Revells cheap kit, quite accurate but in terms of parts quality and fit, overly sliced nose and wings, milky canopy, few steps behind Hasegawa. Added metal landing gear from Eduard, resin propeller, resin beules and exhausts, Eduard interior PE. Insead of riveting whole surface i sprayed dark grey while holding sponge for making "lines" of them and to make surface more 3D then using pecil I created dot here and there. Hartmann as new research tells never scored as many kills as he claimed and never was really first in aces table, but I like non-usual painting schemes and this one really buyed me. Hope you like it!
Just as the proverb says: You get what you pay for :D But nothing to keep away a determined modeller from building a good looking model. Stunning paint job :punk:
Regards
- dutik
What an impressive build. Noticed the subtle spiral suggested under the white over spray on the spinner. Which kit did you start with? Surely not the very, very early Revell kit with the large bump under the cowl. Which ever kit, you have pulled off an impressive build. Thanks for sharing.
Thanks guys! It's a Revell from 2013.
