Anthony in NZ Posted June 28, 2015 Author Share Posted June 28, 2015 Ok, these bomb doors have been getting quite involved. Time to start reworking the hinges. Should look like this... so I have cut the kit part back to the shape of the inner wooden piece and I have trimmed up the 2 side plates to replicate the same multi layered real part. I am going to trim it back and see how it looks. I have made both port and stbd. Once I have trimmed it back and am happy I will add the bolt detail and add the screw details to the inner 'dished' skin. I have scribed the outer doors and added a few extra details. then I can make the other 2 sets of hinges....eeeek Not much of an update, but its progress for me... Thanks for looking all Cheers Anthony Greg W 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted June 28, 2015 Author Share Posted June 28, 2015 (edited) HEY, this might work... With a bit of fine tuning and bolts?? Edited June 28, 2015 by Anthony in NZ Greg W, D.B. Andrus and Mal_Belford 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 28, 2015 Share Posted June 28, 2015 Mighty fine work, Anthony! I'm not qualified to judge it for suitability, but I'm certainly suitably impressed! Kev Link to comment Share on other sites More sharing options...
Anthony in NZ Posted June 28, 2015 Author Share Posted June 28, 2015 Thanks Kev, really appreciate that mate, especially coming from you! As much as I love this Airfix kit...and I do. In this scale some things have just got to be done, well I think they do. I am hoping it will finish up looking like Tamiya produced the kit! Well that is the aim... Link to comment Share on other sites More sharing options...
Anthony in NZ Posted June 28, 2015 Author Share Posted June 28, 2015 MARU thanks for your encouraging comment, appreciated as always mate!! Link to comment Share on other sites More sharing options...
Youngtiger1 Posted June 28, 2015 Share Posted June 28, 2015 Great attention to detail. You sure know how to do some fine work...clean!! Anthony in NZ 1 Link to comment Share on other sites More sharing options...
Mal_Belford Posted June 28, 2015 Share Posted June 28, 2015 Wow....wooow...true craftmanship...i like what i see...very much..... /Mal Anthony in NZ 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted June 28, 2015 Author Share Posted June 28, 2015 Thanks Mike and Mel! I have finished one hinge up very late last night, I drilled out all the little bolt holes and inserted fine rod to simulate the bolt heads and have glued it to the door itself. Working on the other side at present. These will form the pattern for lining up the other 2 sets of hinges to keep everything in alignment. Will post some shots of that and the ailerons tonight. Cheers Anthony Greg W 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted June 29, 2015 Author Share Posted June 29, 2015 Ok so I think this effect will work out just fine, I have glued it to the door now. Drew on the rib rivet lines and did very slight stressing of the skin. The Mosquito aileron didn't seem to get the effect like the elevators have. I doubt it will be even noticed when riveted and painted Really difficult to photograph the stressed effect... As you can see the trim tabs will also be deflected and I have reworked and boxed the inner section (cant see it in these pics) so I can add the actuating rod etc Thanks for looking D.B. Andrus and Greg W 2 Link to comment Share on other sites More sharing options...
mlcflhs Posted June 29, 2015 Share Posted June 29, 2015 looks great, especially the hinge. I need to keep it in mind. Cheers Mike Link to comment Share on other sites More sharing options...
Anthony in NZ Posted June 29, 2015 Author Share Posted June 29, 2015 OMG I have just gone mad pressing what seems like 10,000 little circles into the top skin of the port aileron..... :wacko: Thank goodness most of the aircraft is wooden!! Thanks Mike, cant wait to see your radiators mate Cheers Anthony Greg W 1 Link to comment Share on other sites More sharing options...
zak Posted June 29, 2015 Share Posted June 29, 2015 Astounding stuff Anthony! Every element is a work of art Anthony in NZ 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 3, 2015 Author Share Posted August 3, 2015 (edited) Thanks Zak Not much to report except whilst waiting for some things to set on my Zero I started whittling some plastic around the tailwheel to try and improve it without pulling it to bits.....well I ended up with many bits! So as you can see I ended up reworking the whole thing. Still a fair bit to go like the ends of the fork and the ejector pin marks and general tidy up. Thanks for looking in Cheers Anthony Edited August 3, 2015 by Anthony in NZ williamj, Mal_Belford, Greg W and 1 other 4 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 4, 2015 Author Share Posted August 4, 2015 Been fine tuning the tailwheel and getting it all tidied up, looking good. Will take pics when I get the ends of the fork finished In the meantime my good friend Kerry sent me a pic of the first test shots off my masters. You can see here the corrected and reprofiled paddle prop blade, underwing RP stubs and long carb intakes...thanks mate! As always, thanks for peeking in on this painfully slow build! Cheers Anthony Greg W, williamj and Ripaman 3 Link to comment Share on other sites More sharing options...
Monty Python Posted August 4, 2015 Share Posted August 4, 2015 As always, thanks for peeking in on this painfully slow build! Cheers Anthony Take your time with it. Coming on beautifully. Can't wait to see the finished Mossie. Anthony in NZ 1 Link to comment Share on other sites More sharing options...
