sandbagger Posted November 11, 2024 Posted November 11, 2024 (edited) Hi all, As my build of the Airco DH.2 is drawing to a close, I thought I’d start planning on a future build. The model is 1/32nd scale and 3D printed from Bjorn Carlson of ‘Flying Bear’ in Sweden. Bjorn has concentrated his research and models on the ‘Thulin’ types designed by Enoch Thulin, of ‘AB Thulinverken’. The ‘Flying Bear’ website currently has aircraft models of the Thulin N, NA, K, KA and float and ski versions of the N and K. The ski conversion for the K will also fit the Fokker D.VII. In addition, there is a refuel cart, figure, Sopwith Pup upper wing section and ski conversion for the Albatros B.II. Flying Bear web site I've not seen a build of Thulin aircraft so I’m looking to build the Thulin K, Serial No.D.3 of the Dutch Marine, 1917. The following is based on the information Bjorn has on the ‘Flying Bear’ web site. The Thulin K was a Swedish naval fighter aircraft, operated by both the Swedish and Dutch armed forces. Enoch Thulin, of ‘AB Thulinverken’, designed the Thulin K in December 1916. Sweden was not part of WW1 and neither the army nor the marine saw any reason to use anything but trainers and reconnaissance aircraft. Nevertheless, the Army Flying Corps eventually saw a need for advanced training. After initial flights in early 1917, the Swedish Army purchased two of the single seat K versions for the ‘Flygcompaniet’. However, the design was in fact obsolete as a fighter, but thanks to its low weight and good manoeuvrability it became popular among its pilots. Thulin himself broke the Swedish altitude record in it in 1919. The time between order and delivery was extremely short, mainly because the type was basically a mix of earlier Thulin types, having Thulin B wings and Thulin D fuselage. Tail surfaces were more rounded and the cowl was slightly changed. Two different set of wings were used. It was a shoulder-wing monoplane of wooden construction employing wing warping for lateral control. Powered by a 90 hp Thulin Gnôme derived rotary engine, it could be configured as a single seat or tandem seat aircraft. Initially the Type K was not equipped with ailerons, but used wing warping instead, as also on the Thulin A, B and D as well as the Fokker Eindecker. It also had a single elevator surface and no tailplane. The army, however, modified their aircraft and installed balanced ailerons and balanced elevators with a tailplane. Enoch Thulin soon followed their initiative. The modification seems to have worked out fine on the army´s aircraft, however Thulin reported severe problems with aileron vibrations in high g dives. It is a complete mystery why he continued with these manoeuvres. The loss of his right aileron on a practice flight was the cause of the crash that killed Thulin in 1919. However, the Type K was more successful as an export plane. The Royal Netherlands Navy bought twelve K single seaters and three two seaters (KA or K1) between 1917 and 1918. Both types were delivered without armament, but the Dutch Navy fitted theirs with machine guns firing through the propeller arc and also experimented with 20 mm Madson cannons. The Dutch Marine ordered a squadron of Thulin K’s and armed them with two synchronized Madsen 8 mm guns. They also performed tests with a 20 mm automatic cannon. Should be an interesting subject to build - we'll see, Mike Edited November 11, 2024 by sandbagger LSP_Kevin, Landrotten Highlander, Kagemusha and 9 others 12
sandbagger Posted February 7, 2025 Author Posted February 7, 2025 Hi all, After a delay in delivery of this kit due to damaged customs paperwork, my kit has now been delivered. As the Phonix C.I is now just waiting for its display case, I'm starting the Thulin K kit at last, Mike themongoose, scvrobeson, Out2gtcha and 3 others 6
sandbagger Posted March 2, 2025 Author Posted March 2, 2025 Hi all, As the Caproni-Pensuti (AP-1) model is complete, I've started on the Thulin K monoplane from 'Flying Bear'. The engine, like the entire kit, is 3D printed and to a high standard of detail and quality. The Thulin A rotary engine of 67 kW (90 hp) was a license-made Le Rhone 9C engine. The engine is supplied as separate parts, namely the engine block, nine cylinders, front cover with intake manifold pipes and the rear ignition slip ring. The Thulin engine was based on the French Le-Rhone 9C engine, with some differences. The most obvious difference is that the Thulin engine had inlet manifold pipes made from Aluminium casts, as opposed to soldered fabricated Copper pipes. The kit supplied propeller, although good, was replaced with an Integral propeller from 'Proper Plane'. This propeller is virtually the same as the kit propeller. Only a slight adjustment to the blade openings in the kit supplied propeller spinner was necessary to get the propeller to fit correctly. Mike Furie, Dpgsbody55, LSP_Kevin and 16 others 19
scvrobeson Posted March 2, 2025 Posted March 2, 2025 Great start on this one. How's the quality of the kit parts? Hopefully this one doesn't need the same amount of rebuilding as the C.1 did. Matt
sandbagger Posted March 7, 2025 Author Posted March 7, 2025 On 3/2/2025 at 7:22 PM, scvrobeson said: Great start on this one. How's the quality of the kit parts? Hopefully this one doesn't need the same amount of rebuilding as the C.1 did. Matt Hi Matt, As this is a 'Flying Bear' 3D printed kit, it's poles apart from the 'Kat Model' C.I. Up there with WNW and CSM I'd say, Mike Kagemusha and scvrobeson 2
dutik Posted March 11, 2025 Posted March 11, 2025 Very interesting, both this build as well as to learn about "Flying bear". Wasn't aware that they existed. Interesting kits. Earmarked the ski set for a Fokker build. Regards - dutik
sandbagger Posted March 12, 2025 Author Posted March 12, 2025 (edited) 21 hours ago, dutik said: Very interesting, both this build as well as to learn about "Flying bear". Wasn't aware that they existed. Interesting kits. Earmarked the ski set for a Fokker build. Regards - dutik Hi Dutik, I have the ski set and fuel rig from Bjorn and like his kits, they are very good 3D prints. https://forum.ww1aircraftmodels.com/index.php?topic=14766.0 Mike Edited March 12, 2025 by sandbagger dutik 1
dutik Posted March 12, 2025 Posted March 12, 2025 1 hour ago, sandbagger said: Hi Dutik, I have the ski set and fuel rig from Bjorn and like his kits, they are very good 3D prints. https://forum.ww1aircraftmodels.com/index.php?topic=14766.0 Mike Thank you for sharing the link with the photos Looks like Flying Bears kits are like WNW, but 3d instead styrene. Even the instructions look very familiar, and boxing the parts in foam is a very thought-out approach. Also great to learn about your opinion about the kits quality. I will keep an eye at acquiring a FB kit in the middle run. Regards - dutik
sandbagger Posted March 13, 2025 Author Posted March 13, 2025 Hi all, The cockpit assembly is ready to be fitted into the fuselage. Despite being careful, I still managed to snap three small parts, which I either replaced or repaired. I've rigged the cockpit bracing wires that will be seen once the cockpit is in the fuselage. Now to fit the cockpit and floor panel with controls, Mike LSP_Kevin, scvrobeson, denders and 10 others 13
sandbagger Posted March 15, 2025 Author Posted March 15, 2025 (edited) Hi all, The fuselage is now closed up. The control column needed to be moved rearwards slightly as it was fouling the cockpit frame and stopping the floor fitting into the cockpit. Also the wing warp lever assembly on the rear of the control column torsion bar was very fragile and one piece broke away. I cut it away and used 0.5 mm diameter tube (secured to the cockpit floor) to represent the cable attachments, Mike Edited March 15, 2025 by sandbagger blackbetty, denders, scvrobeson and 7 others 10
scvrobeson Posted March 15, 2025 Posted March 15, 2025 Great start to this one Mike. It looks like a nice kit Matt
sandbagger Posted March 21, 2025 Author Posted March 21, 2025 Hi all, The basic fuselage, propeller and flight surfaces are done. The fuselage: Linen covering - base coat of MRP 256 (CDL) then the internal formers masked off, Tamiya XF55 applied, masking removed and light coat of XF55 to blend. Engine cowl and panel Tamiya XF81. Wood effect Windsor and Newton Raw sienna oil paint. Weathering Flory Models Dark Dirt wash, AK Interactive Kerosene and engine oil and Mr. Color' Super Iron 2 (dry brushed). Decals kit supplied but need to be cut from sheet as not separate decals. Finish Tamiya Semi-Gloss X35. Flight surfaces essentially the same for linen, decals and weathering. NOTE - Linen colour difference between fuselage and flight surfaces are due to photograph lighting. Now its onto the weapons, windscreen and upper pylon to complete the fuselage, Mike LSP_Kevin, denders, Landrotten Highlander and 3 others 6
LSP_Kevin Posted March 21, 2025 Posted March 21, 2025 That looks fantastic, Mike! I'm especially impressed by the fabric see-through effect on the wings. Kev
sandbagger Posted March 23, 2025 Author Posted March 23, 2025 Hi all, The fuselage now has its machine guns, upper pylon, fuel cock and windscreen fitted. Also the wing and elevator top and underside rigging anchors fitted, Mike Landrotten Highlander, patricksparks, denders and 3 others 6
