TonyT Posted November 21, 2016 Share Posted November 21, 2016 MK 14 access panels from the high back manual http://i536.photobucket.com/albums/ff321/taylortony/Spitfire%20MKx1x/more%20Spit/Mk%2014/_MG_5781mk14drawing.jpg~original airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted November 21, 2016 Author Share Posted November 21, 2016 Thanks chaps MK 14 access panels from the high back manual http://i536.photobucket.com/albums/ff321/taylortony/Spitfire%20MKx1x/more%20Spit/Mk%2014/_MG_5781mk14drawing.jpg~original Curious - as usual this seems to be a minefield of fit-out being different - I have this pic of TZ138 which shows the layout I went for which does seem slightly different there are others like the two ahead of the radiator that do marry up - great to get the help though, thank you Are you finding this scale easier of more difficult than 1/32 or 1/24? Thank you. Sincerely, Mark thanks Mark -I would say easier, simply because everything is bigger to work with, however, the downside is I have to protect surfaces as I keep dinking the larger airframe on things as I handle it thanks all Peter Uilleann, Out2gtcha and HerculesPA_2 3 Link to comment Share on other sites More sharing options...
TonyT Posted November 21, 2016 Share Posted November 21, 2016 (edited) MK1Ve http://www.vmiengineering.com/-Spitfire-MK-XVIe-TE311-Spitfire-Wing-Overhaul-BBMF Mk1X http://goactionstations.co.uk/spitfire-nh341-restoration-update-26/ Edited November 21, 2016 by TonyT airscale 1 Link to comment Share on other sites More sharing options...
TonyT Posted November 21, 2016 Share Posted November 21, 2016 https://www.google.co.uk/search?q=&tbm=isch&tbs=rimg:Cama1gAFMxjlIji2lyutnTV9zrIdjEKT-lK8rFfj5TfYG7VmLwgwUCEUYkqEDXR81snKWdeHZIIAPdP_1o-98wK7YtyoSCbaXK62dNX3OEZVYxH9emW5dKhIJsh2MQpP6UrwRn4farfMsYFwqEgmsV-PlN9gbtRGVWMR_1XpluXSoSCWYvCDBQIRRiEfpguHUVaj3WKhIJSoQNdHzWycoRa5qsh3oIDbsqEglZ14dkggA90xFYw1RFZ-579SoSCf-j73zArti3EdfkN2p6N2OO&tbo=u airscale 1 Link to comment Share on other sites More sharing options...
Fencer-1 Posted November 21, 2016 Share Posted November 21, 2016 Hello! Here is the my walkaround of RTAF Mk.XIV at Bangkok. I hope it will help a little. https://www.flickr.com/photos/100009549@N06/albums/72157672900489963 airscale 1 Link to comment Share on other sites More sharing options...
Ironwing Posted November 22, 2016 Share Posted November 22, 2016 Peter, I cant stop looking at your work and I just love your methodologies. I cant imagine what she must look like in the flesh...just so impressive on so many levels. Best Geoff Jeff and airscale 2 Link to comment Share on other sites More sharing options...
airscale Posted November 22, 2016 Author Share Posted November 22, 2016 Hello! Here is the my walkaround of RTAF Mk.XIV at Bangkok. I hope it will help a little. https://www.flickr.com/photos/100009549@N06/albums/72157672900489963 those are extremely useful pics - thank you. I particularly like the ones from above the canopy which is not a point of view I think I have ever seen in detail That drawing you posted, we cannot fathom out what all the panels are for on the bottom of the ailerons, it has the two to access the hinge pins, and that is about it. I have no idea either Tony - I did see them on some reference pics so included them - I have built the ailerons now so they are here to stay! maybe on earlier versions knowing my luck.. TTFN Peter Link to comment Share on other sites More sharing options...
airscale Posted November 22, 2016 Author Share Posted November 22, 2016 I have done a little more, this time the first panel under the wing at the wingtip where the pitot is fitted.. I drew out the panel, cut out the hatch where the pitot is mounted and started riveting... ..once complete I added a small brass tube inside where the hatch is so I can mount the pitot fitting.. ..in a nice little diversion from constant panel work, I started to make the pitot mount itself from a thick sheet of aluminium I got at Telford - I cut the shape with a cutting disc and left a 'handle' so I could hold it in a chuck while I shaped it... ..made the pitot tube from brass rod and prepared the parts for assembly.. ..and assembled - it has a brass pin to slot into the tube in the wing so I can put it on at the end... ..finally the hatch was made by using tape to get the shape, later, fastening screws were simulated and a cut-out where the pitot mount goes through the panel.. ..and the finished parts in place.. ..thats it for today TTFNPeter kike_gt, Starfighter, Jeff and 5 others 8 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 22, 2016 Share Posted November 22, 2016 airscale, zak and Uilleann 3 Link to comment Share on other sites More sharing options...
KUROK Posted November 23, 2016 Share Posted November 23, 2016 How do u get such a clean fit on those round access panels? airscale 1 Link to comment Share on other sites More sharing options...
TonyT Posted November 23, 2016 Share Posted November 23, 2016 The panels on the Aileron appear to be repairs Peter, it looks like at some point they have either had corrosion internally, required to inspect them or had issues with the balance weights, so have cut inspection holes, then pop riveted repairs into the leading edges to fill the inspection holes. airscale 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted November 23, 2016 Share Posted November 23, 2016 Love that pitot. Nicely done. Sincerely, Mark airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted November 23, 2016 Author Share Posted November 23, 2016 The panels on the Aileron appear to be repairs Peter, it looks like at some point they have either had corrosion internally, required to inspect them or had issues with the balance weights, so have cut inspection holes, then pop riveted repairs into the leading edges to fill the inspection holes. hmm, not sure about that Tony as they appear in various pics & drawings in the Montforton book, and online walkarounds so I don't think are one-off repairs on one airframe, like this one.. How do u get such a clean fit on those round access panels? ..just gently turning a conical burr in a hand chuck until the round panel just drops through the hole - usual mantra - go slowly as you can always take away, but never add back material ..now then, I need help / opinions again.. there is what looks like a landing light on period pics of TZ138, but I can't find it on other Spits - some pics make me think it is a lens as it is much darker, some pics make me think it is just another access panel (though non-standard) as it seems to be metal, and in the final colour pic of TZ138 today it looks like a panel with three fixings but maybe this is post restoration? what say you? a light?, a panel? a mirage? odd but I can't seem to find it on other birds TIA Peter Jeff and Uilleann 2 Link to comment Share on other sites More sharing options...
TonyT Posted November 23, 2016 Share Posted November 23, 2016 (edited) http://spitfiresite.com/2010/04/concise-guide-to-spitfire-wing-types.html/2 Internal structure of the Type C wing as fitted to the Spitfire Mk. VIII.The leading edge fuel tank was peculiar to this mark and was not mounted on Spitfires Mk. V and IX.Interestingly, both this and the subsequent drawing (produced by Supermarine) of the Mk. VII show the downward identification lamp. However, this item was deleted in the Mk. VII & VIII production, by modification No. 746 issued on 1 May 1943. Edited November 23, 2016 by TonyT airscale 1 Link to comment Share on other sites More sharing options...
TonyT Posted November 23, 2016 Share Posted November 23, 2016 (edited) see http://forum.largescaleplanes.com/index.php?showtopic=28606 http://thumbs1.picclick.com/d/l400/pict/331992383560_/WW2-RAF-Downward-Identification-Lamp-5-c-557-Mosquito.jpg Edited November 23, 2016 by TonyT airscale and Out2gtcha 2 Link to comment Share on other sites More sharing options...
