sluggo Posted April 30, 2015 Author Share Posted April 30, 2015 very nice workI for my B-2 project i let my cutter cut .5mm sheet. i can then pop out most of the parts after some cutting with an xacto blade. what cutter are you using? Summa D75R Link to comment Share on other sites More sharing options...
sluggo Posted May 1, 2015 Author Share Posted May 1, 2015 Got some more work done on this rig. Built the wing inner structure and applied the inner skin. This is a little more challenging than I anticipated. Have quite a bit of smoothing to do before the out skin can go on. I'm waiting to make an aluminum order so I have time. Inner structure. Upper inner skin attached. shbemo13, Out2gtcha, Uncarina and 4 others 7 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 1, 2015 Share Posted May 1, 2015 Impressive work already, Randy! Kev Link to comment Share on other sites More sharing options...
brahman104 Posted May 1, 2015 Share Posted May 1, 2015 Man this looks like it's going to be every bit as epic as Peter's Tigercat and Loic's F1! Right up there..... Craig Loic 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 1, 2015 Share Posted May 1, 2015 Epic! Link to comment Share on other sites More sharing options...
Barry Posted May 1, 2015 Share Posted May 1, 2015 What and awesome project and subject! Barry Link to comment Share on other sites More sharing options...
Bruce Posted May 1, 2015 Share Posted May 1, 2015 You know that ID Models made a1/32 vacform of the B-58. I'm not sure if tigger is making it or can special order make it. Bruce Link to comment Share on other sites More sharing options...
Loic Posted May 1, 2015 Share Posted May 1, 2015 (edited) Great start !!! If i may say, the thinner the card, the more flexible it is so the more complex part you can make but the more structure you need What is the thickness of the card you use? Keep it up! Edited May 1, 2015 by Loic Link to comment Share on other sites More sharing options...
sluggo Posted May 1, 2015 Author Share Posted May 1, 2015 That's all .020 styrene. I'm going to use .005 styrene and .004 or .005 aluminum sheet for the outer skin. Link to comment Share on other sites More sharing options...
Bill_S Posted May 1, 2015 Share Posted May 1, 2015 Impressive already! Link to comment Share on other sites More sharing options...
Loic Posted May 2, 2015 Share Posted May 2, 2015 Wow, 0,02 is thin for such a big surface mate brahman104 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 2, 2015 Share Posted May 2, 2015 Terrific progress and surely is going to be amazing build thread. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
sluggo Posted March 4, 2016 Author Share Posted March 4, 2016 You and me both! Been busy busy. Sorry I have not got anywhere with this. Did a bunch of remodeling on the house and got the X-plane bug...................... Link to comment Share on other sites More sharing options...
amurray Posted March 5, 2016 Share Posted March 5, 2016 You are one ambitious modeler! I look forward to this build. Link to comment Share on other sites More sharing options...
shark64 Posted March 5, 2016 Share Posted March 5, 2016 Following this Link to comment Share on other sites More sharing options...
