Out2gtcha Posted March 28, 2019 Posted March 28, 2019 Gettin a bit antsy for updates my friend........................need a Griffon fix nmayhew and Martinnfb 2
williamj Posted March 28, 2019 Author Posted March 28, 2019 Very soon Brian...Who was it that said it was going to a ton?? It has been,so much to change,damned Spitfires Martinnfb, chuck540z3 and Out2gtcha 3
nmayhew Posted April 4, 2019 Posted April 4, 2019 would love to see an update on these and even if no update, could you provide a bit more info on how the resin noses mated up to the Tamiya fuselages? Was the fit good? Aren't you worried about the strength of the join? etc etc Many thanks nick williamj, Martinnfb and Out2gtcha 3
williamj Posted April 4, 2019 Author Posted April 4, 2019 (edited) Thanks for the kind comments.. Update...Try to answer some questions here..We are just about ready to lay some paint...do have some fasteners ,rivets,and a bit of touch ups yet to finish up..not too much..few days. Just to let you know..no one makes a griffon set for the Tamiya kits..not yet anyway..I hear Radu might be working one up.Now I took the Warbirds nose and re worked it to fit,a lot of premeditated planning and dry fitting...(There is a very slight downward angle on the front engine ...that was a challenge) ,then re cast my own.went through a lot of silicon rubber,mold release and resin as we made a few other parts as well. The hollow noses were "Tacked" into place with some CA..then when I was happy with the position went in and back filled the join with two part epoxy putty,a dark grey putty think it's called "liquid steel" when it sets up you can't even sand it,a very strong connection ,from there we carried on with re establishing rivets,panel lines,fasteners. The final primer is Tamiya fine grey.I decant and thin with lacquer thinner for better coverage..just spraying it from the can will fill up and cover a lot of fine detail that you sweat over,small repairs and touch ups are easier as well. There is a list of changes made to both..shorter ailerons,change to elevators,new hatches in the fuselage,blasting out the rad areas under the wings and blending in larger new ones,getting the spinners and prop blades where I wanted them and casting replacements,etc...to long to list.and that takes time. But very happy to have arrived here. Cheers for now...let's keep it fun..Bill. Edited December 10, 2022 by williamj Out2gtcha, TorbenD, Uncarina and 15 others 17 1
Out2gtcha Posted April 4, 2019 Posted April 4, 2019 Smooth as a new-born's bottom! nmayhew, Martinnfb and williamj 2 1
williamj Posted April 4, 2019 Author Posted April 4, 2019 (edited) 4 hours ago, nmayhew said: would love to see an update on these and even if no update, could you provide a bit more info on how the resin noses mated up to the Tamiya fuselages? Was the fit good? Aren't you worried about the strength of the join? etc etc Many thanks nick Here you go Nick..and thanks for following. "Was the fit good?" No...it sure wasn't..much grinding and re-shaping..not to mention some choice curses. Edited April 4, 2019 by williamj Martinnfb and nmayhew 1 1
williamj Posted April 4, 2019 Author Posted April 4, 2019 23 minutes ago, Out2gtcha said: Smooth as a new-born's bottom! Thanks buddy..hope we don't get a rash. nmayhew and Martinnfb 1 1
Martinnfb Posted April 4, 2019 Posted April 4, 2019 The propeller is my favourite part of this Spitfire generation and from where I sit seems to be spot on . Work of beauty William. williamj, Out2gtcha, Anthony in NZ and 3 others 6
D.B. Andrus Posted April 4, 2019 Posted April 4, 2019 I have one of those Griffon noses, you've worked a miracle making it fit. Wonderful effort so you shall henceforth be known as St. William-Griffon of Penticton. I bow before your workmanship, dear sir. Cheers, D.B. Anthony in NZ, nmayhew, Martinnfb and 1 other 4
williamj Posted April 4, 2019 Author Posted April 4, 2019 56 minutes ago, D.B. Andrus said: I have one of those Griffon noses, you've worked a miracle making it fit. Wonderful effort so you shall henceforth be known as St. William-Griffon of Penticton. I bow before your workmanship, dear sir. Cheers, D.B. Thanks DB,,really appreciate it......sorry to tell you but my lovely wife officially named me years ago..there was a ceremony and everything. Martinnfb and Out2gtcha 2
D.B. Andrus Posted April 4, 2019 Posted April 4, 2019 13 minutes ago, williamj said: Thanks DB,,really appreciate it......sorry to tell you but my lovely wife officially named me years ago..there was a ceremony and everything. Damn, a day late and a dollar short.......again. Martinnfb and williamj 2
Fanes Posted April 5, 2019 Posted April 5, 2019 That's really nice craftmanship - I'm really excited to see some paint on those beautiful spits. One minor Thing: It may be the light but it seems like there are still some scratches on the upper engine cowling? williamj and Martinnfb 2
