mark31 Posted August 15, 2015 Posted August 15, 2015 (edited) Hello after recieving this set i put a few things on hold and start this on. The kit. The F-4C/D from tamiya. The conversion kit from GT resin. some reference. The only things i just need are the intakes(underway) and some eduard bits. Progress will be slow so i hope you have patience. Mark Edited January 2, 2016 by mark31 Out2gtcha, Kagemusha, Whitey and 3 others 6
Jack Posted August 15, 2015 Posted August 15, 2015 Mark, you can't be any slower than i am, so just go ahead and have fun with this project, looking good. Jack. mark31 1
mark31 Posted August 18, 2015 Author Posted August 18, 2015 Just a question about the raised pannels on the feuselage. Do the all have to go before i remove to many. Thanks Mark Out2gtcha 1
Youngtiger1 Posted August 19, 2015 Posted August 19, 2015 Mark, nice to see you building a Weasel. Can you show a close up pic of the cockpit and ejection seat details? Looking forward to your build.
Girlscanplay2 Posted August 19, 2015 Posted August 19, 2015 Heck Mark, Just do them all at the same time, I am sure you could Looking forward to this one! Teresa mark31 1
Out2gtcha Posted August 19, 2015 Posted August 19, 2015 Just a question about the raised pannels on the feuselage. Do the all have to go before i remove to many. Thanks Mark You mean the BDR panels Mark? IIRC, they should most all be removed. If I also recall correctly, there is one section (also raised?) on the side/top of the fuselage that I think is some kind of door/vent, and needs panel lines scribed, but NOT raised................a lot of folks are actually using the raised parts themselves as a scribing template, and scribing the panel lines before removing the raised parts.......................then after sanding the raised part off, your left with a nicely scribed access/door/panel. mark31 1
BloorwestSiR Posted August 19, 2015 Posted August 19, 2015 You mean the BDR panels Mark? IIRC, they should most all be removed. If I also recall correctly, there is one section (also raised?) on the side/top of the fuselage that I think is some kind of door/vent, and needs panel lines scribed, but NOT raised................a lot of folks are actually using the raised parts themselves as a scribing template, and scribing the panel lines before removing the raised parts.......................then after sanding the raised part off, your left with a nicely scribed access/door/panel. Brian, I you're referring to the Ram Air Turbine doors. They're on the left side of the fuselage towards the rear end. I sanded off almost all of the BDR panels on my build and the ones I left were because I felt it would be too difficult to re-scribe them (for me). Carl Out2gtcha 1
BloorwestSiR Posted August 19, 2015 Posted August 19, 2015 You mean the BDR panels Mark? IIRC, they should most all be removed. If I also recall correctly, there is one section (also raised?) on the side/top of the fuselage that I think is some kind of door/vent, and needs panel lines scribed, but NOT raised................a lot of folks are actually using the raised parts themselves as a scribing template, and scribing the panel lines before removing the raised parts.......................then after sanding the raised part off, your left with a nicely scribed access/door/panel. Brian, I you're referring to the Ram Air Turbine doors. They're on the left side of the fuselage towards the rear end. I sanded off almost all of the BDR panels on my build and the ones I left were because I felt it would be too difficult to re-scribe them (for me). Carl mark31 1
chuck540z3 Posted August 19, 2015 Posted August 19, 2015 Just a question about the raised pannels on the feuselage. Do the all have to go before i remove to many. Thanks Mark Hi Mark. Good luck with the project and I look forward to seeing your progress. The so-called "BDR" (Battle Damage Repair) raised panels are actually regular panels that were often removed and re-sealed with some sort of caulk, which sometimes left them slightly raised. Tamiya went crazy with the amount of this relief, which is why many believe they are patches of some kind. They're not. They are just regular panels that need to be sanded down, but also retained. The best way to do this is to scribe a deep groove around them, then sand them down. I have a fairly lengthy build thread on an F-4E I made a few years ago that might be helpful, with a link concerning the raised panels here: http://www.arcforums.com/forums/air/index.php?showtopic=224033&st=38 I'm not sure if the F-4C has the "RAT" (RAM Air Turbine) door on it or not, but I deleted mine because the F-4E doesn't have one. Otherwise, almost all of the panel line edits I made should apply to your project. Cheers, Chuck mark31, ghatherly and Kagemusha 3
mark31 Posted August 19, 2015 Author Posted August 19, 2015 Mark, nice to see you building a Weasel. Can you show a close up pic of the cockpit and ejection seat details? Looking forward to your build. Pics are comming Hi Mark. Good luck with the project and I look forward to seeing your progress. The so-called "BDR" (Battle Damage Repair) raised panels are actually regular panels that were often removed and re-sealed with some sort of caulk, which sometimes left them slightly raised. Tamiya went crazy with the amount of this relief, which is why many believe they are patches of some kind. They're not. They are just regular panels that need to be sanded down, but also retained. The best way to do this is to scribe a deep groove around them, then sand them down. I have a fairly lengthy build thread on an F-4E I made a few years ago that might be helpful, with a link concerning the raised panels here: http://www.arcforums.com/forums/air/index.php?showtopic=224033&st=38 I'm not sure if the F-4C has the "RAT" (RAM Air Turbine) door on it or not, but I deleted mine because the F-4E doesn't have one. Otherwise, almost all of the panel line edits I made should apply to your project. Cheers, Chuck Thanks for the link will look tru your build. Here a detail pic of the seat and pit. Thanks about the pannels. This are the ones. The one with the crosses that im sure of so now i know the rest has to go. Thank you all Mark ghatherly, Girlscanplay2, Zero77 and 1 other 4
andromeda673 Posted August 19, 2015 Posted August 19, 2015 totally bitching!!!!!! following this one!
Guest Peterpools Posted August 20, 2015 Posted August 20, 2015 Hi Mark Looking forward to following your F4 build and I'm strapped in and waiting. Keep 'em coming Peter
