LSP_Kevin Posted August 29, 2017 Share Posted August 29, 2017 This is looking really terrific! Kev Link to comment Share on other sites More sharing options...
Gazzas Posted August 29, 2017 Share Posted August 29, 2017 Excellent pit. The seat belts really make a difference. Shaka HI 1 Link to comment Share on other sites More sharing options...
AceofClubs Posted August 29, 2017 Share Posted August 29, 2017 Very nice weathering and built! IMHO add some more drybrushing on instruments dials to give more evidence to details. I usually use a mix of silver and light gray in a very very little amount on brush. Ciao Filippo Link to comment Share on other sites More sharing options...
Guyman1 Posted August 29, 2017 Share Posted August 29, 2017 Very nice work on the pit the way you have aged the interior is excellent. Guy Link to comment Share on other sites More sharing options...
b737flyer Posted September 6, 2017 Author Share Posted September 6, 2017 Managed to get the fuselage closed up and things are moving along again. The cockpit sill/edge needs some work as Revell has engineered it so the fuselage sides and cockpit sides have a bit of a gap that needs to be filled and sanded smooth. The battery cover area behind the cockpit needs some work as well to get the bulkead to sit flush. If installed per the kit instructions a step is created all around the bulkhead; I think this is a leftover from their G6 kit with the non-Erla canopy. The upper cowling is also just placed for the photograph and will need some tweaking and filling as well. Overall I've been pleased with the way things have gone together so far. The wheel wells and radiator scoop area have also been airbrushed with decanted Tamiya AS-12 Bare Metal Silver thinned with Mr.Color Levelling Thinner. My research indicates these late 109-G10's likely had natural metal gear wheels as well as the under surfaces of the wings. If anyone has additional info or insight it would be appreciated. Gazzas, Shaka HI, Greg W and 2 others 5 Link to comment Share on other sites More sharing options...
ClumsyDude Posted September 6, 2017 Share Posted September 6, 2017 Wow, looks really crisp. I like it! Jim Link to comment Share on other sites More sharing options...
Mark M Posted September 6, 2017 Share Posted September 6, 2017 very nice Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 6, 2017 Share Posted September 6, 2017 Nice work! I like the paint work in the pit very much Mark M 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted September 6, 2017 Share Posted September 6, 2017 Great build, excellent photography! Link to comment Share on other sites More sharing options...
MikeMaben Posted September 6, 2017 Share Posted September 6, 2017 (edited) My research indicates these late 109-G10's likely had natural metal gear wheels as well as the under surfaces of the wings. If anyone has additional info or insight it would be appreciated. Hey Jeremy, the G-10 was called the 'b*****d' 109 because they were conversions from pre existing G-6s and G-14s to bring them up to the standards of the K. So it's unlikely that any of the various parts would be unpainted, but being built in the 'desperate' period of the war, anything is possible. I see you're using Roy's decals so I wouldn't argue with his sources. Something to consider would be your choice of wheels. Some G-10s had the larger wheels with the long tailwheel, some had the smaller wheels with the standard tailwheel, some had a mix of the 2. The size of the wheels would determine the size of the 'bumps' on top of the wing. Have fun Edited September 6, 2017 by mmaben Gazzas 1 Link to comment Share on other sites More sharing options...
b737flyer Posted September 6, 2017 Author Share Posted September 6, 2017 (edited) Hey Jeremy, the G-10 was called the 'b*****d' 109 because they were conversions from pre existing G-6s and G-14s to bring them up to the standards of the K. So it's unlikely that any of the various parts would be unpainted, but being built in the 'desperate' period of the war, anything is possible. I see you're using Roy's decals so I wouldn't argue with his sources. Something to consider would be your choice of wheels. Some G-10s had the larger wheels with the long tailwheel, some had the smaller wheels with the standard tailwheel, some had a mix of the 2. The size of the wheels would determine the size of the 'bumps' on top of the wing. Have fun Thanks for the info mmaben. I agree with your comments about painted vs. unpainted components during the late stages of the war - it seems anything is possible due to desperate times. I might do a little of both on the gear wells and under surfaces to make things a little more interesting. As far as wheels go, the kit comes with the wide wing bulges so I'm using the wide G10 wheels from BarracudaCast as well as the tall tail wheel. Edited September 6, 2017 by b737flyer MikeMaben 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted September 6, 2017 Share Posted September 6, 2017 I'd like to amend my previous statement. Not all G-10s were conversions from previous aircraft. Most G-10s started out either as G-14s or parts destined to become G-14s. This is likely the reason some had some unpainted surfaces. G-10s came 'after' the G-14. All this information comes from Prien/Rodeike and Japo books. Sounds like you're on the right track Jeremy. Mike Link to comment Share on other sites More sharing options...
b737flyer Posted September 20, 2017 Author Share Posted September 20, 2017 It's been a while since my last update but things are still moving along. The wings have been installed and fit pretty well both at the upper wing root and below. I've also secured the upper cowling which will need some work to eliminate a seam line that doesn't fall on a panel line. I also painted the BarracudaCast exhausts and mounted them and in the photos below you can see the BarracudaCast spinner, oil cooler fairing, and cooling scoops. I've also settled on a paint scheme - Black 13 from the excellent BarracudaCal decal set. Still lots of work to do! Gazzas, Shaka HI, MikeMaben and 1 other 4 Link to comment Share on other sites More sharing options...
Hardcore Posted September 20, 2017 Share Posted September 20, 2017 (edited) Note that the area where the drop tank is mounted is not part of the wing, and should not be left unpainted (green camo here!). The Decal sheet got that wrong imho. Edited September 20, 2017 by Hardcore Link to comment Share on other sites More sharing options...
b737flyer Posted September 20, 2017 Author Share Posted September 20, 2017 Note that the area where the drop tank is mounted is not part of the wing, and should not be left unpainted (green camo here!). The Decal sheet got that wrong imho. Thanks - I noticed the same from a different resource and was planning on painting the area in question. Link to comment Share on other sites More sharing options...
