Tolga ULGUR Posted September 11, 2017 Author Share Posted September 11, 2017 The issue is a bit more complex : Hasegawa got the fuselage totally wrong. It's width is way too small. If you compare it to the Tamiya kit, you'll see what i'm talking about. So the Hasegawa canopy is, unfortunatly, also wrong in dimensions I haven t compare it with Tamiya yet, but I am sure that it s better in all ways than the trumpeter s canopy Link to comment Share on other sites More sharing options...
tomv87 Posted September 11, 2017 Share Posted September 11, 2017 Excellent start! Regards Tom Link to comment Share on other sites More sharing options...
MikeMaben Posted September 12, 2017 Share Posted September 12, 2017 ... If you compare it to the Tamiya kit, OK Vincent... do you know something 'we' don't ? Out with it ... jgrease and Nick32 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 19, 2017 Author Share Posted September 19, 2017 (edited) I tried to re create the missing details around the connection area Edited September 19, 2017 by Tolga ULGUR sandokan, Vandy 1 VX 4 and Martinnfb 3 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 20, 2017 Author Share Posted September 20, 2017 (edited) Decided to use Hasegawa s cockpit from my previous P-47 project.( Trumpeter offers corrugated floor which is not correct for D28 - M and N versions) Edited September 20, 2017 by Tolga ULGUR Vandy 1 VX 4, Kendzior, Uncarina and 5 others 8 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 20, 2017 Author Share Posted September 20, 2017 First step is the instrument panel I have used Eduard P-47M PE set and added some scracth changes to simulate "N" cockpit. No changes will be done on the sidewalls except for the oxygene hose. Gazzas, Martinnfb, MikeMaben and 3 others 6 Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted September 20, 2017 Share Posted September 20, 2017 Nice Work Tolga Martinnfb 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 22, 2017 Author Share Posted September 22, 2017 Some progess Vandy 1 VX 4, Kagemusha, tomv87 and 3 others 6 Link to comment Share on other sites More sharing options...
Troy Molitor Posted September 23, 2017 Share Posted September 23, 2017 Looking good. Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Uncarina Posted September 23, 2017 Share Posted September 23, 2017 Nice work! Cheers, Tom Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted September 23, 2017 Share Posted September 23, 2017 Nice detail set. Sincerely, Mark Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Guest Vincent Posted September 24, 2017 Share Posted September 24, 2017 Sorry, i'm talking about the 1:48 kit. When i mastered the cockpit set for the Hasegawa 1:32 P47 i was puzzled at why my reference dimensions turned always too large. Then i compared the factory drawings of the P47 with the Hasegawa cross dimensions and found the the fuselage to be way too narrow at the cocpit section. The Tamiya 1:48 kits on the other hand are spot on and since the Trumpeter kit looks like a scaled up Tamiya kit, it is also dimensionnally more accurate than the Hasegawa kit Vincent OK Vincent... do you know something 'we' don't ? Out with it ... Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 24, 2017 Author Share Posted September 24, 2017 Sorry, i'm talking about the 1:48 kit. When i mastered the cockpit set for the Hasegawa 1:32 P47 i was puzzled at why my reference dimensions turned always too large. Then i compared the factory drawings of the P47 with the Hasegawa cross dimensions and found the the fuselage to be way too narrow at the cocpit section. The Tamiya 1:48 kits on the other hand are spot on and since the Trumpeter kit looks like a scaled up Tamiya kit, it is also dimensionnally more accurate than the Hasegawa kit Vincent Wish Trumpeter scaled up also Tamiya s windscreen and canopy.. Kendzior 1 Link to comment Share on other sites More sharing options...
Guest Vincent Posted September 25, 2017 Share Posted September 25, 2017 (edited) Wish Trumpeter scaled up also Tamiya s windscreen and canopy.. I'm sorry to break the bad news but the Hasegawa canopy you used is at the wrong position in your model. It should be much more forward. Trumpeter got the proportions correct, use the access hatches for reference, you will see what i mean : Edited September 25, 2017 by Vincent/MDC Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 25, 2017 Author Share Posted September 25, 2017 I'm sorry to break the bad news but the Hasegawa canopy you used is at the wrong position in your model. It should be much more forward. Trumpeter got the proportions correct, use the access hatches for reference, you will see what i mean : Aaahh. "Wish you were here" before Vincent. Well, I see what you mean, yes you are right .Front alignment of the windscreen is 2 or 3 mm behind on the fuselage If I moved the windscreen to forward, fitting of the rear part canopy will have problem. It needs to use windscreen and canopy parts separately. And in this option, the gap between the windscreen and opened sliding canopy will be increased. So my options are: 1- Finding a separate Hasegawa windscreen, and re worked the overlap area of the windscreen, at least 1 or 1,5 mm forward. Thus error portion will be reduced. 2- To continue as it is by using the drug of "it is just 2 mm behind not too much" 3- And stopping the project Waiting for your suggestions. Martinnfb and Kendzior 2 Link to comment Share on other sites More sharing options...
