richdlc Posted January 17, 2014 Posted January 17, 2014 (edited) Hi guys - here's my latest project, the Trumpeter 1/32 A-1H / AD-6 Skyraider. This one's going to be finished as a USAF Vietnam-era machine. I was planning on finishing it as a VNAF aircraft, but then I found out that the Yankee ejection seat was removed from the majority of these machines, and as I quite fancied scratchbuilding this, I went for a US aircraft.. You may be wondering what happened to the B-26K project - well that's on the backburner for now....there is one being restored in the US, but as they are only halfway through, I don't have enough reference pics at the moment. Back to the Skyraider - the Trumpeter kit is quite accurate and detailed. It shares some of the features of the Zoukei Mura offering, but is much less complex to build. I wanted to show as much internal detail and as many open panels as possible, and I started with the engine bay - a nice guy who owns an AD4-N variant in France provided me with numerous photos. Armed with this information, I can now show the engine bay, accessory compartment, engine mount & engine itself in detail. The engine mounting bulkhead provided in the kit is quite accurate - here's a photo of the real thing compared to the kit part: more on that part later.... The oil tank is a distinctive shape - I'm hoping that its the same on all Skyraider variants (although please correct me if I am wrong): The kit's oil tank is either wrong...or I am: too late now - I've started to re-shape it: I'm guessing this is the hydraulic fluid reservoir: kit part is basic: I started to re-work & detail it - there's lot's I can't add until later on in the process, but here's where I am up to: Edited November 1, 2014 by richdlc Uilleann 1
richdlc Posted January 17, 2014 Author Posted January 17, 2014 The engine mount has a distinctive construction with many complex curves and shapes on the inside framing: Trumpeter provide the basic shape: I started to build up the internal framing to give it a more pleasing appearance - mostly hidden later, but I'm happier with how it looks now... There are little 'gills' on the outside part of the mounting ring - here's the kit representation: I removed these & replaced them with thin metal sheet: Finally for now, I had a go making the large air filter that dominates the lower inside part of the engine mount: I knew that the Trumpeter bombs and weapons provided in the kit weren't the most accurate & it was unlikely I'd use them, so I chopped up one of the larger bombs that seemed like an accurate diameter for the filter: I blanked off the ends with plastic card, then added some photoetched screen: That's it for now, more to come as I progress! Lee White and Pfuf 2
mark31 Posted January 17, 2014 Posted January 17, 2014 Looking forward to this build. I just orderd one at my local shop. Great work so far. Keep going. Mark
Sparzanza Posted January 17, 2014 Posted January 17, 2014 The artist at work again. I'll be following this build as well!
marauderdriver Posted January 17, 2014 Posted January 17, 2014 Been wanting to see this kit built. Plan mine Korean War with 2 Tiny Tim Rockets. Watching with interest Jack
Iain Posted January 17, 2014 Posted January 17, 2014 Nice one Rich - looking forward to watching this! Iain
richdlc Posted January 22, 2014 Author Posted January 22, 2014 (edited) *update 22/1/14* Time for a quick update... been working away at the engine mount. The first thing I did was to build the cradle for the air filter and attach it to the mount frame. On the real thing the filter is mounted with the top end tilted back towards the bulkhead. I think I might have made the angle a bit too steep on my version, but it's not too noticeable. Besides - it all has to jostle for space with the oil and hydraulic fluid tanks plus loads of other gizmos, all of which are built by dead reckoning - as long as I can cram it all in there I'm happy. There's also some cool little gadgets and wires on the starboard side. It's just a matter of deciding which ones I can affix now, and which ones I need to leave until later because they are either attached to the engine or disappear into the bulkhead. Bearing this in mind I added what I could right now. On the real aircraft there is a panel on each side of the mount that is left in natural metal - I replicated these with pewter sheer - rivets added with a Trumpeter riveting tool: On the port side next to the air filter is an unidentified gadget - probably some kind of pump (the black thing in the centre of this picture): The round part is attached to the engine mount - the other part has wires and stuff that attach elsewhere - I'll have to figure out where they go and make this part later. For now I made the round part and its little mount: And that's where I am up to as of last night! Stay tuned & thanks for looking Rich Edited January 22, 2014 by richdlc Harold, Uilleann and Volture 3
Guest Peterpools Posted January 22, 2014 Posted January 22, 2014 Rich Some fantastic detailing going on - sure looks mighty good Keep 'em coming Peter
Volture Posted January 22, 2014 Posted January 22, 2014 Hi Rich, Amazing job .....speachless....!!I had allready started mine Skyraider.....and you help me a lot!!! I cannot do your detail ....i havn't your skills...but i take my lessons from your job!!! Keep going mister....we are follow you!!!! Filippos
