gerry1 Posted December 20, 2014 Share Posted December 20, 2014 I'm currently working on a Trumpeter P-38 except mine is not as detailed as yours. If I read your question right about the landing gear, that is the way the landing gear is engineered to assemble into the wheel wells. It is sturdy this way and will hold the plane after it is completely assembled. I originally filled both engines with brass BB's and I thought this alone would keep the plane from becoming a tail sitter. Wrong, I was. I extended the front gear with aluminum tube to make the plane sit higher in the front than the original part. Looks like I will have to add some more BB's in the nose. I also reinforced the area where the upper and lower wings join together and I am still having a problem with the joint "cracking" at times when I hold the plane in my hands. I don't know if this is because there is too much weight in the engines. I might have to make this a fixed diorama build so whenever I move the plane, I move the entire diorama. You have a great build going on here. Please finish the plane you don't see a whole lot of 38's on anybody's airplane forum. Jerry. brahman104 and Vandy 1 VX 4 2 Link to comment Share on other sites More sharing options...
Loic Posted December 20, 2014 Share Posted December 20, 2014 You are doing good on those LG Link to comment Share on other sites More sharing options...
dodgem37 Posted December 20, 2014 Share Posted December 20, 2014 Some serious modelling going on here. Good show, Chuck. Sincerely, Mark Link to comment Share on other sites More sharing options...
chuck540z3 Posted December 24, 2014 Author Share Posted December 24, 2014 Thanks guys! December 24. A little more progress before the Xmas break.With the landing gear almost completed, it's time to paint and assemble the gear wells before they are placed in the fuselage booms along with the engines. As mentioned above, the gear wells are fairly narrow and deep, so seeing any detail in here will be tough, even with a mirror. Using at least a hundred pics of these wells for references, I found that no two P-38's were the same and the details were all over the place. The superchargers, for one, are deleted in many restored birds and a lot of the electrical and other boxes are missing as well. These gear wells also have a lot of rivet detail, but I decided to save myself a lot of extra work that I'll never see or appreciate later by adding Archer raised rivets as I did on my A-10C build.Here's a pic of most of the right side gear well, except for the roof, which is equally devoid of any real detail and is full of seam marks everywhere. These seams are particularly hard to remove on the very small landing gear door arms, attached to the ends of the wells.I decided to go with interior green for the inside of the wells. With a BMF on the outside, the green should add some nice contrast and I believe it was the original color from the factory. I found a lot of aluminum painted gear wells, but you can see green poking through underneath. The Eduard photo-etch brass set is a real help to get the gear wells a bit more busy, including those oval access panels on the sides which are wrong on the kit parts. Right or wrong, this is how I distributed the panels according to reference pics on the left gear well in the middle, compared to the unaltered right well on the outside.Here's the main gear well parts before final assembly. I didn't go crazy with wiring or plumbing, but there are a set of hydraulic lines that go along the inside of the well that are fairly prominent, so I made something similar out of nickel plated #28 copper wire. I have several pics of the main glycol line painted blue or turquoise, so I went with that because I like the color and as a “restored birdâ€, I can do whatever I want for a change! You can see a lot of the Eduard brass details on the end walls, but I left out a couple of the main boxes, because I could not find one pic with them installed where the Eduard instructions tell you to.A rear view. A big improvement using the Eduard parts is on the roof where the tire depression is. The Eduard brass is on the correct side and oval shaped, while the kit parts just have a big circular sink hole underneath.The front. I used some more Bare Metal Matte Aluminum foil for the rings on that little tank to make them “popâ€.Hydraulic lines and the glycol pipe. For the hose clamp on the pipe, I used black electrical tape with some automotive hose clamps.I also used these automotive clamps on my P-51D, which you can see on the lower right, a trick I learned from LSP's own Wolf Buddee on his awesome Spitfire build!Oval cuts in the sidewalls are needed to feed the plumbing lines through before assembly.You also need to add the main brake line to the gear leg before you close up the side walls, which you can barely see as a black wire on the right. The only “weathering†I used was pastels to replicate some tire marks where the tire touches the depression in the roof.Another angle…. sandokan and Uncarina 2 Link to comment Share on other sites More sharing options...
chuck540z3 Posted December 24, 2014 Author Share Posted December 24, 2014 (edited) The wheels won't be installed until the end, to avoid scratching them up and also to allow some tweaking with alignment at the very end of the build, but now is a good time to figure out where that brake line should go. I also want to add a brake line clamp at the front of the scissor link, but I will wait until the end for that as well for the same reasons.Those Aires wheels are beautiful….The clearance between the scissor link and wheel is very tight on the P-38….A view from the rear, but the tire is a smidge too close to the leg.And finally, a very Merry Xmas, Hanukkah, or whatever you may celebrate at this time of year!Cheers,Chuck Edited January 24, 2015 by chuck540z3 sandokan, Uncarina and xmh53wrench 3 Link to comment Share on other sites More sharing options...
geedubelyer Posted December 24, 2014 Share Posted December 24, 2014 Clinically crisp work Chuck. It is a pleasure watching your mastery of this craft develop. Each of your models exceeds the last , regardless of what subject you choose. Magnificent work. Many thanks for taking the time to share your work. Have a very Happy Christmas and a healthy, prosperous New Year. Cheers. Link to comment Share on other sites More sharing options...
brahman104 Posted December 24, 2014 Share Posted December 24, 2014 Nice, clean work Chuck. I do love those hose clamps.... got to start doing that for my builds too! Merry Christmas, Craig Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 24, 2014 Share Posted December 24, 2014 Chuck Well done I i appreciate your common sense approach to the detailing. Keep 'em coming peter Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 24, 2014 Share Posted December 24, 2014 Lovely work Chuck, and some incredible detailing! Awesome and inspirational stuff. Merry Christmas to you and your family! Kev Link to comment Share on other sites More sharing options...
gerry1 Posted December 25, 2014 Share Posted December 25, 2014 (edited) You have done an excellent job on those wheel wells. One thing I learned is that before you glue the wells together, test fit them into their respective booms and front fuselage. I didn't do this and when I fit them into place there was a noticeable gap around the perimeter where they fit. I had to stretch the wheel wells to get rid of the gap. I ended using putty and super glue to eliminate the gap altogether. Tedious. Great build. Jerry. Edited December 25, 2014 by gerry1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted December 25, 2014 Author Share Posted December 25, 2014 Thank you everyone. I try! You have done an excellent job on those wheel wells. One thing I learned is that before you glue the wells together, test fit them into their respective booms and front fuselage.I didn't do this and when I fit them into place there was a noticeable gap around the perimeter where they fit. I had to stretch the wheel wells to get rid of the gap. I ended using putty and super glue to eliminate the gap altogether. Tedious. Great build. Jerry. Thanks for the tips Jerry. One thing I didn't mention is that I don't use ordinary plastic glue to seal the gear wells together. I gob on lots of CA glue, totally on the outside, to make sure I don't have glue marks and drips on the inside to ruin the paint job and other details. The landing gear wells fit like crap, so you need lots of support on the outside. Having said this, it looks like I'm in for some fun fitting them into the fuselage booms based upon your observations! Oh well. Trumpeter = problems to fix! Link to comment Share on other sites More sharing options...
dodgem37 Posted December 25, 2014 Share Posted December 25, 2014 Very nice, Chuck. Love your work, so clean. Sincerely, Mark Tewika 1 Link to comment Share on other sites More sharing options...
alberto49 Posted December 26, 2014 Share Posted December 26, 2014 Very nice, I will follow your work. Alberto Link to comment Share on other sites More sharing options...
chuck540z3 Posted December 26, 2014 Author Share Posted December 26, 2014 (edited) Thank you everyone! December 26, 2014I just finished the assembly of the right side gear well, which went twice as fast as the left side now that I had a plan and knew what the heck I was doing. Well, sort of....The gear wells have a lot of photo-etch and I used lots of CA glue on the outside of the gear wells, to ensure a strong bond without any glue marks or mess on the inside. This got me to thinking…..It's time for another Tutorial! As with my other tutorials, I am no expert, but I have learned a few things along the way and pass on my own personal observations.CA Gluing Made EasyWhen I first used CA glue (Cyanoacrylate) for the first time on Eduard photo-etch, it was a very frustrating experience. I got my fingers stuck together, the brass parts were covered in glue and the parts were crooked on the plastic. I dreaded using photo-etch parts for this reason, but over time, I figured out how to do it cleanly and quickly. I now love photo-etch parts and you'll always find a lot of them in my builds. Eduard photo-etch brass really “kicks up your model a notch†with super fine detail you can't mold with just plastic and resin alone.First some basics. Generally speaking, CA glue comes in three viscosities of thin, medium and thick and each viscosity has its own uses and drying times. The thin glue usually dries very fast while the thicker the glue, the slower the drying time due to less surface area of the glue being exposed to air. I never buy medium or thick glue, because over time, thin CA glue will be of medium viscosity in about a year and almost too thick for anything after a year and half. I buy thin glue only and rotate the bottles according to age, so I always have all three viscosities on hand. I've read that keeping CA glue in the refrigerator will increase its shelf life, but I go through it so much that it doesn't matter.Besides the glue itself, you will need CA glue “Accelerator†and a “Debonder†to “dry†the glue immediately or remove the glue from places you don't want it. The accelerators all work about the same. After you glue the parts, apply a bit of accelerator to the glued area with a microbrush and the glue will cure instantly. From what I've read, CA glue dries or “polymerizes†due to the attraction of water molecules in the air, which is totally the opposite of other glues where solvents within the glue evaporate. Since thinners or solvents aren't leaving the glue, it doesn't shrink, which makes it perfect for using as a filler. More on that later.The biggest discovery I have made about CA glue is that not all debonders work the same. With many debonders, the application of the solvent will make a gooey mess and doesn't quite remove all of the glue. “Great Planes Pro CA Debonder†is super strong and really dissolves the CA glue completely, but only where it is applied. Once I found this debonder, almost all of my CA gluing problems went away. It's that much better than the other debonders, including the ones made specifically for certain brands of CA glue.Before I get into gluing PE brass, you really should have two other tools to help you cut and bend the parts. The “Hold And Fold†is a great little tool to hold and bend the brass parts and the Xuron cutters are super accurate and do a much better job of cutting brass than any other tool, including scissors.Now to gluing. Depending on the application, I will use thin glue on tiny parts and thicker glues on larger parts that I might need to move around and therefore need a few more seconds to do so. The best way of applying the glue is to use a toothpick or the end of a microbrush with the brush pulled off. These brushes have a second life when the brush head is contaminated or dried with glue, they become CA glue applicators. By pulling the brush head off in an outward direction, the plastic stretches, creating a nice fine plastic tip for gluing. They are very cheap when you buy them in bulk, so you can throw them away after they are no longer usable. I also like to put a few drops of the glue into a shallow plastic cup, like the one below. While not air tight, the rim of the cup restricts the air circulation over the glue and I can sometimes keep the glue from drying for 24 hours this way, even uncovered. When I'm not gluing, I cover the cup to keep the glue thin for even longer.I like to apply the glue to area where the part is to be placed and not the part itself. That way you can control where the glue stays and place the part with tweezers without fear of the part sticking to the tweezers. Once the part is placed, give it a gentle push to distribute the glue under the part and decrease the drying time. If some glue oozes out, no worries, assuming you're dealing with just plastic and brass and not any paint. Apply some of the Great Planes debonder to a fresh microbrush and apply it to the area you want the glue removed. Wipe the area, then wipe the brush on a cloth to remove the glue from the brush, then reapply debonder and repeat until the area is glue free. If debonder gets under the part and is in contact with the glue you want to stay there, again no worries. Just let the debonder evaporate and give the glue more time to dry. The glue bond will not be compromisedDepending on the application, you may need to use an accelerator to set the glue quicker than ordinary drying times. To do this, I just load another microbrush with accelerator and let the solution touch the glue by capillary action underneath the brass part. For some very small parts, I might hold the part in place without any glue, then apply super thin CA glue to a microbrush and let it wick underneath the part from the sides. Cleanup is the same as above, using debonder.Another tip. If you're moving a part around with glue on it and it suddenly gets stuck before you're ready, you need to pull the part off and try again. The bond will never be strong, even though the glue might not be totally dry. Carefully scrape off the glue on the plastic and the brass with a #11 knife and glue it all over again.While accelerator is a great aid when using CA glue, it can also cause the glue to cure too quickly and unevenly, which creates a rough surface and air bubbles. For most applications this is not a problem and is only cosmetic, but sometimes you want the glue to stay as smooth and clear as possible, especially if it's visible. For these situations I recommend no accelerator or, at the very least, the application of accelerator nearby the glue and not directly in contact with it.You can also use CA glue to makes parts! When I was building my P-51D Mustang, I broke off the wing tip next to the aileron (almost impossible not to do at least once because it catches on everything!) as shown below: To fix it, I cut the thin part back to provide a stronger base and inserted a pin, which in this case was a strong drill bit base.I then applied a bit of CA glue to the base of the pin and let it dry with a small amount of accelerator placed on the pin.Building up the part, I applied more CA glue to the tip of the pin which dried fairly quickly with the remnants of the accelerator, then sanded the new tip to shape and added the missing rivet detail while the CA glue remained relatively soft.After re-painting, voila, the wing is as good as new! Ignore that outer panel line, which I rescribed later.I also use CA glue a LOT to fill seams, panel lines and as a general filler instead of putty. Putty has its uses, but if want to fill something quickly, without shrinkage and you want to re-scribe panel lines or reapply rivet detail, you can't beat it. Putty shrinks, takes quite a while to dry and re-scribed lines across its surface are often ragged and torn looking. The key to using CA glue as a filler, is to sand it within one hour of application while it remains relatively soft and easy to deal with. After it dries for a day or so it becomes very hard and is difficult to sand.Well, that's about it on CA glue that I can think of, but if you have any questions, fire away or maybe even offer your own experiences. We all learn from others!Cheers,Chuck Edited December 26, 2014 by chuck540z3 Jim E, Rainer Hoffmann, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted December 26, 2014 Share Posted December 26, 2014 Great work Chuck ! On my build, I used black and white shrink tubing for the hose clamps and fittings......Harv Link to comment Share on other sites More sharing options...
