Vandy 1 VX 4 Posted April 7, 2018 Share Posted April 7, 2018 You're welcome Carl . Where is this photo Taken? BloorwestSiR 1 Link to comment Share on other sites More sharing options...
patricksparks Posted April 7, 2018 Share Posted April 7, 2018 Yup, it's in there all right. Almost have this side done. If your going to put all the radios in, I decided to get the Eduard B-17 radio compartment set as it has all the same equipment as far as the different components carried, plus you get a couple oxygen indicators/regulators you can add onto your cabin walls plus some other bits and pieces that can be used. I also looked into Resin 2 Detail who makes 1:32 radios(less expensive too) but I don't think the set has all of the radios that were carried on B-25s, the castings look really nice though and the set is probably enough components to make due once you close up the fuselage you probably won't notice. Pat Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2018 Author Share Posted April 7, 2018 For a kit of this magnitude, I am a little surprised they didn't mould the ribs...........looking good guys....... They did put some ribs in but nowhere near all of them. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2018 Author Share Posted April 7, 2018 Darn Carl, you're Rollin'! Getting into a rhythm, that's for sure. Link to comment Share on other sites More sharing options...
TimHepplestone Posted April 7, 2018 Share Posted April 7, 2018 Yup, it's in there all right. Almost have this side done. Nicely done sir.!!! BloorwestSiR 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2018 Author Share Posted April 7, 2018 If your going to put all the radios in, I decided to get the Eduard B-17 radio compartment set as it has all the same equipment as far as the different components carried, plus you get a couple oxygen indicators/regulators you can add onto your cabin walls plus some other bits and pieces that can be used. I also looked into Resin 2 Detail who makes 1:32 radios(less expensive too) but I don't think the set has all of the radios that were carried on B-25s, the castings look really nice though and the set is probably enough components to make due once you close up the fuselage you probably won't notice. Pat I thought about the Eduard B-17 set as well as the Resin2detail ones. The Resin2detail ones worked out to be almost double due to really high shipping. I ended up getting a set from Australia on eBay that were much more reasonable. The guy has a front radio compartment as well as a radio set so I ordered one of each. And thanks again for your inspiration and advice on the ribbing. Carl patricksparks 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2018 Author Share Posted April 7, 2018 Nicely done sir.!!! Thanks Tim! Link to comment Share on other sites More sharing options...
Finn Posted April 7, 2018 Share Posted April 7, 2018 A few more waist position images: http://www.gstatic.com/hostedimg/2f0172c578bdea56_large http://www.gstatic.com/hostedimg/1658c862757ce779_large http://www.gstatic.com/hostedimg/3b877cbb24349fe0_large http://www.gstatic.com/hostedimg/47e7821bc0e7adb5_large Jari patricksparks and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted April 7, 2018 Share Posted April 7, 2018 It looks like somewhere over the Solomons... Ernie's the reason I mentioned it it looks like the Solomon's in Baa Baa Black Sheep to be exact on the left of the photo you see two points one has a break water and the second row rocks jetting out at the farther point doesn't but you see a white building which I think is the Hueneme lighthouse. Which would be the harbor for US Navy Seabees BloorwestSiR 1 Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted April 7, 2018 Share Posted April 7, 2018 The B-25 is coming out great good quality work BloorwestSiR 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2018 Author Share Posted April 7, 2018 A few more waist position images: http://www.gstatic.com/hostedimg/2f0172c578bdea56_large http://www.gstatic.com/hostedimg/1658c862757ce779_large http://www.gstatic.com/hostedimg/3b877cbb24349fe0_large http://www.gstatic.com/hostedimg/47e7821bc0e7adb5_large Jari Thanks Jari! Those pics confirm what I suspected which is that the gun mount is not in the right place. It's centered and should be closer to the rear edge where the opening is. Carl Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2018 Author Share Posted April 7, 2018 The B-25 is coming out great good quality work Thanks Vandy! Vandy 1 VX 4 1 Link to comment Share on other sites More sharing options...
Bstarr3 Posted April 7, 2018 Share Posted April 7, 2018 Great work, Carl. I love seeing all these 25s come together! Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 Great work, Carl. I love seeing all these 25s come together! Thanks Brian! They keep growing in number. Carl Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 What do you guys think? I'm reminded of the quote from "Contact" where the guy says "Why build one at full price when you can have two for double?" or something like that. Anyways, I started on the starboard side. I figured the best place was the round escape hatch just aft of the waist window. I started by cutting out a circle 17mm in diameter. This was edged with a strip of 0.015 x 0.030 which I curled a bit before gluing it to the edge. With the edge completely in place. I then added the internal bracing to match the rivet pattern on the outside. I then measured the distance from the waist window and glued it in place. ShotMagnet, LSP_Kevin, Uncarina and 2 others 5 Link to comment Share on other sites More sharing options...
