Guest Posted November 12, 2015 Posted November 12, 2015 How hard would it be to conform Trump booms to Revell ? I have a set of Trump booms you could have.....Harv
ChrisS Posted November 12, 2015 Author Posted November 12, 2015 Harv, Thanks for the offer, at this point in the build the booms and wings have been assembled, thinking through a boom replacement at this point it seems like an order of magnitude greater than the reshape of the resin chin pieces. Again, thanks much for the offer, it's greatly appreciated. BiggTim 1
BiggTim Posted November 12, 2015 Posted November 12, 2015 How hard would it be to conform Trump booms to Revell ? I have a set of Trump booms you could have.....Harv I might take you up on that, Harv. That would be interesting to try....
Rob Colvin Posted November 12, 2015 Posted November 12, 2015 I plan.....way down the road to build the revell kit myself. That said does it look like the verlinden pit will fit the revell fuselage? Nice work thus far! BiggTim 1
Rick Griewski Posted November 13, 2015 Posted November 13, 2015 Yes this is the Gray Matter boxing so I'm assuming you re-engineered it for the trumpy kit. And you're correct about my tolerance, this is in no way stopping me, merely a small speed bump my friend! Given what we're looking at here, how would you suggest I proceed? 1) Shorten and reshape the resin piece 2) Pull and re-fashion the boom side walls to accept the resin piece as it is I'm rolling both around in my head at this point. The trouble with #1 is getting the blend and reduction in shape correct and breathing in all that resin dust (yes I'll wear a mask), and the trouble with #2 is that the boom reduction will be a lot more dramatic and harder to resolve near the trailing edge of the wing More scotch! My conversion is using the older set for the Revell kit. I needed to do more of 1) and shape the kit and the resin after glue to match up. The miss match was not as dramatic. I recommend modification of the resin. Wear a mask and sand with water to trap the dust. My 0.20 Euro. Rick
skiner Posted November 13, 2015 Posted November 13, 2015 Wow , it's clearly Jurasic Park.... "Spared no expense....."
bdthoresen Posted November 13, 2015 Posted November 13, 2015 Chris-Welcome back! One word for you-M-I-L-L-I-P-U-THack away, sir!THOR
ChrisS Posted November 15, 2015 Author Posted November 15, 2015 (in best Bob Marley style...) "Don't Worry...'bout a ting...cause...every-littl-ting's gonna be alriiight..." Got the port nacelle reshaped and mounted. There's still some filling and blending to do, but the heavy lifting is done on the port side. Will do the Starboard nacelle this afternoon and post a pic of them both on. Thanks for the support and advice, it is much appreciated! Business end Spinner cap and gear bay dry-fit here Rick Griewski, mywifehatesmodels, D.B. Andrus and 3 others 6
Guest Posted November 15, 2015 Posted November 15, 2015 Knew you could do it Chris ! Looking good.....Harv
alaninaustria Posted November 15, 2015 Posted November 15, 2015 Really nice Chris! Good to have you back!! Just like good old times!! ChrisS 1
ClumsyDude Posted November 15, 2015 Posted November 15, 2015 I love watching builds of old kits ... you're up to some great work already, sleeves rolled up and making progress! Great stuff. Jim ChrisS 1
