After painting some detail, I assembled the engine.
I got a few tips from Dugy's Thunderbolt build! One of them was to lower the engine.
The other one was to cut up the drop tank mount in order to raise it a bit so the tank won't touch the floor.
I've also worked a bit with the landing gear and tank parts, preparing stuff for paint.
So now I got some painting and later assembly to do! :)
Håkan
Hello Håkan!
Full speed Ahead:clap2:.
Nice progress.
Cheers
Boris
The rims, covers and the tank was painted aluminium.
Then the covers was turned over and painted zinc-chromate yellow.
I almost forgot to put a small decal on the engine, but now it's done! :)
The tires was painted with a mix of tire black and black.
I kinda more or less copied what Dugy had done! :)
After trying a few OD colours on the bombs, I found one that I liked.
Now they only need a bit of touching up and decals, unless I paint the yellow bands.
The prop tips and spinner got some yellow paint.
I first glues the cowlings and then the bottom cover with the engine. After that the other covers was glued in place, one by one.
A few bits and pieces to sort, like masking the canopy, before I can start priming and painting.
Håkan
5 hours ago, Azgaron said:
Thank you Dugy and thanks for the very useful tips on your build! :)
Håkan
Ah, your welcome there, naturally I pinched them myself from other builds too…. :ph34r:
