AlbertD Posted August 13, 2020 Author Share Posted August 13, 2020 5 hours ago, vvwse4 said: Looking good!! Will you use the kit's variable intake ramps, aka splitter plates, or do you have aftermarket for those. I see that one of the connection strips broke off with your build also. Look forward to more! Rick Thanks Rick, The resin intakes came with a set of intake ramps. I will be using those. Link to comment Share on other sites More sharing options...
AlbertD Posted August 14, 2020 Author Share Posted August 14, 2020 I don't know if this is the best solution to separating the horizontal stabilizers but it's what I came up with and seems to work ok. Whitey, scvrobeson, Landrotten Highlander and 10 others 13 Link to comment Share on other sites More sharing options...
AlbertD Posted August 15, 2020 Author Share Posted August 15, 2020 I've been working on fitting the Aires cockpit tub to the fuselage and can't see where I'm going wrong. It fits in the upper fuselage like a glove but after grinding the bottom of the tub so much I can see light through it the bottom fuselage won't fit well. I know it's snagging on the inside of the wheel well and I've taken off the resin part about as much as I dare. I can get it to close up but it takes a bit of force to squeeze together. Will this be OK or should I keep trimming? Do you guys have any suggestions? Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 15, 2020 Share Posted August 15, 2020 5 hours ago, AlbertD said: I've been working on fitting the Aires cockpit tub to the fuselage and can't see where I'm going wrong. It fits in the upper fuselage like a glove but after grinding the bottom of the tub so much I can see light through it the bottom fuselage won't fit well. I know it's snagging on the inside of the wheel well and I've taken off the resin part about as much as I dare. I can get it to close up but it takes a bit of force to squeeze together. Will this be OK or should I keep trimming? Do you guys have any suggestions? Hmmm, I would like to help, especially as I will be using the Aires pit too. Can you take a couple of pics so I can see what the issue is and we can see if we can find a solution? Link to comment Share on other sites More sharing options...
vvwse4 Posted August 15, 2020 Share Posted August 15, 2020 10 hours ago, AlbertD said: I've been working on fitting the Aires cockpit tub to the fuselage and can't see where I'm going wrong. It fits in the upper fuselage like a glove but after grinding the bottom of the tub so much I can see light through it the bottom fuselage won't fit well. I know it's snagging on the inside of the wheel well and I've taken off the resin part about as much as I dare. I can get it to close up but it takes a bit of force to squeeze together. Will this be OK or should I keep trimming? Do you guys have any suggestions? Hi Albert, Had the same problem. Kep grinding the top of the wheel well to get that one as thin as possible. The wheel well is think enough so grinding there is not a problem. I Also pay attention to the backside of the tub and the kitpart, and I cutted off the parts where you would screw the tub to the fuselage and removed the part where the refulling probe was placed. I spended quite a lot of time, force and CA glue in the end too get that one fixed. Hope this helps. Rick AlbertD 1 Link to comment Share on other sites More sharing options...
AlbertD Posted August 15, 2020 Author Share Posted August 15, 2020 9 hours ago, Anthony in NZ said: Hmmm, I would like to help, especially as I will be using the Aires pit too. Can you take a couple of pics so I can see what the issue is and we can see if we can find a solution? 4 hours ago, vvwse4 said: Hi Albert, Had the same problem. Kep grinding the top of the wheel well to get that one as thin as possible. The wheel well is think enough so grinding there is not a problem. I Also pay attention to the backside of the tub and the kitpart, and I cutted off the parts where you would screw the tub to the fuselage and removed the part where the refulling probe was placed. I spended quite a lot of time, force and CA glue in the end too get that one fixed. Hope this helps. Rick I have not even put the Aires cockpit together yet. I am just trying to fit the bare tub. Here are pictures of what I have removed so far. Starfighter, F`s are my favs, Derek B and 1 other 4 Link to comment Share on other sites More sharing options...
Landrotten Highlander Posted August 15, 2020 Share Posted August 15, 2020 I would not go any further on the tub either. Perhaps the wheel bay is your next sanding target as suggested above? AlbertD 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 15, 2020 Share Posted August 15, 2020 Oh ok, well as the others say, move to the wheel well top. Thanks for the photo's and pre warning. At this stage I cant offer much more than the others. Might get my cockpit tub out and see what I can do... Link to comment Share on other sites More sharing options...
AlbertD Posted August 15, 2020 Author Share Posted August 15, 2020 Did a bit more fitting and after taking off a bit more material from the bottom of the tub and the top of the wheel well (see marked area) it fits better. I think it's good to go now. Like Rick said above it will probably need some fitting around the inside of the fuselage once the side are on the cockpit. On a side note, the resin components of the Aires cockpit are really nice. They look great and go together perfectly. MikeMaben, johncrow, Anthony in NZ and 4 others 7 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 15, 2020 Share Posted August 15, 2020 Thanks very much for the helpful advice AlbertD 1 Link to comment Share on other sites More sharing options...
AlbertD Posted August 15, 2020 Author Share Posted August 15, 2020 3 minutes ago, Anthony in NZ said: Thanks very much for the helpful advice My pleasure. Anthony in NZ 1 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted August 16, 2020 Share Posted August 16, 2020 Albert, that's some great progress and wealth of information! I will be following with great interest! Just keep in mind that the Eduard exhausts are undersized unfortunately. Best to try and find a pair of Sierra Hotel or GT resin exhausts which have the correct diameter for the Tamiya kit. AlbertD 1 Link to comment Share on other sites More sharing options...
AlbertD Posted August 16, 2020 Author Share Posted August 16, 2020 10 hours ago, spyrosjzmichos said: Albert, that's some great progress and wealth of information! I will be following with great interest! Just keep in mind that the Eduard exhausts are undersized unfortunately. Best to try and find a pair of Sierra Hotel or GT resin exhausts which have the correct diameter for the Tamiya kit. Thank you. I am aware that the Eduard exhausts are undersized. I think the Sierra Hotel parts are almost impossible to get right now. I will look into the GT set though. As far as the Eduard goes they are pretty close and do have nice detail. They made them the same diameter as the kit parts so they must be undersized too. Makes me wonder where they all fell short in the design. I guess they copy mistakes. Link to comment Share on other sites More sharing options...
AlbertD Posted August 18, 2020 Author Share Posted August 18, 2020 Just a quick update. The Aires cockpit is about ready to fit into the fuselage. I'm pretty happy with the way it looks. Looking at pictures of the real thing the buttons and knobs tend to be pretty subdued so that is what I went for. I didn't want them to be too bright though being in the dark recesses it might have been the better way to go. Should be able to close it up tomorrow. F`s are my favs, vvwse4, Greg W and 14 others 17 Link to comment Share on other sites More sharing options...
vvwse4 Posted August 19, 2020 Share Posted August 19, 2020 Hi Albert, Looking good from where I am!! Rick AlbertD 1 Link to comment Share on other sites More sharing options...
