MikeC Posted April 21, 2019 Share Posted April 21, 2019 Great work, something very different. The Force is obviously with you on this. spacewolf 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted April 21, 2019 Share Posted April 21, 2019 Good show, Vaughn. You are so creative. Sincerely, Mark spacewolf 1 Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 On 4/19/2019 at 12:36 PM, Out2gtcha said: Saaaaaaaweet!! Is the large seem down the end by the Temple side, a crack in the rock? You could say that... Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 On 4/20/2019 at 2:57 AM, Troy Molitor said: There should be some sort of trivia or quiz to ask someone how many bits of styrene make up Jedha City. Ha! I didn't count and I'm not going back to check !! Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 On 4/20/2019 at 5:17 PM, The Madhatter said: Super impressive build going on here I must say! The only thing I would suggest is having a removable building plate where a mounting pole can go. Not every modeller will want to destroy some ground work to be able to install a mounting pole. Personally I think it would be a selling point to be able to remove a plug rather than have to rebuild some of those details. Looking forward to the next update Thanks ! I kinda felt the same way but Jimi said not to worry about it. I personally will wait till I get my hands on the SD to see about the best placement for a rod/ stand. It wouldn't be hard to drill a mounting hole in the mountain side for a 1/4 in acrylic rod... and in the movie the SD is off a bit to one side, not directly over the city. Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 On 4/20/2019 at 11:15 PM, MikeC said: Great work, something very different. The Force is obviously with you on this. It's actually been a lot of fun not having to nit pic and worry about accuracy & rivet counting. Out2gtcha 1 Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 On 4/21/2019 at 2:41 AM, dodgem37 said: Good show, Vaughn. You are so creative. Sincerely, Mark Thanks much !! Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 So kids, it's update time !! It took a bit of searching but I found that build I mentioned.. the guy scratch built a city in scale with the Zvesda kit and lit the city.. Brilliant crazy work Link to his build; https://sci-fi.at.webry.info/201711/article_5.html Alain Gadbois, coogrfan, BloorwestSiR and 1 other 4 Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 I was busy working to get the seams as close as I could... The overlapping joint certainly helps the city wall.. BloorwestSiR, MikeC, Coneheadff and 2 others 5 Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 I was going back and forth from sculpting to working on the city... The small one with the big one.. Almost there.... LSP_Kevin, BloorwestSiR, Tnarg and 5 others 8 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 26, 2019 Share Posted April 26, 2019 Love it man! Looking every bit the part! BloorwestSiR 1 Link to comment Share on other sites More sharing options...
spacewolf Posted April 26, 2019 Author Share Posted April 26, 2019 And finally... the last buildings in place... In primer... Now to finish off the walls and the mountain. If all goes well, beauty shots next week !! Thanks for looking in !! Christoffer Lindelav, LSP_K2, Tnarg and 11 others 14 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 26, 2019 Share Posted April 26, 2019 Awesome BloorwestSiR and spacewolf 2 Link to comment Share on other sites More sharing options...
Troy Molitor Posted April 27, 2019 Share Posted April 27, 2019 Most impressive. spacewolf and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 29, 2019 Share Posted April 29, 2019 Looks fantastic Vaughan! spacewolf 1 Link to comment Share on other sites More sharing options...
