monthebiff Posted March 24, 2018 Author Share Posted March 24, 2018 (edited) So I added some decals to the rear of the glazing panel on the cowls fixed in place with Future and then added a length of styrene strip painted RLM 02, not strictly accurate but will be good enough when all closed up. And cowling now glued in place, I also added the seal from masking tape also sealing the edges to stop peel with a little future. Now on to the other wing which is having a bit of a fight with me getting everything aligned but I think I am nearly there with it now, hopefully have both wings complete this coming week including drop tanks assembled and test fitted. Regards. Andy Edited June 29, 2018 by monthebiff florin13, tucohoward, Greg W and 6 others 9 Link to comment Share on other sites More sharing options...
Michael Scarborough Posted March 24, 2018 Share Posted March 24, 2018 Neat stuff, Andy!!! monthebiff 1 Link to comment Share on other sites More sharing options...
JeffH Posted March 24, 2018 Share Posted March 24, 2018 Brilliant. Push on then! monthebiff 1 Link to comment Share on other sites More sharing options...
Thunnus Posted March 26, 2018 Share Posted March 26, 2018 Awesome work Andy! I love the instruments on the engine facing the cockpit! monthebiff 1 Link to comment Share on other sites More sharing options...
monthebiff Posted March 30, 2018 Author Share Posted March 30, 2018 (edited) Managed to finish the wings today after fitting the oil cooler and radiators , pretty happy with the results after lots and lots of careful dry fits and adjustment I think its as good as I will get. Followed by a very quick dry fit with the fuselage Starting to look a lot like a G-4 now! For anyone working on this conversion be very careful constucting the engine naceles as you can easily be tripped up and get things out of alignment, I think the key is getting the upper rear cowl correctly aligned on to the upper wing and the only way you can do this is with the wing halves taped together with no wheel wells fitted. Take it slowly and all should come nicely together! Regards. Andy Edited June 29, 2018 by monthebiff Harrison90, Darren Howie, Shawn M and 14 others 17 Link to comment Share on other sites More sharing options...
mozart Posted March 30, 2018 Share Posted March 30, 2018 Yep, you're absolutely right about the nacelles, trickiest part of the build I reckon even OOB. Looking very good Andy. Max monthebiff 1 Link to comment Share on other sites More sharing options...
monthebiff Posted March 30, 2018 Author Share Posted March 30, 2018 Yep, you're absolutely right about the nacelles, trickiest part of the build I reckon even OOB. Looking very good Andy. Max Awful break down of parts by Dragon isn't it Max and probably because they were leaving there options open for an F/ G version but it never happened! Hardest parts of this conversion for me have been: i) Shrage Musik installation fit issue's, from my build the rear fire wall needs to go back about 5mm more than the conversion instructions but hopefuuly anyone following my build wont have any issues with this. Interested to see another build to see if I have messed up or they come to the same conclusion as me in this area. ii) FuG array installation, lots of careful measuring and pinning while making sure all is square. The 220b installation is probably the hardest but strongest when complete. iii) Replacement engine nacelles iv) and the part most people have expressed most concern with before even having a go is the rear vac canopy. I'm pretty close to final assembly of the main airframe now and all I can say is measure, measure and measure again and all should fall into place. Regards. Andy mozart 1 Link to comment Share on other sites More sharing options...
Wouter Posted March 30, 2018 Share Posted March 30, 2018 (edited) Great tip on the engine cowlings! Tell me, did you pick up the model and made a quick round through the room making broommm, brooom sounds? Edited March 30, 2018 by Wouter monthebiff, Michael Scarborough and Pastor John 3 Link to comment Share on other sites More sharing options...
Pastor John Posted March 31, 2018 Share Posted March 31, 2018 Well done Andy monthebiff 1 Link to comment Share on other sites More sharing options...
Gerhard Posted March 31, 2018 Share Posted March 31, 2018 I'm too scared to start mine. I put my kit and conversion in a safe place. Hopefully I can build it in a way that will make the sponsors proud. Your build is an inspiration. monthebiff 1 Link to comment Share on other sites More sharing options...
Shawn M Posted April 3, 2018 Share Posted April 3, 2018 great work and good tips for my future build as well monthebiff 1 Link to comment Share on other sites More sharing options...
Thunnus Posted April 3, 2018 Share Posted April 3, 2018 Wow... it really is coming together nicely! Such clean work... does not look like a conversion at all. monthebiff 1 Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2018 Share Posted April 3, 2018 You rally make it look easier than all the work it takes. I also have the kit and conversion but will wait some time before starting. Thanks so much for taking your time to show us the way !.......Harv Link to comment Share on other sites More sharing options...
monthebiff Posted April 3, 2018 Author Share Posted April 3, 2018 Great tip on the engine cowlings! Tell me, did you pick up the model and made a quick round through the room making broommm, brooom sounds? Of course Wouter, it's got to be done when I get to this point on a build Regards. Andy Michael Scarborough 1 Link to comment Share on other sites More sharing options...
monthebiff Posted April 3, 2018 Author Share Posted April 3, 2018 Well done Andy Thank you John, pretty well there with the conversion now and so far the fit has been pretty good all round. A really nice conversion indeed!! Regards. Andy Kagemusha 1 Link to comment Share on other sites More sharing options...
