nice resin detail parts, as well as a photo-etched fret for the seat belts and instrument panels. Two vacform canopies are supplied (representing the two main types of canopy style found on these machines), but seem to have suffered from the dreaded yellowing: If you look closely, though, the actual canopy part seems relatively clear, but that could just be an optical illusion. I'll cut one out anyway and see what it looks like in isolation. If it doesn't scrub up, happily MPM also provides a single injection-moulded alternative: It's not the nicest-looking canopy you'll ever see, but should work with a bit of polishing and rehabilitation. Taping the fuselage together suggested that fit of the main parts would be OK, though they took quite a bit of preparation in terms of cleaning up the mating surfaces and removing flash and other ugly bits: The casting block in the resin wheel bay was a bit of a pain to remove, and I damaged one side a little bit. In any case, it doesn't fit too badly: The black stuff you can see in the photo is JB Weld Kwik, which I initially used to attach the resin part to the plastic wing. But it didn't cure properly, and let go when I accidentally dropped the wing. I had to resort the using CA instead; what you see is the JB Weld residue that I couldn't be bothered removing. My guess is that I didn't get close enough to the required 50:50 ratio of the two JB Weld components, so I'll have to be more careful next time. I decided to add the upper wings immediately to assist with keeping the wheel bays in place. Since the cockpit is literally a resin tub that can be slid into the fuselage from below, I figured I could now join the fuselage halves in preparation for this operation. Here are the fuselage and wing assemblies being tested for fit relative to each other: The gaps at the wing root very much remind me of the Dragon kit, and I wouldn't be surprised if that's a source of "inspiration" for this one: Note also the large gap at the bottom of the forward fuselage: I can push the two halves in to meet OK, but that would require reshaping the section where the wing meets it. I think it would be easier just to shim the gap. OK, that's it for now! My next task is to prepare and paint the cockpit tub so that it can be inserted into the fuselage. I'm hoping this will also spread the fuselage somewhat, and help eliminate the wing root gaps. This kit also comes with the same markings that I'm planning to use on my 1/32 build, so I reckon this one will become something of a mini-me. More soon! Kev Gazzas, BradG, Greg W and 8 others 11
Sparzanza Posted January 5, 2018 Posted January 5, 2018 Wow, never seen a FW like this. I'll be sure to follow along on this journey. LSP_Kevin and Martinnfb 2
Thunnus Posted January 5, 2018 Posted January 5, 2018 Nice start Kevin! Sorry to hear about the JB Kwik not setting correctly. Did it just not harden all the way? Martinnfb and LSP_Kevin 2
LSP_Kevin Posted January 5, 2018 Author Posted January 5, 2018 Nice start Kevin! Sorry to hear about the JB Kwik not setting correctly. Did it just not harden all the way? Not even close - it just went all rubbery. I left it to cure for about 12 hours or so, which should have been plenty. I'm only guessing that I got the mix wrong, but I can't think of another plausible explanation. Kev Martinnfb 1
LSP_Ron Posted January 5, 2018 Posted January 5, 2018 Here are a few pics I took of the real one a few years ago. Mal_Belford, Martinnfb, chukw and 5 others 8
Thunnus Posted January 5, 2018 Posted January 5, 2018 Yeah... that doesn't sound right. Mine went rubbery in about five minutes and the joint was solid in less than 10. I was able to sand the stuff within hours of application and it responded very well to sanding while retaining just a bit of flex to it. I thought it would make a good filler material since that flex would make it less prone to cracking. LSP_Kevin and Martinnfb 2
Gazzas Posted January 5, 2018 Posted January 5, 2018 Cool! I never imagined this would be in kit form. Gaz Martinnfb and LSP_Kevin 2
mustang1989 Posted January 9, 2018 Posted January 9, 2018 I'm liking this one already Kevin. Being a fan of 190's , I really enjoy the "different" variations of this bird. I'll be watching the progress. Martinnfb and LSP_Kevin 2
LSP_Kevin Posted January 9, 2018 Author Posted January 9, 2018 Thanks, fellas. I'm just dealing with the PE seat belts, and once they're finished and installed, I can call the cockpit done, and install it into the fuselage. Should actually be a pretty quick run to the finish line from there. Kev Martinnfb 1
LSP_Kevin Posted January 11, 2018 Author Posted January 11, 2018 So, as predicted, I've made quite a bit of headway with this one. All the main components are now together, and most of the main gaps have filler in them: The cockpit was a bit of a pain to paint and detail, being a single-piece resin tub, but I managed to do a serviceable job given the quick-fire nature of this project: The seat belts and instrument panels are PE parts that come in the kit, as are the unseen rudder pedals. I opted to use the injection-moulded canopy for the sake of expedience, even though it's not great clarity-wise. At least it seems to fit OK: I need to break out some epoxy putty to take care of the remaining gaps, most especially to fair in the wheel bays, and then it's on to the paint job! Kev Kendzior, Gazzas, BradG and 6 others 9
BradG Posted January 11, 2018 Posted January 11, 2018 Pretty good job. I've considered grafting the upper fuselage onto a Tamiya kit before. Not sure mine will ever get done lol Martinnfb 1
LSP_Kevin Posted January 11, 2018 Author Posted January 11, 2018 It's not a great kit to start with if you really want to build a show-stopper, but grafting the hump on to a different kit (which is essentially what I'm doing with the 1/32 scale version) would come with its own problems. A better target kit might be the Dragon one, as I suspect this kit has been patterned off it. With the Dragon kit, you'd get better moulding and sharper details (than the MPM parts), and the donor spine would be more likely to fit without serious work. If you don't think you'll ever build yours, maybe I'll take it off your hands and give it a go! Kev Martinnfb 1
Thunnus Posted January 11, 2018 Posted January 11, 2018 Looking good Kevin! Can't wait to see some paint on this rarely modeled aircraft. Martinnfb and LSP_Kevin 2
Ohm-men Posted January 12, 2018 Posted January 12, 2018 I can definitly say that the MPM Fw 190 S 5/8 is a copy of the Dragon Fw 190. I build the two side by side several years ago. The parts are interchangeable. I used several Dragon parts on my S-5. As some of the short run MPM parts are very crudly molded. You are making very good progress with the "S" it seams! Though MPM's S5/8 is still easier to construct then the old Falcon vacu conversion kit. to bad the old MPM vacu canopies have a severe case of yelowing going on. But I think with some polishing compound and some micro mesh the injected canopy can be made to good use. I hope to build another S5 from some leftover Fw 190 parts some day in 1/48 scale by mating the spine and longer cockpit era of the falcon conversion to a newer Eduard A5 kit. But it's far down the list... Martinnfb and LSP_Kevin 2
Astro32 Posted January 16, 2018 Posted January 16, 2018 Waaay back in the day I used the MPM fuselage from the firewall back and Tamiya's F-8 for the rest, with a few tweaks that I don't remember now. Yours is looking great! Martinnfb and LSP_Kevin 2
