Juggernut Posted June 16, 2019 Share Posted June 16, 2019 (edited) Apparently, HK used the plans from the Aero Detail book on the B-17G which look good on paper but are way off. If you have a copy of that book, you can see the similarities between these drawings and the HK kit. I've been told the the best drawings of the B-17G that are available are included in a book by Roger Freeman with the drawings done by Watanabe...sorry, the fist name eludes me. I'm not in my library at the moment so all I know of the title is B-17..., I'll amend this post when I get to my library. Edited June 16, 2019 by Juggernut Spelling kkarlsen and Martinnfb 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted June 16, 2019 Share Posted June 16, 2019 Here it is: https://www.amazon.com/17-Flying-Fortress-Roger-Freeman/dp/0517549859/ref=mp_s_a_1_1?keywords=0517549859&qid=1560695119&s=gateway&sr=8-1 This has one of the sets of plans I used. kkarlsen and Martinnfb 2 Link to comment Share on other sites More sharing options...
Juggernut Posted June 16, 2019 Share Posted June 16, 2019 29 minutes ago, thierry laurent said: Here it is: https://www.amazon.com/17-Flying-Fortress-Roger-Freeman/dp/0517549859/ref=mp_s_a_1_1?keywords=0517549859&qid=1560695119&s=gateway&sr=8-1 This has one of the sets of plans I used. Yep, that's the book. kkarlsen and Martinnfb 2 Link to comment Share on other sites More sharing options...
kkarlsen Posted June 18, 2019 Author Share Posted June 18, 2019 (edited) Thanks Guy's, sounds a bit like it's a hopeless project... I'm already looking forward to it So, I've been looking for a more promising place to cut the fuselage... As the interior will be exposed, I moved the cutting line to fit the interior stringers, removing one panel ca. 4-5 mm's. I hope this will make it a bit easier to eliminate the signs of 'surgery'. On the outside the cut will go something like this, beginning with 5-6 mm's at the nose down to 4 mm's behind the wing. At the end the cut will come together a little bit more. Well that's the intention at the moment. This will also correct the panels beneath the cockpit, which are somewhat too wide. BTW: If anybody has tried to form/bend a kit part using hot/boiling water, please let me know if it is possible? Cheers: Kent Edited June 18, 2019 by kkarlsen brahman104, Fencer-1, Martinnfb and 4 others 7 Link to comment Share on other sites More sharing options...
dodgem37 Posted June 18, 2019 Share Posted June 18, 2019 'If anybody has tried to form/bend a kit part using hot/boiling water' I've done this with thick styrene, 040, 060, 080, but not with kit parts. Insinkerator hot water (190 degrees), not boiling water (212 degrees @ sea level). Sincerely, Mark Martinnfb and kkarlsen 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted June 18, 2019 Share Posted June 18, 2019 Well Kent, you are brave! This is surely not a hopeless project as there is nothing that cannot be repaired but this is going to take time for sure! Good luck! I will keep a close eye on that project. T. kkarlsen and Martinnfb 2 Link to comment Share on other sites More sharing options...
brahman104 Posted June 18, 2019 Share Posted June 18, 2019 On 6/16/2019 at 4:09 PM, kkarlsen said: To be honest Craig, I haven''t looked too much at the nose yet. I will 'study' your observations, to see what can be done. Something has to be done about the 'dropping' though, I'm not quite sure what, but it's necessary to get the glass part to fit, after I have removed some of the bottom part of the nose. Cheers: Kent I hope that I can provide some useful deductions then! Getting the original nose piece to fit will definitely be a challenge, but I doubt insurmountable for someone of your talents. Not sure if you've come across it yet, but flattening the nose will also mean the windscreen will need replacing as it's too narrow at the very front..... On flattening the nose, perhaps the partial removal of some sections of plastic from the inside will allow enough "give" to reform the plastic without having to resort to heat. Once the desired shape has been established, some strategic application of some high strength epoxy should hold everything in its new place.... Thierry is right, this is a massive undertaking, but I think your approach is very novel and if you're prepared to put in the effort, absolutely do-able! Go get em! Craig D.B. Andrus, kkarlsen and Martinnfb 2 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted June 18, 2019 Share Posted June 18, 2019 One thing is puzzling me: if you are cutting a section of some mm out of the fuselage, it will not have anymore a round section, won't it? Is it the reason why you foresee that use of heat would be required? kkarlsen and Martinnfb 2 Link to comment Share on other sites More sharing options...
mozart Posted June 18, 2019 Share Posted June 18, 2019 Goodness me, I've got a headache just reading this already!! Utter madness.....love it! Martinnfb and kkarlsen 1 1 Link to comment Share on other sites More sharing options...
kkarlsen Posted June 18, 2019 Author Share Posted June 18, 2019 (edited) 1 hour ago, brahman104 said: flattening the nose will also mean the windscreen will need replacing as it's too narrow at the very front..... Yes I'm aware of that Craig, one problem/solution at a time. I think I will have to scratch the front frame anyways... 1 hour ago, thierry laurent said: One thing is puzzling me: if you are cutting a section of some mm out of the fuselage, it will not have anymore a round section, won't it? Is it the reason why you foresee that use of heat would be required? You are of course right, there will be an issue with that. I will start out by cutting 4-5 mm's max and see how that looks. I'm trying to keep the cutting as close to the center line as possible to be able to smoothed the effect of that. But I'm in no rush cutting anything up yet, I think I will spend a couple of days on other projects, having this in the back of my head. It's often the best way to prepare... Kent Edited June 18, 2019 by kkarlsen mozart, thierry laurent, D.B. Andrus and 4 others 7 Link to comment Share on other sites More sharing options...
mozart Posted June 18, 2019 Share Posted June 18, 2019 1 hour ago, kkarlsen said: But I'm in no rush cutting anything up yet, I think I will spend a couple of days on other projects, having this in the back of my head. It's often the best way to prepare... Kent The creative process Kent: Investigation........INCUBATION.......Inspiration!! Martinnfb 1 Link to comment Share on other sites More sharing options...
Fencer-1 Posted June 19, 2019 Share Posted June 19, 2019 Huh... I've started thinking about full fuselage 3D work for printable option... Craziness! D.B. Andrus and Martinnfb 2 Link to comment Share on other sites More sharing options...
Fencer-1 Posted June 19, 2019 Share Posted June 19, 2019 On 6/18/2019 at 7:00 PM, kkarlsen said: BTW: If anybody has tried to form/bend a kit part using hot/boiling water, please let me know if it is possible? Don't try it. There will be unpredictable warpage of full detail. It can be done only with relatively small simple shapes. D.B. Andrus and Martinnfb 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 19, 2019 Share Posted June 19, 2019 I have done hot water bending of IM plastic, but the shape to be fixed cant be out of line that far, and the water needs to be hot but not boiling. I fixed my 32nd Su-33 MKK wing in that manor, and it worked well. Just have to be VERY careful as to not keep any one part in the water for too long, and make very small adjustments. D.B. Andrus and Martinnfb 2 Link to comment Share on other sites More sharing options...
Iain Posted June 19, 2019 Share Posted June 19, 2019 Used hot water to help effect bending the upper forward fuselage sections when I 'flattened' the nose on the B-17G I've been working on - worked a treat! Iain kkarlsen and Martinnfb 2 Link to comment Share on other sites More sharing options...
