quang Posted March 13, 2017 Share Posted March 13, 2017 (edited) I waited for the Roden 1/32 O-1 Bird Dog with much anticipation. When it finally arrived, I wasn't disappointed: a simple, no-nonsense, accurate, well-moulded kit albeit a little scarce in interior details. This latter point didn't bother me a bit because I like to detail cockpits and interiors.IMO the one thing the kit lacks is an M-16/ AR-15 assault rifle which is closely associated with the Bird Dog and the FAC missions it was renowned for in the Vietnam conflict. The O-1 is a little bare without it. The problem is that M-16's can be easily found in armor modelling in 1/35 but none in 1/32. So what to do?Build one from scratch.This is how I did it. The reference is a profile view taken from the internet et reduced to 1/32 scale. The material: plasticard and brass wire. The pictures say it all.In situHope you like it.Cheers,Quang Edited March 27, 2017 by quang Hubert Boillot, Zero77, Out2gtcha and 6 others 9 Link to comment Share on other sites More sharing options...
Martinnfb Posted March 13, 2017 Share Posted March 13, 2017 Awesome! Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 13, 2017 Share Posted March 13, 2017 Quang You never fail to amaze me Looking real good Keep 'em coming Peter Link to comment Share on other sites More sharing options...
ericg Posted March 13, 2017 Share Posted March 13, 2017 Excellent work mate. quang 1 Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2017 Share Posted March 13, 2017 I love it !.....Harv Link to comment Share on other sites More sharing options...
Skywagon Posted March 23, 2017 Share Posted March 23, 2017 Hi quang, Nice scratched build the M-16! and very details in the cabin. I like your canvas sound proof also, it's look very awe some! I'll follow your build definitely! thanks for sharing your WIP. Link to comment Share on other sites More sharing options...
TorbenD Posted March 23, 2017 Share Posted March 23, 2017 Loving it! Torben Link to comment Share on other sites More sharing options...
quang Posted March 24, 2017 Author Share Posted March 24, 2017 Thank you all for your kind words. My intent is not to do a detailed WIP since there are already 3 excellent ones on this forum. Instead I'd like to share with you my take on this particular aircraft which also is one of my favorites. My main reference is LG Halls' 1/48 plans first published in Model Airplane News in 1969. Compared with the drawings, the Roden kit is spot-on. So far so good. However the cockpit/cabin interior is spartan and lacks much of the 'furniture' that makes this type of aircraft particularly interesting. Firstly, boxes and various dials are added from plasticard. Note the round inspection hatches on the cabin floor. Some brass placards from an old Reheat sheet are used to represent the numerous radio faces. This is the O-1E version. The instrument lay-out is slightly different from the kit (O-1A) version. The circuit breakers (on the kit IP) have moved and now are located on a panel under the left window. A view of the right side with some of the canvas lining installed. More of it later. Note the quilted lining covering the firewall and the console under the instrument panel. Next time I'll show you how I made the linings and how I installed them. Until then, keep well. Quang Hubert Boillot, Shawn M, Zero77 and 3 others 6 Link to comment Share on other sites More sharing options...
petrov27 Posted March 27, 2017 Share Posted March 27, 2017 looking very good - interested in how you do the quilting Link to comment Share on other sites More sharing options...
Finn Posted March 27, 2017 Share Posted March 27, 2017 Great work Quang. In case you want to detail the engine: https://www.flickr.com/photos/usmcarchives/23342463771/sizes/o/ and here is a another pic that might be of interest: https://www.flickr.com/photos/usmcarchives/23342460971/sizes/o/ Jari quang 1 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted March 27, 2017 Share Posted March 27, 2017 Woah! That's some nice work there Quang! Link to comment Share on other sites More sharing options...
Guest Posted March 27, 2017 Share Posted March 27, 2017 Very nice Quang ! Looks fantastic.....Harv Link to comment Share on other sites More sharing options...
quang Posted March 27, 2017 Author Share Posted March 27, 2017 and here is a another pic that might be of interest: https://www.flickr.com/photos/usmcarchives/23342460971/sizes/o/ Jari Gee, Jari! I can see in your pic that there is also a piece of quilted lining covering the back of the cabin. Will have to add that to the build. Thanks for the heads-up and also you guys for the kind words Here's how I made the diamond-patterned lining. The basic material is a 70/30 mix of Milliput and Duro epoxy putties. Milliput is hard and somewhat brittle. Duro is chewy and leatherlike. Mixing the two gives us the right consistency and a comfortable 45-minutes to work with before the putty settles and hardens. The blob is flattened using a small rolling pin and plenty of talcum powder to prevent the putty sticking to the work surface. After a dozen passes, the resulting paper-thin sheet is imprinted with parallel lines using the edge of a straight edge ruler. A second series of lines imprinted at an angle to the first and we get a nice diamond pattern. The sheet is then cut to smaller bits using scissors. The individual (oversized) pieces are then laid on the parts to be covered. Trim to the right size with X-Acto blade. The central part is the last to be covered. Leave overnight to harden. Do a final trim trim and it's ready to be primed. The rest of the cabin is lined with plain rubberized canvas. Same method as above but without the diamond-pattern step. The lining is done in several parts, each one overlapping the next. Here's the first step: Right side Left side Lining completed and primed. Left: Right That's all for today, folks. Next time we'll tackle the instrument panel. Until then, keep well Cheers, Quang Hubert Boillot and johncrow 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 27, 2017 Share Posted March 27, 2017 Fantastic work, Quang! And your technique for producing the quilted padding is killer! Thanks for sharing. Kev Link to comment Share on other sites More sharing options...
dodgem37 Posted March 27, 2017 Share Posted March 27, 2017 Great show! Sincerely, Mark Link to comment Share on other sites More sharing options...
