Mmarchal Posted May 9, 2017 Share Posted May 9, 2017 (edited) Hi, Here's my finished Ninak. I am still planning on building a base for her, but that may take some time as I can't quite find what I want. The kit is near perfect, as usual with WNW. Making pics was challenging due to the size of the model, the Ninak is large. Hence the pics are not that great. It's build OOB, except for the HGW seat belts and bomb accessories. I enjoyed every minute of the build. Edited May 15, 2017 by Mmarchal Jan_G, MikeC, Girlscanplay2 and 9 others 12 Link to comment Share on other sites More sharing options...
Iain Posted May 9, 2017 Share Posted May 9, 2017 Beautiful build! Iain Mmarchal 1 Link to comment Share on other sites More sharing options...
ZachP319 Posted May 9, 2017 Share Posted May 9, 2017 Nice Ninak Zach Mmarchal 1 Link to comment Share on other sites More sharing options...
OldTroll Posted May 9, 2017 Share Posted May 9, 2017 Mighty fine build of a mighty fine aircraft. Mmarchal 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 10, 2017 Share Posted May 10, 2017 Terrific build, Marc! May I publish it on the website? Kev Mmarchal 1 Link to comment Share on other sites More sharing options...
Mmarchal Posted May 10, 2017 Author Share Posted May 10, 2017 Yeah, sure Kevin, glad you like her Link to comment Share on other sites More sharing options...
Joe66 Posted May 10, 2017 Share Posted May 10, 2017 Impressive ! Joe Mmarchal 1 Link to comment Share on other sites More sharing options...
Jim Barry Posted May 10, 2017 Share Posted May 10, 2017 Mmmm. Most excellent finish work. These WNW kits are something else! --Jim Mmarchal 1 Link to comment Share on other sites More sharing options...
MikeC Posted May 10, 2017 Share Posted May 10, 2017 Very well done. Mmarchal 1 Link to comment Share on other sites More sharing options...
Jan_G Posted May 10, 2017 Share Posted May 10, 2017 Perfect build Marc! I like it a lot jan Mmarchal 1 Link to comment Share on other sites More sharing options...
Gerhard Posted May 10, 2017 Share Posted May 10, 2017 Superb!!! Wont you please give us a rundown on how you did the rigging? Mmarchal 1 Link to comment Share on other sites More sharing options...
Mmarchal Posted May 10, 2017 Author Share Posted May 10, 2017 Hi Gerard, I mostly use ezwire, the elastic stuff you can source from the WNW site ore from Ushi v. As glue I use superglue, the gel type. For the wing, I work top to bottom. Glue all wires in the top wing, then turn the model over, cut the wires a coiple of mm's short and glue them into the bottom wing attachment points. I find that the trick is to get them in place on the first attempt. I never try a second time without shortening the wire and re-applying glue (I never apply glue to the model, only to the wires) I use sharp nosed tweezers to hold the wires in place, without tension to the glue point, for about 10 seconds. It really isn't that hard to do. For very short runs, I tend to use stretched sprue painted black. On this model I used sprue for the control cable attachments on the top and bottom wing. I use normal cement in that case. For the engine, ignition wires etc, I used copper wire, the really small stuff used in cell phone cables (used as a screen). These can be bend to suit and glued with super glue. If I want to mimic turn buckles, I use brass tube sourced from bob buckles which I slide over the elastic wire. Easy to do and the buckles always align with the wire. In rare occasions I use super glue accelerator, applied carefully to the model with a tooth pick. (Basically, I only do this when I get really frustrated with a difficult to reach and attach wire - not needed on this model) Hope this helps. Scare of rigging stopped me from building WW1 planes, but it really isn't that difficult, Marc. MikeC 1 Link to comment Share on other sites More sharing options...
dutik Posted May 10, 2017 Share Posted May 10, 2017 Wonderful! Regards - dutik Mmarchal 1 Link to comment Share on other sites More sharing options...
Bill Cross Posted May 10, 2017 Share Posted May 10, 2017 Really nice. Mmarchal 1 Link to comment Share on other sites More sharing options...
KUROK Posted May 11, 2017 Share Posted May 11, 2017 Superb to say the least! I don't own any WNW kits....yet....but they look killer! Mmarchal 1 Link to comment Share on other sites More sharing options...
