Cees Broere Posted March 22, 2019 Share Posted March 22, 2019 Indeed, no pressure my friend. Link to comment Share on other sites More sharing options...
Troy Molitor Posted March 24, 2019 Share Posted March 24, 2019 Wonderful start on this build. Thanks for sharing this one with us Erik. Troy One-Oh-Four 1 Link to comment Share on other sites More sharing options...
One-Oh-Four Posted March 24, 2019 Author Share Posted March 24, 2019 3 hours ago, Troy Molitor said: Wonderful start on this build. Thanks for sharing this one with us Erik. Troy Well... The wonderful part up till now is Scott’s work. I’ll see if I can match the quality! The next couple of days I’m afraid I’ll be supporting my oldest son finalizing his history paper he needs to finish to be able to graduate. Interesting topic: How did (the outcome of) the First World War cause the Second World War. The economic, political and German societal (Weimar Republic) causes need to be adressed. Link to comment Share on other sites More sharing options...
A6M Posted March 27, 2019 Share Posted March 27, 2019 I finally had time to sit down and open a Fotki account (thanks for the suggestion, Erik). Here is my first test posting. The upper image is of the Oxygen Flow Regulator. The pilot's oxygen mask would link into the fitting on the lower right side (by the sh in Mikesh). Beside this fitting is a valve to set the desired flow pressure. On the top left is an on/off switch The second image illustrates where the OFR was mounted below the centre of the instrument panel Pete Roberts, LSP_K2, LSP_Kevin and 2 others 4 1 Link to comment Share on other sites More sharing options...
One-Oh-Four Posted April 5, 2019 Author Share Posted April 5, 2019 A little babystep. As pointed out already, the double compressed air-bottle setup on the left fuselage side was an A6M5-feature so I have been busy fabricating two horizontal single-bottle brackets. Comparing them to the photo posted by Scott of the setup in an A6M3 I freewheeled a bit. If they'll be visible at all remains to be seen.... This was the Eduard-modified kit setup: I first tried to copy the Eduard bracket for the single bottle as found on the back of the cockpit bulkhead from plasticard, but I was already dissatisfied even while I was cutting it. When the knife went a little wide; that was it! New tactic: making a photocopy of the bracket, trying to drill the lightening holes after which the bracket could simply be cut out with a small pair of decal-scissors. Of course, drilling in a piece of paper doesn't work! I didn't want to abandon the basic idea at that moment yet so I repeated the photocopying, this time punching the holes with the punch-and-die, what sort-of worked. After cutting out the part, I immersed it in Future, hoping to reinforce the paper with it after it had dried. This also sort-of worked, but I couldn't get excited about it... Nothing beats the instructional value of (other people's) failure, so: Then I had my Eureka-moment: why not try to cut the original double bracket in half, thereby creating two single brackets? Lo and behold, it worked! I cut the two bottles apart and sanded the bottom of one round to conform to the shape of the horizontal bottle on the fuselage floor. Because the bottle only poses for this photo, the straps haven't been fastened over the bottle yet. Hmmmm, looking at the photo of the A6M3, it looks significantly different..... Maybe I'll try something else, yet... LSP_Kevin, Pete Roberts, TenSeven and 3 others 6 Link to comment Share on other sites More sharing options...
fmatthews Posted April 6, 2019 Share Posted April 6, 2019 Looking great-nice work! Link to comment Share on other sites More sharing options...
LSP_Ray Posted April 6, 2019 Share Posted April 6, 2019 12 minutes ago, fmatthews said: Looking great-nice work! Link to comment Share on other sites More sharing options...
Rick K Posted April 6, 2019 Share Posted April 6, 2019 Watching you put the finish on this one Erik! Great detail work! Link to comment Share on other sites More sharing options...
A6M Posted April 7, 2019 Share Posted April 7, 2019 (edited) Here are some details on the CO2 tank mount for the fire extinguisher system. The B&W photo is from A6M3 32 c/n 3030. The colour image is from an artifact in the collection of Legend Flyers in Everett WA. The line drawing is from the A6M2 maintenance manual. Ryan Edited April 7, 2019 by A6M Pete Roberts 1 Link to comment Share on other sites More sharing options...
A6M Posted April 7, 2019 Share Posted April 7, 2019 I found another image in my files that provides a much more detailed view of the CO2 tank mounts. This is from the A6M3 22 c/n 3685 in the Duxford collection. Rob Thwaites was kind enough to photograph this plane for me back in 2008. In the photo you can see the two mounts were not identical in configuration. Ryan Pete Roberts, LSP_Kevin, One-Oh-Four and 1 other 3 1 Link to comment Share on other sites More sharing options...
One-Oh-Four Posted April 8, 2019 Author Share Posted April 8, 2019 Wow, great info, Ryan! I'll chop out the brackets I used and try to replicate these! Link to comment Share on other sites More sharing options...
jep1210 Posted April 8, 2019 Share Posted April 8, 2019 I'm not a huge fan of Zeros or most Japanese aircraft but this build has me considering adding one. Looking great so far. One-Oh-Four 1 Link to comment Share on other sites More sharing options...
A6M Posted April 10, 2019 Share Posted April 10, 2019 I'll help as much as I can. I'm in the process of rewriting my A6M2 Tweak List and the exercise is proving profitable. Going through all my notes and pulling them all together is turning up a number of little details, especially in the later Nakajima-built M2s. Ryan LSP_Kevin, coogrfan and One-Oh-Four 2 1 Link to comment Share on other sites More sharing options...
One-Oh-Four Posted April 10, 2019 Author Share Posted April 10, 2019 That's great! Thanks! Link to comment Share on other sites More sharing options...
A6M Posted April 11, 2019 Share Posted April 11, 2019 I've bogged down on Section 9 of the Tamiya instruction sheet. There are lots of cockpit changes for the later Nakajima built M2. However, here are my notes for Section 1 so at least that initial step is covered for you. Section 1 - The Mitsubishi consistently painted the cockpit interior a dark green (FS 4098). Nakajima at first started with a similar shade of green, but by mid-1942 switched to a much lighter green (FS 4373). In contrast to Mitsubishi, Nakajima Zeros had the seat supports and landing gear and flap levers painted gloss black. Both the guns and radio equipment, however, followed the pattern found in Mitsubishi examples. - The rivets on the rear cockpit deck were not flush and should instead be raised. - The ammunition expenditure counter E3 can only be found on the very early Mitsubishi built A6M2. However, the hemispheric lamp should be attached just below E26. It is overall natural aluminum. - The two CO2 (not oxygen) pressure bottles E62 were part of the fire extinguisher system introduced in early Dec 43. Prior to that date there was only a single horizontally-mounted CO2 bottle in this location. This CO2 bottle should be painted green with the valve facing towards the front of the aircraft. - There is a small circle inscribed on the outer left side of the fuselage just below the rear oval access panel. This is the location of the compressed air refilling valve and should be drilled out. Ryan LSP_Kevin, Uncle Toby and anj4de 3 Link to comment Share on other sites More sharing options...
