sandbagger Posted June 8, 2021 Share Posted June 8, 2021 (edited) Hi all, I thought you might like to see my 1:32 scale build of the German ‘Hansa-Brandenburg W.20’. This model is from ‘Omega Models’ and is resin. This aircraft was a single seat float, designed to be carried in a water tight container on a type of submarine. The intention was to surface and remove the aircraft from its container, assemble it then launch it for reconnaissance missions. After landing near the submarine, it was be taken onboard, disassembled and stowed back in its container. The special submarines were never built before hostilities ceased and the three prototypes were eventually put into storage. The basic list of changes/additions to the model are: Engine: The resin engine replaced with the equivalent engine from ‘Wingnut Wings and detailed with Nickel-Silver valve push rods and copper wire ignition leads. Propeller: The resin propeller was replaced with a special made wood laminate from ‘ProperPlane’. Modified or corrected: All wing, float and tailplane resin struts were replaced with hand made Brass Tube struts with internal Brass rod. The entire engine support frame was hand made using Brass tube and rod. Rigging is 0.08 mm or 0.12 mm diameter mono-filament with ‘GasPatch’ 1:48th scale turnbuckles and 0.5 mm or 0.4 mm diameter blackened Brass tube. Animation of the ailerons, rudder and elevators achieved by cutting out with Brass rod supports. The beaching trolley and trestle were scratch built, apart from the wheels which were from a 'Kellerkind' model. Aftermarket additions: ‘Aviattic’ Clear linen effect (ATT32236). ‘Aviattic’ German Naval Hex (faded) (ATT32113). ‘GasPatch’ Elite Accessories 1:48th scale metal Turnbuckles. ‘Wings Cockpit Figures’ 1:32 scale Seated pilot (LSK 07A). ‘Elan Miniatures’ 1:32 scale German Naval pilot (EL19). ‘Elan Miniatures’ 1:32 scale RFC Mechanic (modified) (EL41). Coastal Kits’ 1:32 scale Abandoned Airfield Display Base (modified for 3D effect). As usual I've created a downloadable build log in Adobe PDF format, for those who might want to refer to it for reference or build details. It contains full step by step descriptions of the model build, its modifications/changes and is also supported with illustrations and photographs. If viewed in Adobe Reader, each build log has book marked chapters/headings for easier navigation through the log. My model website has the gallery page, so to view any model, go to the gallery and select it. If it has a PDF build log, it will be available to download using the 'PDF' icon on that models photo's page. For any photograph, just click the photo to enlarge or reduce the viewing size. http://igavh2.xara.hosting]Mikes WW1 Aircraft Models Mike Edited June 8, 2021 by sandbagger 109, scvrobeson, Out2gtcha and 11 others 14 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 8, 2021 Share Posted June 8, 2021 Superb, Mike! Kev Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 8, 2021 Share Posted June 8, 2021 Simply lovely! Link to comment Share on other sites More sharing options...
Greif8 Posted June 9, 2021 Share Posted June 9, 2021 Very cool little plane and great job setting up the diorama! Your scratch building skills are top shelf for sure and you did a wonderful job painting and decaling the build! Ernest Link to comment Share on other sites More sharing options...
PrzemoL Posted June 9, 2021 Share Posted June 9, 2021 Spectacular results, especially bearing in mind the quality of the kit. Very fine presentation, too. Surely one to be proud of. Link to comment Share on other sites More sharing options...
LSP_Ray Posted June 10, 2021 Share Posted June 10, 2021 Beautiful, Mike! May I post it on the website? Link to comment Share on other sites More sharing options...
MikeMaben Posted June 10, 2021 Share Posted June 10, 2021 Very very nice Link to comment Share on other sites More sharing options...
sandbagger Posted June 10, 2021 Author Share Posted June 10, 2021 3 hours ago, LSP_Ray said: Beautiful, Mike! May I post it on the website? Thanks everyone - much appreciated; Ray: Certainly Ray and thanks, Mike Link to comment Share on other sites More sharing options...
dodgem37 Posted June 10, 2021 Share Posted June 10, 2021 That is a nice piece of work, Mike. Good show. Sincerely, Mark Link to comment Share on other sites More sharing options...
aircare84 Posted June 10, 2021 Share Posted June 10, 2021 Great build Mike! Exceptional detail work. Not a subject you see often, first one I have seen. Thanks for posting. Link to comment Share on other sites More sharing options...
