68 -
Posts posted by Cajun Two One
On 12/18/2022 at 5:41 AM, Alex said:
So my question is, if you have already left your aircraft before you down the enemy plane, does that still count towards the five you need to be an ace?
A kill is a kill.
Cheers,
Itch
- BiggTim and Pete Fleischmann
- 2
"The times . . . . they are a changin'"! Hope I live long enough to see it.
Cheers
Itch.
If it is a A-20 PLEASE make it a gun nosed -G, please.
Cheers
Itch
On 11/8/2022 at 1:26 AM, Bradleygolding said:
In the latest Sprue talk, the 1/24 Spitfire designer says he has not been working on the Spitfire for over a year, but working on the next one. Presumably the next 1/24 and they all comment about how many domed rivets he has had to position.
Steve.
Sounds like a Hurricane wing to me!!
Cheers
Itch
He made the world a little bit better and brighter.
God speed.
Itch
- Lee White and Alain Gadbois
- 2
23 hours ago, Pete Fleischmann said:
Yes- built in test
I will definitely speak those words to the jet! I’ll let you know what happens!
cheers
Pete
Pete,
I think it means "Good girl"? Dobri means good.
Like you every a/c I flew had it's own personality, the one I had to eject from I could feel the sorrow and almost hear her cry.
Cheers
Itch
Excellent work. Anxious to see more of this build, always loved the Fury.
Cheers
Itch
16 hours ago, Pete Fleischmann said:
We used to say flying the
T-37 was like dating a fat girl- fun; but don’t let your buddies see you-cheers
Pete
Pig,
We used to refer to her as the 6000 lbs dog whistle or the converter - converts JP-4 to noise.
Cheers
Itch
On 10/21/2020 at 12:47 PM, wunwinglow said:
The missile knows where it is at all times. It knows this because it knows where it isn't, by subtracting where it is, from where it isn't, or where it isn't, from where it is, whichever is greater, it obtains a difference, or deviation. The guidance sub-system uses deviations to generate corrective commands to drive the missile from a position where it is, to a position where it isn't, and arriving at a position where it wasn't, it now is. Consequently, the position where it is, is now the position that it wasn't, and it follows that the position where it was, is now the position that it isn't. In the event of the position that it is in is not the position that it wasn't, the system has required a variation. The variation being the difference between where the missile is, and where it wasn't. If variation is considered to be a significant factor, it too, may be corrected by the GEA. However, the missile must also know where it was. The missile guidance computer scenario works as follows: Because a variation has modified some of the information the missile has obtained, it is not sure just where it is, however it is sure where it isn't, within reason, and it knows where it was. It now subtracts where it should be, from where it wasn't, or vice versa. By differentiating this from the algebraic sum of where it shouldn't be, and where it was. It is able to obtain a deviation, and a variation, which is called "air"
My head hurts!
Cheers
Itch
21 hours ago, Troy Molitor said:
Bucker BU 181? They had Pazerfausts on the wings .
That was it thanks TM, got my German light aircraft mixed up.
Cheers
Itch
That was really funny! Some great work there, someones excellent sense of humor and a extensive knowledge of history.
Loved it!
Cheers
Itch
- Rick Griewski and MikeC
- 2
10 hours ago, ade rowlands said:
There was no crash in the Mach Loop, the shut down of the low fly route was due to someone posting a video to social media of a pilot leaving the air space with a ‘little more flair’ than is allowed. Plus the use of the afterburners which is prohibited unless used to avoid an accident.
I don’t think anything has crashed in the specific route known as the Mach Loop. Certainly not in my living memory I was born and raised in the area. Plenty of others have crashed in the general area over the years but the only crashes I remember growing up there were a Twin seat Jaguar colliding with a little Cessna around 1991/92 on one of the specified routes into the low fly areas of North and Middle Wales and 2 Hawks colliding on the coast of Wales in the late 1980’s. again not actually in the loop itself. The Mach Loop is just a tiny fraction of Low Flying Area 7 which itself basically covers the whole of Wales.
ade,
Thanks for the correction, it jogged my now dwindling brain cells and yes it did not involve a crash. It may the Jag / Cessna event that I got confused with.
Itch
Similar incident to the crash in Whales (Mach Run?) and the RAF stood down from that flying for quit awhile. Probably the same thing will happen here. Viewing area will probably be closed to the public when it resumes operations.
Very sad news indeed.
Itch
Ivan,
Interesting, in the first picture that Phantom is the 5000th air frame produced.
An -E that would later get a blue and white celebratory paint scheme.
Cheers,
Itch
I would love to get one of those yellow Interceptors myself.
I believe there is a full scale one in the Chicago area.
Cheers,
Itch
- BloorwestSiR and Out2gtcha
- 2
Tolga,
As with the photo and the early US national insignia it would more than likely have the U.S. ARMY under the wings along with the gray underside.. HTH.
Cheers,
Itch
I know they were in the Revell Germany kit but did anyone make aftermarket markings by chance thanks u
I believe Super Scale put out a 1/48th sheet years ago with KY ANG markings for the RF-4C. SEA or wrap around scheme, can't remember which, with a red, white and blue rudder and a eagle on it.
Cheers
Itch
haha, no worries, it was a practical joke by the repair crew, they just positioned the letters with low-tack tape behind it, and were just watching me "driving away" with the car, so it was repositioned properly eventually, but the end of the story is that this particular type of car has a lot of motor management issues, but like i said i "love to hate it"....
Jack,
What sort of motor management issues did you experience? I have a 2013 LR 2 HSE (aka Freestyle in Europe), same color as yours and so far the 2.0 T has been stellar. My only problem is that it has been used as a "target" a few times.
Cheers
Itch
ICM and Airfix releases
in LSP Discussion
OH YEAAAAAAAH, X2
Cheers
Itch
