spacewolf Posted August 5, 2019 Share Posted August 5, 2019 As most of you know I was challenged to build a master for a kit of Jedha City by Jimi of JPG Productions to go with the upcoming Bandai 1/5000 scale Star Destroyer due out soon. Being that I was thinking of building one for myself it didn't take much arm twisting. It was a first for me making a kit for production but worked out really well. Jimi unveiled it at Wonderfest and it has been well received. He sent me my copy just last week.. it arrived Wed evening and I finished it this morning (Sunday) !! The box is of reasonable size.. the kit was well packed in peanut foam, the city plate & spire were in a ziplock bag. 4 parts, keeping it simple. I wanted the kit to be like the Bandai kits.. go together simple & fast, look good and the real challenge to be painting/ weathering. coogrfan, Alain Gadbois and Christoffer Lindelav 3 Link to comment Share on other sites More sharing options...
spacewolf Posted August 5, 2019 Author Share Posted August 5, 2019 It is a resin kit... and had some typical issues. The main spire was bent, the two shorter ones were 'short shot' and there were some airbubbles in some of the buildings.. Sorry for the crappy pics. The shorter spires I just filed to a flat surface, nipped off a bit of sheet, superglued them on and sanded to final shape. The taller spire I simply broke off and re positioned... Buildings that were a bit rough (6) got some putty.. Some primer and it was done.. all of about 90 minutes work. The main temple had a few air bubbles.. nothing bad at all. LSP_Kevin, coogrfan, Alain Gadbois and 1 other 4 Link to comment Share on other sites More sharing options...
spacewolf Posted August 5, 2019 Author Share Posted August 5, 2019 (edited) First real issue.. one of the sides was a MM short.. not sure if one side warped a bit or not. I thought about using the hot water method to bend one side but decided not to.. as Londo Mollari would say.. "It can't be that bad..." The city plate needed a bit of careful sanding to get the wall seams to close properly. My kit took some time and I finally got a bit frustrated and filled the small remaining gaps with super glue. Once everything was securely glued I slathered on a bit of putty and went to bed.. 3 hrs into the build. Edited August 5, 2019 by spacewolf Uilleann, coogrfan, Coneheadff and 4 others 7 Link to comment Share on other sites More sharing options...
spacewolf Posted August 5, 2019 Author Share Posted August 5, 2019 (edited) The next evening I sanded down the putty and did a bit of re sculpting with files and sanding sticks. Another primer coat, a bit more sculpting, then some putty just spotted on and spread around to roughen up the surface.. Shot coat of primer... Lets play find the seam... :-) Edited August 5, 2019 by spacewolf Out2gtcha, Gazzas, Trak-Tor and 6 others 9 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 5, 2019 Share Posted August 5, 2019 Love it! Cant wait to get to mine spacewolf 1 Link to comment Share on other sites More sharing options...
spacewolf Posted August 5, 2019 Author Share Posted August 5, 2019 And, just like that.. it was paint time... total about 6 hrs into the build. Vallejo air light & dark brown, white and a bit of grey... Just playing... haven't done ground work in decades.. And within an hour or so... I had the look I was shooting for in my minds eye back in March when I started this mad project. Coneheadff, Uilleann, Out2gtcha and 2 others 5 Link to comment Share on other sites More sharing options...
spacewolf Posted August 5, 2019 Author Share Posted August 5, 2019 About 8 hours into the build... this was where I lost track... we are painting buildings... White, light grey, red brown, yellow, light blue, concrete, washes, touchups, enamel gold for the domes.... this took several sessions of at least 2 hrs at a time... but came out pretty much like I'd hoped... And before I knew it.. it was done.. this morning around 9 am....the sun rose over Jedha City... LSP_Kevin, Uilleann, Out2gtcha and 8 others 11 Link to comment Share on other sites More sharing options...
spacewolf Posted August 5, 2019 Author Share Posted August 5, 2019 Thanks for sharing the journey with me and to those who are going to get one of these I simply can't wait to see what you do !! Cheers Vaughn Alain Gadbois, Gazzas, Christoffer Lindelav and 11 others 14 Link to comment Share on other sites More sharing options...
LSP_Ray Posted August 5, 2019 Share Posted August 5, 2019 Thank looks great! Kit turned out nice! spacewolf 1 Link to comment Share on other sites More sharing options...
1to1scale Posted August 5, 2019 Share Posted August 5, 2019 This is cool, and on my list of wants! spacewolf 1 Link to comment Share on other sites More sharing options...
Gazzas Posted August 5, 2019 Share Posted August 5, 2019 That's cool. Power and phone lines? spacewolf 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted August 5, 2019 Share Posted August 5, 2019 Very cool. What are the dimensions of the board? Thank you. Sincerely, Mark spacewolf 1 Link to comment Share on other sites More sharing options...
spacewolf Posted August 5, 2019 Author Share Posted August 5, 2019 5 hours ago, dodgem37 said: Very cool. What are the dimensions of the board? Thank you. Sincerely, Mark 13 1/2 X 8 X 3/4 Out2gtcha 1 Link to comment Share on other sites More sharing options...
Shawn M Posted August 6, 2019 Share Posted August 6, 2019 very cool! spacewolf 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 6, 2019 Share Posted August 6, 2019 Wow! That looks amazing Vaughn! It will look tremendous with a 1/5000 Bandai SD above it too! spacewolf 1 Link to comment Share on other sites More sharing options...
