Wackyracer Posted February 14, 2019 Author Posted February 14, 2019 Brass undercarriage arrived! Looks well up for the job. BradG, Out2gtcha, Azgaron and 1 other 4
Stormer Posted February 15, 2019 Posted February 15, 2019 9 hours ago, Wackyracer said: Seems some ships didn't read the forums Well, I just assumed that you were doing Spotted Ass Abe, who’s clearly an eager forum reader...
Wackyracer Posted February 15, 2019 Author Posted February 15, 2019 55 minutes ago, Stormer said: Well, I just assumed that you were doing Spotted Ass Abe, who’s clearly an eager forum reader... Hey wasn't having a go at you. It was a toss up between SAA and Tubarao when I first posted which did so I got the armament set. Your post is fine. It's the next 3 jumping on as well. I'm just a bit fed up with all the negativity on these threads nowadays that's all. To be honest I may well just delete this build and the others I've doing on here.
Scale32 Posted February 15, 2019 Posted February 15, 2019 12 hours ago, Wackyracer said: Hmm... Seems some ships didn't read the forums THAT is an excellent photo. Bevan
Out2gtcha Posted February 15, 2019 Posted February 15, 2019 6 hours ago, Wackyracer said: Hey wasn't having a go at you. It was a toss up between SAA and Tubarao when I first posted which did so I got the armament set. Your post is fine. It's the next 3 jumping on as well. I'm just a bit fed up with all the negativity on these threads nowadays that's all. To be honest I may well just delete this build and the others I've doing on here. That would be a shame! I think there are a ton of people who would like to see it come together. The thing about forums is........ There are all types of people in the world, and on a world wide forum, you get exactly that, people from all over, sharing opinions, thoughts (sometimes both good and bad) and a lot of times, things seem to get misconstrued over the interwebs, when typed instead of said. Its easy to take someones meaning a different way than they meant it, and its also hard to walk away or take things in stride when someone comes off negatively. I think in those cases there are sometimes individuals that we as individuals may not jive with. I think it does happen quite often when people from all over are brought together and share thoughts on the same subject, and sometimes it does get heated or negative. For the record, I hope you dont feel that Shawn or I were trying to "pile on" here. I was simply passing on what I had learned more about from the link Stormer posted. I personally was looking forward to your build, and hope you stay and continue to share. Cheers, JefH 1
Shawn M Posted February 15, 2019 Posted February 15, 2019 absolutely, I was not trying to stir anything up or slight your build, no offense meant at all! JefH and Out2gtcha 2
Wackyracer Posted February 24, 2019 Author Posted February 24, 2019 So it begins... Excellent fit so far. Few injector pin holes that need addressing. Azgaron, Trak-Tor, BradG and 8 others 11
mgunns Posted February 25, 2019 Posted February 25, 2019 The detail looks pretty good there and looks like you're making progress. WIll be following along. Wackyracer and Out2gtcha 2
Out2gtcha Posted February 25, 2019 Posted February 25, 2019 There does seem to an astounding amount of interior detail. Does the kit comes with any nose weight or any indication if how much nose weight to add? Wackyracer 1
Wackyracer Posted February 25, 2019 Author Posted February 25, 2019 5 hours ago, Out2gtcha said: There does seem to an astounding amount of interior detail. Does the kit comes with any nose weight or any indication if how much nose weight to add? 300 grams recommended I think but none supplied. There's a couple of areas it can go. The large space behind the front wheel and the slot above/below the cockpit. Out2gtcha 1
LSP_Ray Posted February 25, 2019 Posted February 25, 2019 Good start! There is a lot of detail in that kit! I wonder how much can be seen when its all done? Wackyracer and Shawn M 2
jimbo Posted February 25, 2019 Posted February 25, 2019 Nice! Great to see some of the interior bits going in, gives us perspective. I think these kits will build up in to a veeeerrryy impressive model, I’m looking forward to your progress! jimbo Wackyracer 1
Stormer Posted February 25, 2019 Posted February 25, 2019 Beware of the width of those bulkheads. I’ve seen a few builds on Facebook where the fit between the fuselage halves leaves a lot to be desired
Wackyracer Posted March 2, 2019 Author Posted March 2, 2019 More goodies Tomorrow I should be off to my first model show of the year and track down some fibre optics lighting bits n bobs. Tnarg, Azgaron, BradG and 1 other 4
