dutik 4,291 Posted August 31, 2020 Share Posted August 31, 2020 (edited) I'm in (again ) This was the WARPAC aerial tow target during Mig-15 times. Some kind of small aircraft to be towed behind a Mig-15 with specialized towing equipment (winch, emergency wire cutter and that stuff). No electronics, just a metal body to shoot at (the drone, not the Mig ). Hits got simply counted by hand after recovery of the target. This aerial target was surprisingly large, so it had to be replaced by a new type (the KT-04) when the L-39 stepped in after retirement of the Mig-15s. Technical data provided by Profimodeller: Constructed in the years 1957-1959, manufactured 1961-1970. The target is a metal with square section, covered with duralumin sheet. Start is performed on a three-wheel chassis. In front of the body is a shock absorber for landing by parachute, which is stored at the rear. Length: 6.65 m Wingspan: 7 m Take-off weight without chassis: 112 kg The total weight of the chassis: 267 kg Max. towing speed at 6000 m: 780 km/h Length of start: 1600 m Regards - dutik Edited August 31, 2020 by dutik Landrotten Highlander, LSP_Kevin, Erwin and 8 others 11 Link to post Share on other sites
dutik 4,291 Posted September 5, 2020 Author Share Posted September 5, 2020 Inside the sturdy box are: - two bags of resin parts for the trolley and the core of the KT-03 - two bags of metal and styren rods, some string ans a decal sheet - four massive PE frets - instructions (not at the photo) The first task is to build up the inner framework from resin parts, then to clad them with large PE parts that also need to be bent somewhat... Interesting times Regards - dutik Landrotten Highlander, BradG, mgbooyv8 and 3 others 6 Link to post Share on other sites
MARU5137 15,919 Posted October 27, 2020 Share Posted October 27, 2020 - dutik, Like your background history to this aircraft. Nice to know . thank you looking forward to your build. Link to post Share on other sites
MARU5137 15,919 Posted November 11, 2020 Share Posted November 11, 2020 how goes it? Link to post Share on other sites
dutik 4,291 Posted January 8 Author Share Posted January 8 Just plain PE sheets, some resin strips and metal rods. Feels like building a paper model. A number of flat parts to be formed into something threedimensional... The central cage is the very core of the whole thing. Take your time to get it right-angled ans square in all directions, or otherwise the whole fuselage will become crooked forever. The outer shell are just 4 large PE pieces, so there is no way to correct bent shapes with some putty and paint. I diverted from the instructions that want you to build the fuselage frame first. But there are no alignment pins or other supports, so there is the risc of misalignment, or simply that your frame is too wide or too narrow to accept one or more of the PE sheets. so I've glued at first one fuselage side onto the central frame core, then glued the parts of the framework onto the inner shell face. Also added some strip styrene to get larger contact surfaces for the other PE. Regards - dutik LSP_Kevin, MARU5137, mgbooyv8 and 4 others 7 Link to post Share on other sites
MARU5137 15,919 Posted January 8 Share Posted January 8 Super update. Thank you much luck. Link to post Share on other sites
dutik 4,291 Posted January 9 Author Share Posted January 9 Take your time and dryfit, dryfit, dryfit. Had to sand off a bit here and to shim with strip styrene there. Added some substatial styrene strips behind the wingroots. The original resin strips are much to week to support the wings. Also added spacers and bulkheads where the furselage sides tended to bent inwards. Nonwithstandig all the dry fittting I had to partially cut off one PE sheet to sand down the frame underneath. And the top sheet does not fit. There is somewhere a bend into my build. Have to think about how to fix this to get the fuselage closed. The companies name "Profimodeller" has a serious meaning. Just saying... Regards - dutik mgbooyv8, MARU5137, LSP_Kevin and 5 others 8 Link to post Share on other sites
dutik 4,291 Posted January 10 Author Share Posted January 10 Congratulations, it's a fuselage: Front is facing to the right, rear to the left. Thats it for the next days. All the etched lines have to be covered with triangular profiles, but these profiles are not provided with the kit. Not very professional, Profimodeller I've ordered a fistful of styrene profiles from Ebay, but delivery might take two days or three. Also ordered square profiles of different size as inserts for wings and rudder. There are PE parts for the wing ribs, which are OK, but I want to use something more solid to get the wings straight and even. Meanwhile started to cut resin for the trolley to go on with the build. BTW, this one is surprisingly large: Close to the size of a Texan/Harvard... Regards - dutik Landrotten Highlander, denders, Alain Gadbois and 8 others 11 Link to post Share on other sites
mgbooyv8 944 Posted January 10 Share Posted January 10 (edited) Wow, that's for the real Profi-modeller! Good job with an unforgiving medium. Indeed not very profi to omit the prominent ridges on the fuselage in the kit . Interesting to show the tow target with a Texan...it is large! Keep up the good work. Cheers, Peter Edited January 10 by mgbooyv8 typos dutik and MARU5137 2 Link to post Share on other sites
MARU5137 15,919 Posted January 15 Share Posted January 15 Super duper workmanship. Link to post Share on other sites
dutik 4,291 Posted January 19 Author Share Posted January 19 (edited) Started the trolley. While the real thing was made from sturdy steel tubes is the model trolley made from wobbly resin parts. Fit was not the best, some struts were misaligned, some too short, some simply broken off. So I've replaced some struts with styrene rods (1,6mm) and added wire pins to all joints to get a straight, sturdy and stressfree structure. Just take your time. This is the rear part. The front part is angled upwards and made of more resin parts. Alignment might be a bit challenging, but I have an idea how to get all things straight together. Still waiting for the styrene strips to build up the wings of the target. Thats life Regards - dutik Edited January 19 by dutik Landrotten Highlander, Alain Gadbois, Out2gtcha and 3 others 6 Link to post Share on other sites
Out2gtcha 35,957 Posted January 19 Share Posted January 19 Excellent work, very deceptive in size dutik 1 Link to post Share on other sites
dutik 4,291 Posted January 20 Author Share Posted January 20 By a long shot not as complicated as your Tigercat. But thank you for the heads-up Of course my kit has some problems of it's own. The one-piece PE for the wings has to be bend inwards; but the etched-in bending lines are all at the outside. You are supposed to make 4 exact bendings per wing without any markings. Very interesting stuff Regards - dutik Link to post Share on other sites
dutik 4,291 Posted February 1 Author Share Posted February 1 (edited) Made the rudder (mostly): Just a dryfit. Ignore the glue smears which will be removed soon. This is a sandwich: The shell is just a large PE part with inner PE ribs. I've added strip styrene inside to augment the small ribs and to save the rudder from getting smashed just by touching it. Thickness of the styrene inserts is 2,75mm, aka 2,5 and 0,25 mm strip glued together. Small problem here: The halfround 3mm styrene strip from the box is just a bit to narrow to cover the front of the rudder. So I have to wait for the delivery of some Evergreen 3,2 mm halfround profiles. Not a biggie: Meanwhile there are waiting two fullsize PE parts to be bend into a wing shape... Regards - dutik Edited February 2 by dutik LSP_Kevin, Landrotten Highlander, mgbooyv8 and 4 others 7 Link to post Share on other sites
dutik 4,291 Posted February 6 Author Share Posted February 6 Building a wing: Poor image, but you get the idea: Anything golden are kit parts. The shell and 3 tiny ribs. Not sufficient enough to keep the PE shell in shape. I've added 4mm square strip styrene fore and aft and a styren tube amidst to hold the crossrod from the fuselage. Well, how do you glue a large PE part that still has to be folded down? In hindsight I should have used twopart epoxy, but I have no epoxy at hand. First idea was to fold the upper part down, fill the gap with thin superglue and hold the whole thing down until the glue had cured, but it didn't work. For some reasons the superglue did not bond. The second try was using super slow drying, gap-filling superglue, aka the "black slow dry" by Ammo of Mig. I smeared a good amount into the gap, using a toothpick, then pressed the whole wing down using a wooden slat - and this worked. Worked better than expected - I had to cut off the wing from the working desk too and to remove a lot of glue spill. So we have one wing now. Dryfit onto the fuselage: Still lacking the frontal halfround styrene strip but it is fine. Maybe I will tackle the other wing tomorrow. Or go on with a simpler task for now - like adding the triangular profiles along the etched lines at the fuselage. We shall see. Regards! - dutik mgbooyv8, Landrotten Highlander, LSP_Kevin and 2 others 5 Link to post Share on other sites
