dennismcc Posted September 9, 2021 Share Posted September 9, 2021 The nose on the SH Tempest is reputably all wrong so I would not use it on your hybrid, there is a Barracuda replacement for it though. The canopy (Revell) on mine was a bit challenging to get a good fit took quite a bit of adjustment, sanding and shaping. Later Typhoons did have the Tempest tail, probably not applicable to your subject though. I did re scribe my Revell Typhoon and it came out well, for this I used Dymo tape and a Bare Metal Foil scriber, with templates from Lion Roar, mistakes, and there were a few were fixed using CA but do not let it go hard as it sets harder that the plastic. Cheers Dennis Panzerwomble and MikeC 2 Link to comment Share on other sites More sharing options...
Panzerwomble Posted September 9, 2021 Author Share Posted September 9, 2021 54 minutes ago, dennismcc said: The nose on the SH Tempest is reputably all wrong so I would not use it on your hybrid, there is a Barracuda replacement for it though. The canopy (Revell) on mine was a bit challenging to get a good fit took quite a bit of adjustment, sanding and shaping. Later Typhoons did have the Tempest tail, probably not applicable to your subject though. I did re scribe my Revell Typhoon and it came out well, for this I used Dymo tape and a Bare Metal Foil scriber, with templates from Lion Roar, mistakes, and there were a few were fixed using CA but do not let it go hard as it sets harder that the plastic. Cheers Dennis Thanks Dennis - I remembered some of the nose shape issues from Chuck's build a little while ago . I don't think I'm minded to get the Barracuda nose, one of the ideas with this was to see how far you can get on just the two kits , perhaps as opposed to throwing down for every after market goodie. Link to comment Share on other sites More sharing options...
Panzerwomble Posted September 9, 2021 Author Share Posted September 9, 2021 (edited) Looking at the two side by side , there is about 40 years between them ! Big chunky detail for 1973, lighter recessed for 2020 . The rivet patterns seem similar though so hoping with a bid of sanding 1973 might not look too bad. Interior is a similar tale And check out the tapes on this stab' ....scales they are 15mm / half and inch high , also not sure the fishplates mod were on my target aircraft when the pics were taken in 1943. Edited September 9, 2021 by Panzerwomble Sepp, LSP_Kevin, Landrotten Highlander and 3 others 6 Link to comment Share on other sites More sharing options...
Panzerwomble Posted September 9, 2021 Author Share Posted September 9, 2021 Moving on , I like this old style of instructions . In good old English , not some IKEA'esque pictogram nonsense . It gives a bill of materials , an assembly schedule and a clear drawing , heck it's almost like engineers were involved . And so following we get this , although this is not what will be in the model . Not too shabby for the era, and if a fella were inclined no doubt could be improved upon a heap . BradG, MDuv, KiwiZac and 6 others 9 Link to comment Share on other sites More sharing options...
Panzerwomble Posted September 9, 2021 Author Share Posted September 9, 2021 And so the the engine , again only an approximation , and none of this will be visible , it's just to hold the prop and the exhausts for me . It even fits in the fuse straight . Sepp, Landrotten Highlander, BradG and 2 others 5 Link to comment Share on other sites More sharing options...
Panzerwomble Posted September 9, 2021 Author Share Posted September 9, 2021 Talking of straight, this old mould is displaying a fair amount of flashing , and some warping of the final parts, this engine cover for example . Not insurmountable .........but of you found this on a modern kit you'd been feeling miffed.....or actually if it were on the Revell FW190 where most of the engine covers fit badly .......very miffed. DZUS fasteners look nice but I suspect they are over scale and should all face one direction . BradG, simmerit, Landrotten Highlander and 6 others 9 Link to comment Share on other sites More sharing options...
Panzerwomble Posted September 19, 2021 Author Share Posted September 19, 2021 I should rename this project lipstick on a pig........ So banged the wings together and toned down the rivets a bit . Fit is ok , and the wing root looks like it should go together without much drama . No idea what this landing light "detail" is supposed to represent nothing goes in here , it's just an odd hole .....some detailing needed here fo shure . And although the fuse is kinda straight the nose is like it's been through a few rounds with Mike Tyson . themongoose, BradG and Landrotten Highlander 2 1 Link to comment Share on other sites More sharing options...
Panzerwomble Posted September 19, 2021 Author Share Posted September 19, 2021 Next "treat especial" is the cockpit first fit Looking at various pics, and downloading Airfix 1/24 plans , I've been working out where this all fits together . Interestingly the Tempest rear frame fits the profile of the Typhoon fuse like a glove which is encouraging . Next stage, build the cockpit, and see how it ll fits with the engine and rad. Typhoon cockpit in fuse Tempest Cockpit in Typhoon . dennismcc, Landrotten Highlander, Alain Gadbois and 5 others 8 Link to comment Share on other sites More sharing options...
dennismcc Posted September 20, 2021 Share Posted September 20, 2021 Looking good so far, it's a good sign that the fuselages seem to match for the rest of the hybrid parts. Cheers Dennis Panzerwomble 1 Link to comment Share on other sites More sharing options...
Panzerwomble Posted October 4, 2021 Author Share Posted October 4, 2021 Hmm confession time . I'm putting this project down, and back in my "healing cupboard " as I don't have a shelf of doom per se I feel a bit rubbish as the other person doing this build did the same thing last year. It's a great idea to get a 1/32 Tiffy . In honesty- modelling been my third priority since May , I'm struggling to get into this build , partly as I have a lack of references ( another nonsense- I just CBA to research more) and although I could throw it together for the purposes of calling it done , since I'm using two kits to make one (££££) I feel I should do it some justice rather than bang it all together for the sake of it . I'm not a huge fan of SODing models , hopefully will circle back around to it next year. I the meantime will do some non LSP subjects closer to heart to get some mojo back . Laters PW Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
Panzerwomble Posted October 4, 2021 Author Share Posted October 4, 2021 @MARU5137 Thank you, that is kind of you . Link to comment Share on other sites More sharing options...
BradG Posted October 9, 2021 Share Posted October 9, 2021 Nevermind, we all hit blocks at times, you might come back to it. Link to comment Share on other sites More sharing options...
RLWP Posted November 19, 2021 Share Posted November 19, 2021 Would you like some more lipstick? Richard Link to comment Share on other sites More sharing options...
logan181 Posted November 20, 2021 Share Posted November 20, 2021 The Revell typhoon can be conquered. The base kit has the right stuff to start out with. Here is a link to my attempt at it. I hope this helps you in your efforts. If you have any questions please feel free to ask. John Link to comment Share on other sites More sharing options...
Panzerwomble Posted November 22, 2021 Author Share Posted November 22, 2021 On 11/20/2021 at 9:22 AM, logan181 said: The Revell typhoon can be conquered. The base kit has the right stuff to start out with. Here is a link to my attempt at it. I hope this helps you in your efforts. If you have any questions please feel free to ask. John Sadly it's less a case of "can it be conquered " more "can I be assed ". Landrotten Highlander and logan181 2 Link to comment Share on other sites More sharing options...
