sandbagger Posted August 15, 2023 Share Posted August 15, 2023 (edited) Hi all, I'm still waiting for a couple of things to arrive for the Hansa-Brandenburg W.12 model. Therefore I'm making a start on another model, this time the Bristol F.2b 'Biff' or 'Brisfit' as it was commonly called. This model will represents represents Bristol F.2b, Serial No. A-7194 of No.111 Squadron RFC, Deir-el-Belah, Palestine during 1917. This particular Bristol F.2b, Serial No. A-7194 (along with 7190 and 7198) was delivered on the 25th of August to No.111 Squadron (RFC). No.111 Squadron (RFC) was formed on the 1st of August 1917 at Deir-el-Belah, Palestine and was commanded by Major Shekleton. The Squadron was formed from aircraft of No.14 and often escorted No.1 Squadron (AFC) on their missions. During it time with No.111 Squadron (RFC), A-7149 was noted as having engaged the enemy on at least two occasions: 8th of October 1917 - 2nd Lt. R.C Steele (Canada) and Lt. John J Lloyd-Williams drove down the Albatros D.II, Serial No.636/14 of Oblt. Dittmar of Fab300. This was the first German aircraft captured in Egypt. Pilot Steel was awarded the Distinguished Service Order (DSO). 15th of October 1917 - 2nd Lt. R.C Steele (Canada) and Lt. John J Lloyd-Williams destroyed an Albatross D.III. Initially the enemy pilot indicated he was surrendering, but then tried to make for his lines and had his wing shot off. The squadron was always intended to be a single seat fighter unit. In January 1918 the squadron handed over its Bristol F.2b aircraft to No.1 Squadron (AFC) after being equipped with the SE5a fighters. No.1 Squadron (AFC) operated with No.111 Squadron (RFC) and later No.142 Squadron (RFC) as part of the 40th (Army) Wing (RFC). The wing formed part of the Palestine Brigade (RFC), the other part of the Brigade was formed by 5th (Corps) Wing (RFC), comprised of No.14 and No.113 Squadrons (RFC). Bristol F.2b, Serial No. A-7194 was transferred from No.111 Squadron (RFC) via Kantara to No.1 Squadron (AFC) on the 11th of January 1918. During its time with No.1 Squadron (AFC) it flew regular missions with different crews through February and March, before crashing on take-off on March the 28th. NOTE: The change in the aircraft colour scheme and style of the serial number when serving with No.1 Squadron (AFC). Mike No.111 Squadron (RFC) in 1917. No.1 Squadron (AFC) in 1918. Edited September 19, 2023 by sandbagger LSP_Kevin, denders, Uncarina and 6 others 9 Link to comment Share on other sites More sharing options...
sandbagger Posted August 31, 2023 Author Share Posted August 31, 2023 Hi all, Here's the basic Rolls Royce 'Falcon' V12 in-line engine. It still needs additions, such as ignition leads, controls and pipes and weathering, Mike Furie, patricksparks, Uncarina and 8 others 11 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 31, 2023 Share Posted August 31, 2023 Lovely stuff, Mike. Kev Link to comment Share on other sites More sharing options...
Furie Posted August 31, 2023 Share Posted August 31, 2023 Superb! Can't wait for the sequel! Link to comment Share on other sites More sharing options...
sandbagger Posted September 7, 2023 Author Share Posted September 7, 2023 Hi all, The basic Rolls-Royce 'Falcon' V12 engine is complete. There are other parts that can only be fitted once the engine has been installed in the fuselage. I've added representations of carburetor/magneto controls and fuel supply/drain pipes. Although the rear of the engine will hardly be visible once installed. I've also added oil pipes, spark plugs and ignition leads. All with a combination of: 0.2 and 0.3 mm diameter Nickel-Silver tube (controls, spark plugs) 0.3 and 0.5 mm diameter Brass tube (fuel supply/drain pipes) 0.4 mm diameter flexible tube (black) (oil pipes) Steel coloured silk thread (ignition leads). Weathered with oil paint and enamel wash. Mike Landrotten Highlander, crobinsonh, Kagemusha and 6 others 9 Link to comment Share on other sites More sharing options...
sandbagger Posted September 16, 2023 Author Share Posted September 16, 2023 Hi all, The cockpit is nearly completed. The pilots seat is a replacement from 'Gaspatch'. I've added the control cables for the ailerons, rudder and tail plane incidence control. The elevator cables are external, so not in the cockpit as such. Also I've added the trigger cable on the control column for the pilots Vickers machine gun. Finally I added control rods from the pilots throttle quadrant and the radiator shutters control. Weather was done using 'Flory Models' wash (Grime). The cockpit assembly is now fitted into the closed up fuselage. However I do have a problem to solve. I got distracted, so unfortunately, I fitted the cockpit into the fuselage without any bracing wires fitted. I now have to try and fit them all through the cockpit opening in the fuselage. It happens, Mike olgerd83, HB252, Fanes and 9 others 12 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 16, 2023 Share Posted September 16, 2023 Superb, Mike! I hope you can get the bracing wires in without any fuss. Kev Link to comment Share on other sites More sharing options...
Kerbalnout Posted September 18, 2023 Share Posted September 18, 2023 Looking great!! Link to comment Share on other sites More sharing options...
sandbagger Posted September 18, 2023 Author Share Posted September 18, 2023 Hi all, I've added the cockpit bracing wires. These are 0.2 mm diameter Nickel-Silver rod. Each was cut to the required length then secured in position using CA adhesive, Mike Landrotten Highlander, Shoggz, Fanes and 6 others 9 Link to comment Share on other sites More sharing options...
sandbagger Posted September 18, 2023 Author Share Posted September 18, 2023 Hi all, Photographs of this particular aircraft show what seems to be an ‘in-field’ modification to the two upper access panels over the engine The blister on each panel was needed to clear the panel from the engine upper coolant pipes. On this aircraft the blisters were cut away in order to provide an opening for, I assume, additional engine cooling, as the aircraft operated in the warmer climate of Palestine. Also the upper right access panel will be displayed open and therefore the two upper panels need to be modified accordingly. It's not clear if all of the aircraft in this squadron had the in-field modification carried out on the two upper access panels over the engine. Mike scvrobeson, LSP_Kevin, coogrfan and 2 others 5 Link to comment Share on other sites More sharing options...
sandbagger Posted September 19, 2023 Author Share Posted September 19, 2023 Hi all, The basic modification to the engine access panels, although not yet finished. The upper access panels have had their blisters removed. Also, the panel locating tabs were removed and their locating recesses filled. These panels were secured together with an added 0.5 mm diameter Brass rod to represent the centre hinge. The three lower panels have had their air intake scoops reduced in thickness to look more in-scale. Mike Kagemusha, Landrotten Highlander, denders and 4 others 7 Link to comment Share on other sites More sharing options...
sandbagger Posted September 27, 2023 Author Share Posted September 27, 2023 Hi all, The basic decal and fuselage painting are done. I used ‘Aviattic’ Bleached Clear Doped Linen (ATT32044) for the undersides. The Off White Linen (ATT32241) for top surfaces and the rest PC10 Medium Linen (ATT32090). All applied on a gloss white base coat. The painted forward fuselage and panels were airbrushed with 'Hataka' lacquer paint and mixed to match the PC10 decal colour. 'Hataka’ black top paint Vert Fonce (C124) with Medium Green (CO19) to a ration of 50/50 and thinned with approximately 35% ‘Mr. Colour’ self levelling thinner 400. The white serial number was created using cut masks from de-tacked 'Tamiya' masking sheet. Still a bit more to do for weathering and detail painting before construction continues, Mike denders, Kagemusha, Furie and 7 others 10 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 27, 2023 Share Posted September 27, 2023 Great stuff, Mike. Looks like real fabric. Kev Link to comment Share on other sites More sharing options...
Archimedes Posted September 28, 2023 Share Posted September 28, 2023 Neatly done on the bracing wires Mike! Kind regards, Paul Link to comment Share on other sites More sharing options...
Kagemusha Posted September 28, 2023 Share Posted September 28, 2023 Outstanding, love the colours. Link to comment Share on other sites More sharing options...
