rosariovw Posted May 27, 2019 Author Posted May 27, 2019 update, after my shifts (2late and 2 nights) i did some extra work. left wing assembled added some rivets, and other stuff johncrow and LSP_Kevin 2
rosariovw Posted May 27, 2019 Author Posted May 27, 2019 did dryfitting on the cockpit LSP_Kevin and johncrow 2
rosariovw Posted May 27, 2019 Author Posted May 27, 2019 And re-shaped the ventral fins, and added depth on the NACA vent. The fins are too thick, so its sanding like hell. Atm i'm thinking casting them in resin, so i have them for future builds. But they are still in progress. LSP_Kevin, johncrow, Gazzas and 1 other 4
rosariovw Posted May 29, 2019 Author Posted May 29, 2019 did some work today, (not that much, cause lost my job today) to keep the mind clear. Added detail to the ventral fin, one done, 1 to go. And every time, adding panels to the forward fuselage, and let me tell ya, fitting sucks. On most places i need to add spacers, or the gaps are huge. Did some windscreen details And the ECS vents A-10LOADER, Shawn M, LSP_Kevin and 3 others 4 2
LSP_Kevin Posted May 29, 2019 Posted May 29, 2019 Very nice work! Sorry to hear about your job. Kev nmayhew 1
Out2gtcha Posted May 30, 2019 Posted May 30, 2019 Some great work here! Indeed, Ive been laid off 3 times in my life, and its never ever fun. Looking for a job IS a full time job on most accounts. I found modeling is a catch 22 when you loose your job; you have all this extra time, but the depressive effects of loosing ones job makes it hard to get to the bench sometimes............ But one you get to the bench it can help keep the brain occupied...............but you have to get there in the first place and there is where the Catch 22 comes into play. Shawn M, Vandy 1 VX 4 and zerosystem 3
rosariovw Posted May 30, 2019 Author Posted May 30, 2019 thanks for the support, got some done today. Started with the HUD, i tried to use some prismatic paint (alclad) but when i spray it, it gets white/flat. So, i used a brush, it worked great on the HUD lens. i tried it on the glass, and fucked it up, so made new ones. and sculpted a new wingbladder TorbenD, Sony Coder, LSP_Kevin and 5 others 8
A-10LOADER Posted May 31, 2019 Posted May 31, 2019 What markings will she eventually wear ? Steve "TOMCATS FOREVER, BABY...!"
rosariovw Posted June 1, 2019 Author Posted June 1, 2019 i'm still in doubt, ATM, i'm thinking for the TOMATO, or Vandy 1
rosariovw Posted June 2, 2019 Author Posted June 2, 2019 yesterdag, i ordered the the Tomato decals (not that i have enough decal sets) but the gilfriend says, it was the best eyepopping bird. Also, this weekend i won't build much, cause i'm compating in a contest with 1/48 this weekend. Even just invested in the hobby again, and bought just a whopping 300$ worth of building materials.
rosariovw Posted June 4, 2019 Author Posted June 4, 2019 (edited) The last 3 days i did the dryfitting, and modding it all for the Zactoman intakes. Its not an easy task, resin wheelbays, resin ecs vents, and the intakes are not intended to be used together. I thinned the vents side, and made a thin cut in the air bleed compartiment. On the wheel bay side, and on the air bleed compartiment i had to remove some extra resin, so the compartiment rests on the angled wheel bay part. Also, i added some strips to make sure the compartiments get on the correct position, and added a cover on the bottom of the vents. painted the intakes just an example Edited June 4, 2019 by rosariovw Starfighter, Shawn M, Out2gtcha and 3 others 6
tchwrma Posted June 5, 2019 Posted June 5, 2019 Nice work! I will be following your job to get inspiration to made my Tamiya's tomcat, one day. And you are doing a great model! I wish to you to get a new job, perhaps better than the old one! And keep in the kits, it always helping us with the life troubles. To me they helps a lot. Cheers, Paulo.
Starfighter Posted June 5, 2019 Posted June 5, 2019 Great job so far, Rosario! Can't wait to see more! Cheers Ben
A-10LOADER Posted June 5, 2019 Posted June 5, 2019 WOW, that really looks like quite the project !! Best of luck getting thru this phase of the build. What you have accomplished so far looks great. Steve "TOMCATS FOREVER, BABY...!"
