guitarlute101 Posted January 12, 2019 Author Share Posted January 12, 2019 Thanks Alain and Ray! Mark Link to comment Share on other sites More sharing options...
Shawn M Posted January 13, 2019 Share Posted January 13, 2019 wow, sharp work and I cant thank you enough for sharing your process Link to comment Share on other sites More sharing options...
guitarlute101 Posted January 13, 2019 Author Share Posted January 13, 2019 Thanks Shawn I appreciate the feedback. I'll be starting on the upper front fuselage today so I will hopefully have an update tonight if everything goes well. Mark Link to comment Share on other sites More sharing options...
mozart Posted January 13, 2019 Share Posted January 13, 2019 Marvellous! This GB is bringing out some mind-blowing stuff already and we're only a fortnight in!! Link to comment Share on other sites More sharing options...
guitarlute101 Posted January 13, 2019 Author Share Posted January 13, 2019 Thanks Max! I've been pouring over the scale drawings, profile drawings and actual pictures for the rear of the upper front fuselage. Here is the scale drawing and I've circled the area in question...…….. It doesn't match up with pictures of the real thing, the real pictures show a gentle, tapered drop off instead of an angled one in the scale drawing to my eye. I'll have to modify the drawings to correct it. Any thoughts? Thanks, Mark BradG and BiggTim 2 Link to comment Share on other sites More sharing options...
kkarlsen Posted January 13, 2019 Share Posted January 13, 2019 Wouldn't be the first drawing with errors, go with the Photos? Cheers: Kent D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted January 13, 2019 Share Posted January 13, 2019 I would use the photos as reference first of course. The drawing is an interpretation, and perhaps those photos were not correctly studied. Alain Link to comment Share on other sites More sharing options...
guitarlute101 Posted January 13, 2019 Author Share Posted January 13, 2019 Thanks guys, my plan exactly. I've run into some other inconsistencies with the drawings but nothing too extreme, just a little modification of the measurements here and there. Mark Link to comment Share on other sites More sharing options...
guitarlute101 Posted January 13, 2019 Author Share Posted January 13, 2019 Ok, so here are the formers for the front upper fuselage. Extreme care has to be taken to make sure the formers are EXACTLY the same size and are EXACTLY level on the top and sides so everything lines up perfectly so there are no surprises and nothing to fix later on. And with the sides..... I think the best option I have for the rear section of the upper front fuselage is to vacuform it. I will work on making the wood part to vacuform over this week. I also noticed that I should not have opened up the entire cockpit section, DOH!. I will have to put the top back on the back left and right corner areas but that's no big deal. At this point, I need to do some filling and cleanup with what I have done so far. I also need to order more plastic card! Thanks for looking in! Mark BiggTim, BradG, Starfighter and 8 others 11 Link to comment Share on other sites More sharing options...
spacewolf Posted January 14, 2019 Share Posted January 14, 2019 Sweet work, clean and neat. Looking amazing !! Link to comment Share on other sites More sharing options...
Daniel460 Posted January 14, 2019 Share Posted January 14, 2019 Really enjoying this build and the craftsmanship! Dan Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 15, 2019 Share Posted January 15, 2019 Wow, that some OUTSTANDING work! Link to comment Share on other sites More sharing options...
guitarlute101 Posted January 16, 2019 Author Share Posted January 16, 2019 Thanks for the kind words guys! I appreciate the encouragement. Mark Link to comment Share on other sites More sharing options...
guitarlute101 Posted January 18, 2019 Author Share Posted January 18, 2019 Just a quick update, The fuselage is primed and everything is smoothed out nicely and I've drilled preliminary holes for the wing attachment points...………….. I'll have to add the reinforcing strips later after I've completed the rest of the upper fuselage. Thanks for looking in, Mark Trak-Tor, Starfighter, BradG and 6 others 9 Link to comment Share on other sites More sharing options...
Daniel460 Posted January 18, 2019 Share Posted January 18, 2019 Beautiful work! Dan Link to comment Share on other sites More sharing options...
