BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 After double checking the hatch's position, I noticed that I had a problem with the ribbing on the other side. The very last rib will run through the escape hatch. Which mean it's in the wrong place... patricksparks and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
Guest Posted April 8, 2018 Share Posted April 8, 2018 (edited) Excellent !Carl, isn't there an outline on the outside you can line it up with ?.....Harv.......Harv Edited April 8, 2018 by Guest Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 Excellent !Carl, isn't there an outline on the outside you can line it up with ?.....Harv.......Harv There is Harv, that how I checked to make sure I had it in the right spot. I think I followed the wrong rivet line when I did the other side. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 So time for Plan B. I've already swiped a bomb bay from the other kit, might as well grab the fuselage half too. Since I was planning to do the second one all closed up, the error won't be as obvious. I'll fudge the escape hatch a bit on that one. Which got me me thinking that since I have so much of the second kit out, I might as well go all in. So now to figure out what scheme to do on number two. NMF? Or OD/NG again? Carl Link to comment Share on other sites More sharing options...
Guest Posted April 8, 2018 Share Posted April 8, 2018 Well, if your up to it, do it NMF....Harv Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 Well, if your up to it, do it NMF....Harv That was my thinking too. Maybe with cheek guns as well. I know most had them at one point so not unreasonable. Link to comment Share on other sites More sharing options...
Guest Posted April 8, 2018 Share Posted April 8, 2018 Some of the early birds(like mine) had guns on the right side only. The other ones were added latter on....Harv Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 I think the H had the asymmetrical load out due to the ammo rack for the 75mm cannon being where the ports identified cheek gun ammo boxes were. Ruff 'N Ready had the cheek guns on both sides at some point but I don't think there's decals for her. Link to comment Share on other sites More sharing options...
Guest Posted April 8, 2018 Share Posted April 8, 2018 I have seen other H modeld with guns on bot h sides. IIRC Barbie had them latter ob....Harv Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 Looks better with them on both sides. Any thoughts to which option you'll go with? Link to comment Share on other sites More sharing options...
Guest Posted April 8, 2018 Share Posted April 8, 2018 Since I'm building it as close as possable, guns only on the one side.MY OCD is gonna drive me nuts!....Harv Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 I bet. It would drive me nuts too! Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2018 Author Share Posted April 8, 2018 What do you think of this? http://www.canmilair.com/products.php?cat=44&pg=3 Fill in the nose, use the top turret blanking plate in the kit and go from there. Link to comment Share on other sites More sharing options...
Guest Posted April 8, 2018 Share Posted April 8, 2018 Cool!....Harv Link to comment Share on other sites More sharing options...
Finn Posted April 8, 2018 Share Posted April 8, 2018 (edited) Carl there are a couple of images here, 3rd row down: https://commons.wikimedia.org/wiki/Category:Heavenly_Body_(B-25_Mitchell) showing the position of the escape hatch. Also on pg 120 of the manual, 133 of the reader: http://www.avialogs.com/index.php/aircraft/usa/northamericanaviation/b-25mitchell/report-na-5770-flight-manual-b-25h.html shows the inside release handle for the hatch. Jari Edited April 8, 2018 by Finn patricksparks and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
