Hello Kent,
I hate to be picky, but shouldn't the undercarriage wheel hubs all be gloss black?
Beautiful work you're doing, I wouldn't want you to get beyond being able to correct the hubs if you want.
Sincerely,
Really stunning paint work :goodjob:
I also thought that Luftwaffe wheels were black, but I don't know about the specific aircraft you are doing :hmmm:
Cheers
Alex
9 hours ago, Troy Molitor said:
Most awesome looking Kent.   What tool did you use for the riveting?   Perhaps I can go back and find this in your build.
Troy
8 hours ago, alaninaustria said:
Outstanding work - what grit and type of sanding do you use? Are the rivets made with a toothed roll wheel, or with an engraving beader?
Cheers
Alan
Thanks Guy's!
I've got several different riveting tools. But for this I decided to use my 'Excel Pounce Wheel' small wheel for the riveting.
Because the Fly Kit plastic is very soft and it i easy to make marks and panel lines. I've also used my Beading tool for some of the panels incl. the removable ones.
Sanding: I've used an old worn sanding sponge, I'm guessing around 400 grit.
Cheers: Kent
8 hours ago, Kais said:
Hello Kent,
Sincerely,
Cheers
Alex
You are of cause right with the wheel color, thank you. I think I'm having some kind of 'tunnel vision' focusing on bringing this baby across the finish line ;-)
Cheers: Kent
So, after applying most of the decals and a final layer of future/Pledge, I was finally able to remove the masking tape and get sneak peek of the work.
Dark wash applied...
The wash is tying the camouflage colors nicely together. Landing gear and left engine in place, I'm seeing light at the end of the tunnel...
Cheers: Kent
8 hours ago, Trak-Tor said:
Well, it looks promising....
B)
Juraj
It does doesn't it? Now I jut have to attach all the loose parts...
Kent
Wow! Spectacular - there are so many details to take in - absolutely lovely work Kent! You’ve outdone yourself on this build!
Cheers
Alan
Thanks Alan, I really wanted to do something special with the B-2 Arado.
Kent
7 hours ago, Spads57 said:
 Kent,
WOW that's all I can say.
Highest Regards,
Gregory Jouette
1 hour ago, LSP_Ray said:
Beautiful!
Thank you ;)
Kent
