11 hours ago, LSP_K2 said:
Nice kit from what I hear.
I hope it is, I have another one of these waiting to be built as Rudolf Sinner's plane or as Red S from the JV 44.
You will enjoy this kit build. It goes together nicely. I built mine as Eduard Schallmoser's aircraft. He was Galland's wingman.
Jager
Edited by Jager
Better than nice, I built one of these years ago, knock down amazing typical tamiya.  Has a nose weight that integrates into the gun bay so it sits perfectly.  Clicks together and the detail is out of this world.
44 minutes ago, sturmovik said:
@cbk57 do you know if the nose landing gear can be added AFTER painting and decalling?
I had to find some instructions, I built mine years ago.  I suspect that I painted the front gear assembly then wrapped it in tape.  However, I think you could test fit the assembly and try because it might be possible to sneak the nose gear in after assembly.
Hello guys, I come back to this thread with lots of progress to show you:
The gunbay:
The gunbay glued to the nose weight, alongside the nose geat attachment piece at the front of the weight:
Wings glued together:
I added an extra weight (not shown) at the front of the cockpit, because I'm not sure if the supplied weight will be enough:
Fuselage halves glued together:
Airframe completed:
5 minutes ago, AlbertD said:
Looks great so far. I have this kit too but I don't think mine came with the nose weight.
Try contacting Tamiya for a spare weight if it didn't come with it. The two I bought had the weights glued inside one side of the box.
I just looked again and sure enough there it is attached inside the end of the box. I guess I just never noticed it before. Thanks for the info.
I've pretty much convinced myself that next year will be entirely devoted to WWII 1:48 ceiling queens, and this kit may well be amongst them. I have several that are well underway already, so finishing off a dozen or so should be pretty easy, I'd think. I'll certainly be watching yours.
