nmayhew Posted May 25, 2020 Posted May 25, 2020 hi all, I am using HGW's seatbelts for the first time and although they are fiddly to make, the detail is better than anything i have seen in photo-etch or resin however... the belts are still quite springy and, unlike photo-etch, if you bend them into shape they just tend to spring back any ideas on how to get around this? the belts are glued together with PVA / Gator Grip glue, so anything water-based will be a no go. Kind regards, Nick
nmayhew Posted May 26, 2020 Author Posted May 26, 2020 7 hours ago, Jennings Heilig said: Mousse? Gel? ironically Jennings that may actually be worth investigating!
Wackyracer Posted May 26, 2020 Posted May 26, 2020 Did you remove the backing tape? I made this error on my first ever set a few years back. I normally roll the belts in my fingers before assembling also. Folds etc are superglued with a tiny blob. and once installed a weak filter type wash is applied which I find makes the fall into place. nmayhew, Lothar and Landrotten Highlander 3
BaldEagle Posted May 26, 2020 Posted May 26, 2020 I remember making the same mistake with the backing film the first time I used them. The trouble with crumpling them up is that it makes it very difficult to thread through the buckles.
nmayhew Posted May 26, 2020 Author Posted May 26, 2020 yes, i have removed the backing tape (!) but thank you the Fw190 belts look sweet!
chrish Posted May 26, 2020 Posted May 26, 2020 I've had great success with "Micro Liquitape" It's kind of like a contact cement of some kind. Brushes on white dries clear and doesn't affect the stiffness of the belts. If unhappy with the lay they are easily (relative to normal glue) moved to another location. I've got several models with seatbelts fastened in that way now, some for many years. I can even put the glue on before threading the buckles etc. then fold them over, squeeze with a tweezers and they stay stuck. Not saying it's the only way to go, but it's the way for me. CANicoll and D.B. Andrus 2
Wackyracer Posted May 27, 2020 Posted May 27, 2020 17 hours ago, nmayhew said: yes, i have removed the backing tape (!) but thank you the Fw190 belts look sweet! No worries, I thought that may be the reason for the springiness that's all. I'm sure I read somewhere when constructing someone removed the fabric parts but left the pe buckles on the fret to make it easier to thread on. It makes sense as you have more to hold onto. Not relevant to your question, but may ease construction. I'll try it with my next set. I've had another thought... would white spirit or a very weak filter wash help soften them up. Would WS not attack the gator grip, much like it doesn't acrylics? Just a thought. Aaron
thierry laurent Posted May 28, 2020 Posted May 28, 2020 Two tips: If possible, put the belts in the buckles before removing them from their fret. Crumple the belts after assembly or part of it. Hth Thierry Reuben L. Hernandez 1
nmayhew Posted May 28, 2020 Author Posted May 28, 2020 1 hour ago, thierry laurent said: Two tips: If possible, put the belts in the buckles before removing them from their fret. Crumple the belts after assembly or part of it. Hth Thierry Thank you Thierry. I have actually found assembly ok yes it's quite teeny weeny but as you say, if you can keep as much of the PE buckles on the fret and then thread the belt in whilst they are being 'held' it's actually not that bad similarly, white glue (PVA / Gator) sticks the flaps together after just a second or two of holding i will try some crumpling and let you know how it goes if it comes apart i guess i can just glue it back together again! cheers Nick PS P-47 comparison HGW vs Radu's set: HGW is waaaay easier to assemble, but less detailed PE pieces and also less detailed diagram; the RB instructions show you exactly how the real thing fit together, whereas HGW is just a representation that being said, i put the RB set straight back in its bag once i saw the PE construction - it was real shipbuilding stuff in my book - no interest!
thierry laurent Posted May 28, 2020 Posted May 28, 2020 To me the most complicated one to assemble is the RB Sutton set. Beautiful but total craziness... dennismcc 1
chuck540z3 Posted May 30, 2020 Posted May 30, 2020 I use CA glue, because it dries fast. Put a small droplet where you want adhesion to the seat, press the belt against the glue with a thin clean object like tweezers or toothpick, wait 15 seconds, then move on to another adhesion point. This method works very well, but is risky because glue marks might show in some places. If they do, have a micro-brush handy when gluing to help remove the extra glue immediately before it dries. When dry, the glue will be gone but the residue will be shiny, so a quick spray of dull coat removes that. An example from my recent Harvard build before I dirtied up the belts a bit. Cheers, Chuck
dennismcc Posted May 30, 2020 Posted May 30, 2020 1 hour ago, chuck540z3 said: I use CA glue, because it dries fast. Put a small droplet where you want adhesion to the seat, press the belt against the glue with a thin clean object like tweezers or toothpick, wait 15 seconds, then move on to another adhesion point. This method works very well, but is risky because glue marks might show in some places. If they do, have a micro-brush handy when gluing to help remove the extra glue immediately before it dries. When dry, the glue will be gone but the residue will be shiny, so a quick spray of dull coat removes that. An example from my recent Harvard build before I dirtied up the belts a bit. Cheers, Chuck Same method I use, did it last night on my N1K2 seat. Cheers Dennis
