MikeMaben Posted October 30, 2017 Share Posted October 30, 2017 Fins are bang on - measurements directly from Lockheed drawings Hi Iain, may I ask where you obtained the drawings ? Link to comment Share on other sites More sharing options...
Out2gtcha Posted October 30, 2017 Share Posted October 30, 2017 Forgot how bloody big this thing was. Looks great! Link to comment Share on other sites More sharing options...
ClumsyDude Posted October 30, 2017 Share Posted October 30, 2017 A-bloody-mazing Iain! Looks brilliant. Jim Link to comment Share on other sites More sharing options...
Guest Maxim Posted October 30, 2017 Share Posted October 30, 2017 Great to see it finally coming together. I would love a Connie in 32 scale. Link to comment Share on other sites More sharing options...
Iain Posted October 30, 2017 Author Share Posted October 30, 2017 Hi Iain, may I ask where you obtained the drawings ? Hi Mike, From one of the many books I have - it's not a 'scale drawing' but gives vertical station dimensions: Iain sandokan and MikeMaben 2 Link to comment Share on other sites More sharing options...
Iain Posted October 30, 2017 Author Share Posted October 30, 2017 Yay - I've found my canopy 'master' - needs a fair amount of adjustment, but will save some time! Iain LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Phartycr0c Posted October 30, 2017 Share Posted October 30, 2017 Christ on a bike Iain, I knew this thing was big but now the wings are on its mahoosive! makes my B17 Dio look tiny. Is she coming to Telford? Link to comment Share on other sites More sharing options...
Iain Posted October 30, 2017 Author Share Posted October 30, 2017 Lunch time and the sun is out - excuse the state of the grass - someone mentioned B-17... Connie is about 50% longer, and quite a bit bulkier - photo with Cameron is deceptive as Cam is behind - so this should give a better idea, or maybe not? Iain Starfighter, AlexM, Harrison90 and 13 others 16 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 30, 2017 Share Posted October 30, 2017 Wow! Kev Link to comment Share on other sites More sharing options...
Guest Maxim Posted October 30, 2017 Share Posted October 30, 2017 Forgot how bloody big this thing was. Looks great! Don't be fooled! It's just a very small coffee table and a paper cut of of his son!! Link to comment Share on other sites More sharing options...
Iain Posted October 31, 2017 Author Share Posted October 31, 2017 OK - that windshield area that I thought I'd lost... The pattern is built up from a base-plate cut to size, the remnants of the sections cut away from the fuselage mouldings, a fill of casting resin - then individual plastic sheet windows (7 of them) cut to shape and applied. Here the 'panes' have had inconsistencies filled and then sanded back - circular motion on 800 grit wet and dry on glass surface - being very careful to keep each pane perfectly flat and with sharp jointing corners. Pattern is over tall - will be trimmed down to fit fuselage. Once trimmed for height I'll cut out openings for each pane and replace with clear PETG sheet. Next stage with pattern is to make a female mould in plaster which will then be used to form the plastic shell on my dental vac forming machine. Have fun! Iain Hubert Boillot, sandokan, LSP_Kevin and 4 others 7 Link to comment Share on other sites More sharing options...
Trak-Tor Posted November 2, 2017 Share Posted November 2, 2017 Great pictures. It's really some piece of plastic... Nice progress. Juraj Out2gtcha 1 Link to comment Share on other sites More sharing options...
Iain Posted November 6, 2017 Author Share Posted November 6, 2017 Lots more progress - with wings fitted and bonded with another 2 Oz of 30 min Epoxy - excellent stuff! Need to adjust the mounts for the tip tanks - a little nose high at the mo - but easily fixed! Have fun! Iain Trak-Tor, AlexM, sandokan and 7 others 10 Link to comment Share on other sites More sharing options...
TorbenD Posted November 6, 2017 Share Posted November 6, 2017 Holy wow! Torben Iain 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted November 6, 2017 Share Posted November 6, 2017 Now you just need to scratch build a 2 square meter paint barn. Great work! Jim Iain 1 Link to comment Share on other sites More sharing options...
