AlbertD Posted September 26, 2022 Share Posted September 26, 2022 I have my Tamiya Birdcage Corsair gathering dust on the shelf. I used chipping fluid but it's way overdone and I don't like the way it looks. I did a layer of aluminum and chipping fluid then a layer of zinc chromate primer with chipping fluid then color coat. I was thinking of just doing a bit of light sanding and re-paint the areas. Is this my best approach? Link to comment Share on other sites More sharing options...
JeepsGunsTanks Posted September 27, 2022 Share Posted September 27, 2022 (edited) Can you really go overboard on a Birdcage? They got really beat up in the Solomons! Edited September 27, 2022 by JeepsGunsTanks AlbertD 1 Link to comment Share on other sites More sharing options...
nmayhew Posted September 27, 2022 Share Posted September 27, 2022 it would be easier to understand with some pictures these things did get very beat up so providing it looks right, and is in the right areas, you'd be surprised with what will pass LSP_K2, AlbertD, daveculp and 2 others 5 Link to comment Share on other sites More sharing options...
Confusionreigns178 Posted September 27, 2022 Share Posted September 27, 2022 I've read that a lot of Pacific landing-strips were made out of crushed coral. When an aircraft's propeller got it flying around, it acted like very coarse sandpaper and reduced exposed areas of the planes to a nearly-naked state. Is the chipping as "bad/overdone" as you're thinking? I also read that the Japanese fighters had paint dropping off in big clumps, mainly due to the very poor-quality paint used and the "sand-blast" effect of flying coral pieces. Cheers. Chris. JeepsGunsTanks and AlbertD 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted September 28, 2022 Share Posted September 28, 2022 chrish, AlbertD and daveculp 2 1 Link to comment Share on other sites More sharing options...
AlbertD Posted September 29, 2022 Author Share Posted September 29, 2022 (edited) Here are a couple of pictures. Now that I look at it after all these months it may not be too bad. Edited September 29, 2022 by AlbertD chukw, Martinnfb, nmayhew and 2 others 4 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted September 29, 2022 Share Posted September 29, 2022 chukw and AlbertD 2 Link to comment Share on other sites More sharing options...
AlbertD Posted September 29, 2022 Author Share Posted September 29, 2022 1 minute ago, Martinnfb said: That's a great photo. I have not seen it before in my research. It definitely has some wear to it, Link to comment Share on other sites More sharing options...
MikeMaben Posted September 29, 2022 Share Posted September 29, 2022 Hi Al, I'd sand/feather the areas lightly with fine sand paper and repaint. AlbertD 1 Link to comment Share on other sites More sharing options...
nmayhew Posted September 29, 2022 Share Posted September 29, 2022 13 hours ago, AlbertD said: Here are a couple of pictures. Now that I look at it after all these months it may not be too bad. ok i see what you mean it's not that these Corsairs weren't chipped to hell, but that just looks quite 'clumsy' the amount of chipped area is too great, but for me the killer is that it's basically one or two giant chips that just look like a map Westeros over the wing the trick is to aim for lots and lots of mini chips, albeit some are just quite close together if that was me i would indeed do over - the wing bend line is a natural starting point for a complete repaint, and that way you keep the rest of the model intact i would also use hairspray rather than chipping fluid, but that's just me best of luck! AlbertD 1 Link to comment Share on other sites More sharing options...
AlbertD Posted September 29, 2022 Author Share Posted September 29, 2022 16 hours ago, MikeMaben said: Hi Al, I'd sand/feather the areas lightly with fine sand paper and repaint. That sounds like a good way to go. Aside from the chipping I'm pretty happy with the model. MikeMaben 1 Link to comment Share on other sites More sharing options...
AlbertD Posted September 29, 2022 Author Share Posted September 29, 2022 6 hours ago, nmayhew said: ok i see what you mean it's not that these Corsairs weren't chipped to hell, but that just looks quite 'clumsy' the amount of chipped area is too great, but for me the killer is that it's basically one or two giant chips that just look like a map Westeros over the wing the trick is to aim for lots and lots of mini chips, albeit some are just quite close together if that was me i would indeed do over - the wing bend line is a natural starting point for a complete repaint, and that way you keep the rest of the model intact i would also use hairspray rather than chipping fluid, but that's just me best of luck! When I re-do it I'll try hairspray. Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 29, 2022 Share Posted September 29, 2022 Many Corsairs got thoroughly trashed in their appearance. AlbertD 1 Link to comment Share on other sites More sharing options...
Woody V Posted September 30, 2022 Share Posted September 30, 2022 In my humble opinion, most wartime photos show a lot more filth and grunge than chipping. It's easy to overdo chipping but not grunge. Grunge, not chipping, is the challenge. LSP_K2, TAG, AlbertD and 2 others 5 Link to comment Share on other sites More sharing options...
KUROK Posted October 5, 2022 Share Posted October 5, 2022 Actually your chipping looks fine if the rest of the aircraft gets weathered too. The other areas look too clean that's why it stands out so much. AlbertD 1 Link to comment Share on other sites More sharing options...
