marauderdriver Posted June 4, 2017 Share Posted June 4, 2017 (edited) Well, I've been putting this build off for as long as I could. She is part of the Wings Over Barksdale, for the museum I work at. Opened the box in August and spent DAAAAAAAAAAAAAAAY's with the heat gun. Need a 45! Put back in the box until I figured that I had no choice but to GET-RRRRRRR- DONE!! I shimmed and superglued the 2 quarter's of the fuselage together. I well take any help and suggestions on how to get this fuselage together. I'll post some picture of it when my camera battery gets charged. Edited May 16, 2018 by marauderdriver LSP_K2, BradG and johncrow 3 Link to comment Share on other sites More sharing options...
marauderdriver Posted June 5, 2017 Author Share Posted June 5, 2017 This is going to be Bery Interestink, Lots of extra plastic, CA, putty. Can I shoot foam inside to give some support? I probably will need to add bulkheads, need a contour gauge..... Thinking of using Gorilla Glue but need clamps...HELP! Taped on TOP only Link to comment Share on other sites More sharing options...
Shawn M Posted June 5, 2017 Share Posted June 5, 2017 looks like a challenge for sure! is that silver tape duct tape or some super secret tape? marauderdriver 1 Link to comment Share on other sites More sharing options...
marauderdriver Posted June 5, 2017 Author Share Posted June 5, 2017 (edited) it's DUCK TAPE! Edited June 5, 2017 by marauderdriver Lenny320 1 Link to comment Share on other sites More sharing options...
Shawn M Posted June 5, 2017 Share Posted June 5, 2017 if ya cant fix it duck it, if ya cant duck it F%K it marauderdriver, Bill_S and Michael931080 3 Link to comment Share on other sites More sharing options...
marauderdriver Posted June 5, 2017 Author Share Posted June 5, 2017 if ya cant fix it duck it, if ya cant duck it F%K it well.....PUCK-IT THEN!!! trying to figure were to start still????? jack Link to comment Share on other sites More sharing options...
kurth Posted June 6, 2017 Share Posted June 6, 2017 (edited) That is some pretty crazy warpage! I am fighting with a Anigrand C-133. I have the fuselage beat into submission, but when I assembled the wings, one of them was warped and I did not realize it until later. I have the KC-10 in my stash too. Any way on my c-133, I used a pot of almost boiling water to soften up the fuselage parts and gently bend them to where they should be, gently bent them to where they should be, then set it in place with running cold water from the tap. When I built the fuselage, I assembled the left and right forward fuselage, and the left and right aft fuselage. Once those halves were set, the forward and aft halves were joined. I guess I would slowly work one section at a time with heat until it is to the point you can finish it up with putty. Good luck. Edited July 23, 2017 by kurth Link to comment Share on other sites More sharing options...
marauderdriver Posted June 27, 2017 Author Share Posted June 27, 2017 Like a bad penny, I'm BAAAAAACK!!!! Been working in small adjustments with the heat gun, Boogered -up a spot on the bottom,Also been busy with life for a couple weeks. I decided that I needed to get this fuselage together, so I started on the top middle at the 4-corners and worked forward for in 1 to 2 inches and started the bottom and worked forward. CA is working great and the fuselage is pretty sturdy. Plan to insert brass tube wing spars to take the strain off the spine ​ Girlscanplay2 1 Link to comment Share on other sites More sharing options...
marauderdriver Posted June 27, 2017 Author Share Posted June 27, 2017 Did Y'all notice the Area-Rule on the foward fuselage? Girlscanplay2 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted June 27, 2017 Share Posted June 27, 2017 (edited) I have noticed a HUGE Rat from another dimension, Awesome ! Edited June 27, 2017 by Martinnfb Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 27, 2017 Share Posted June 27, 2017 Nice locomotive you are busy on as well marauderdriver and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted June 29, 2017 Share Posted June 29, 2017 I think that this one might be less fuss all around. Lee White, marauderdriver and Out2gtcha 3 Link to comment Share on other sites More sharing options...
phasephantomphixer Posted June 29, 2017 Share Posted June 29, 2017 I think that this one might be less fuss all around. Certainly a sweet kit, but already have the Anigrand - will they take a trade in? lol Out2gtcha and marauderdriver 2 Link to comment Share on other sites More sharing options...
marauderdriver Posted July 8, 2017 Author Share Posted July 8, 2017 Well, been busy and been grinding CA and resin with 320 to rough in to shape. Have several spots that are built up CA to fill the low spots and short rear fuselage. Those who know me know I have a real eversion to putty. I prefer CA as it is smoother. and easier to scribe IMHO. LSP_Paul 1 Link to comment Share on other sites More sharing options...
marauderdriver Posted July 8, 2017 Author Share Posted July 8, 2017 More coming Link to comment Share on other sites More sharing options...
