Sasha As Posted May 21, 2023 Share Posted May 21, 2023 You can never have too many Messerschmitts. )))) Starting to build an interesting Me-209 V-4 in 48 by A&A. There is something to work on in the model, but in general quite good, given the lack of alternativeness of the model. On information for construction, of course searched quite a long time, but he who seeks is always with work. ))))) I assembled the basic details of the glider. I expected worse, but it is at the Modelsvit level. Drilled holes for machine guns, cannon (pasted a tube), holes in the rear of the fuselage (pasted tubing). I evened the parts of the tail rotor and oil cooler, everything fits together nicely. Then we worked with undercarriage recess. There are not many photos of it, but it is possible to understand it approximately. Alex, chukw, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
Sasha As Posted May 21, 2023 Author Share Posted May 21, 2023 Made the wiring in the chassis recesses. They're a bit shallow, but that's about it. Alex, Alain Gadbois, Volksjager and 9 others 12 Link to comment Share on other sites More sharing options...
Sasha As Posted May 24, 2023 Author Share Posted May 24, 2023 A little continuation. Painted undercarriage recesses. Screw, spinner. Alex, MikeC, Greg W and 5 others 8 Link to comment Share on other sites More sharing options...
Sasha As Posted May 24, 2023 Author Share Posted May 24, 2023 I will be using the chassis and exhaust manifolds to assemble the model. The spigots are 3D printed. The wheel rims are also 3D printed. The pneumatics are resin. LSP_Kevin, Alex, Martinnfb and 3 others 6 Link to comment Share on other sites More sharing options...
Sasha As Posted July 26, 2023 Author Share Posted July 26, 2023 Continuing work after a short break. Made wiring, some interior details, belts. The cabin can be primed and painted. ivanmoe, D Bellis, Greg W and 8 others 11 Link to comment Share on other sites More sharing options...
Sasha As Posted July 30, 2023 Author Share Posted July 30, 2023 The cab is almost finished. Glued in the exhaust pipes, made shelves over them.The dashboard is in place. Closed the fuselage. Once again tried on the parts of the glider, not perfect, but after fitting became everything as it should be. Putty will be needed, but not as much as I thought.)))))))) Painted the landing gear. I compared with 109th (skinny it is not called for nothing), 209th will be fuller Alex, chrish, LSP_Kevin and 7 others 10 Link to comment Share on other sites More sharing options...
Sasha As Posted July 30, 2023 Author Share Posted July 30, 2023 Alex, chrish, Greg W and 10 others 13 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 30, 2023 Share Posted July 30, 2023 Nice! Kev Sasha As and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
Sasha As Posted July 30, 2023 Author Share Posted July 30, 2023 11 minutes ago, LSP_Kevin said: Nice! Kev Kevin thank you ! LSP_Kevin and Martinnfb 2 Link to comment Share on other sites More sharing options...
LSP_Ray Posted July 30, 2023 Share Posted July 30, 2023 Very nice! Boy, vision over that nose would be horrible for landing or maneuvering on the ground. Sasha As and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
Sasha As Posted July 30, 2023 Author Share Posted July 30, 2023 33 minutes ago, LSP_Ray said: Very nice! Boy, vision over that nose would be horrible for landing or maneuvering on the ground. Ray thank you! Yeah, it's not the easiest aircraft to fly. )))) Martinnfb 1 Link to comment Share on other sites More sharing options...
RadBaron Posted July 31, 2023 Share Posted July 31, 2023 Great progress! Sasha As and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
Sasha As Posted August 2, 2023 Author Share Posted August 2, 2023 On 7/31/2023 at 8:35 PM, RadBaron said: Great progress! RadBaron thank you ! RadBaron and Martinnfb 2 Link to comment Share on other sites More sharing options...
scvrobeson Posted August 4, 2023 Share Posted August 4, 2023 It's closer in size to the -109 than I expected. Great progress Sasha! Matt Sasha As 1 Link to comment Share on other sites More sharing options...
Greg W Posted August 4, 2023 Share Posted August 4, 2023 I really like this model Sasha, it ticks all the boxes: ■ Interesting subject ■ High level build quality ■ High level paint quality ■ High level everything! Very nice. Sasha As 1 Link to comment Share on other sites More sharing options...
