Dan Paxton Posted August 29, 2017 Share Posted August 29, 2017 Link to comment Share on other sites More sharing options...
mozart Posted April 13, 2019 Author Share Posted April 13, 2019 (edited) I've picked up my Harvard build again over the past couple of weeks, a few update pictures and brief comments where necessary: Work on the cockpit and pilot figure: The KH kit lacks the horns on the rudder for the linkages: so some work on this: The fit of the aft panel isn't great on the KH kit, I'm not sure why they planned it as a separate item instead of moulded as part of the fuselage halves, so filling and sanding necessary: Another area needing work is KH's attempt at portraying the underlying metal structure of the fabric covered empennage. As can be seen on the Harvard photograph, it's not that obvious: so the lines were sanded off: and lines of Archer rivets applied - not strictly accurate either I know but an improvement to my eyes: I've done a little work on the air intake on the port front cowling. The kit version is just a flat blank so I drilled that out, thinned down a BF109 radiator grille and cut it to shape for the intake: Another area needing a little detailing is the refuelling points. KH's mouldings drilled out and replaced with better looking versions: The IPs supplied are wrong for an RAF WW2 vintage Harvard, so these are being addressed. I've taken a rather lazy approach I'm afraid in just putting Airscale dials straight onto the plastic surface, I may put the bezels in front....hmmm? The large white lump on the inside of the top nose panel is additional anchorage for the tall radio aerial, mine snapped off on my first build when the aerial was stretched. And finally, Mustang wheels were ordered to replace the flimsy KH ones. The Harvard is going to be in-flight, but possibly flaps down and uncart being lowered....... that's where "it's at" folks. More later I hope! Edited April 13, 2019 by mozart MikeC, sandokan, Out2gtcha and 7 others 9 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 13, 2019 Share Posted April 13, 2019 Lovely work, Max! Just remember, though, that this is a KH kit, not a HK one! Kev mozart 1 Link to comment Share on other sites More sharing options...
MikeC Posted April 13, 2019 Share Posted April 13, 2019 Good to see this one back under way. Link to comment Share on other sites More sharing options...
mozart Posted April 13, 2019 Author Share Posted April 13, 2019 20 minutes ago, LSP_Kevin said: Lovely work, Max! Just remember, though, that this is a KH kit, not a HK one! Kev Thanks for that Kev, dyslexia strikes again....or senior moments! Will correct immediately lest I cause offence! LSP_Kevin 1 Link to comment Share on other sites More sharing options...
monthebiff Posted April 13, 2019 Share Posted April 13, 2019 Good to see you back on this one Max and some nice work on the cockpit. Like your use of the Archer rivets as well. Regards. Andy Link to comment Share on other sites More sharing options...
mozart Posted April 13, 2019 Author Share Posted April 13, 2019 13 minutes ago, monthebiff said: Good to see you back on this one Max and some nice work on the cockpit. Like your use of the Archer rivets as well. Regards. Andy You'll always be the Archer rivet King Andy!! Link to comment Share on other sites More sharing options...
Pascal Posted April 13, 2019 Share Posted April 13, 2019 Very nice work Max. Where can one buy that figure ? Sincerely Pascal Link to comment Share on other sites More sharing options...
mozart Posted April 13, 2019 Author Share Posted April 13, 2019 1 hour ago, Pascal said: Very nice work Max. Where can one buy that figure ? Sincerely Pascal Thank you Pascal. The figure is a Wings Cockpit figure, adapted as mentioned previously to get rid of the Mae West, but the only way you can order is via Facebook or try david.allen@wingscockpitfigures.com, the figure is coded RAF01 in David's excellent range of figures. sandokan and Pascal 2 Link to comment Share on other sites More sharing options...
mozart Posted April 15, 2019 Author Share Posted April 15, 2019 Now here's a funny thing!! As can be seen from this extract from the T-6/Harvard manual, the engine cowling comprises three parts: so I wonder why KH decided to make the model one four parts, none of the joints coinciding with the panel joins on the real thing: More sanding, more polishing! sandokan, LSP_Kevin and Pfuf 2 1 Link to comment Share on other sites More sharing options...
MikeC Posted April 15, 2019 Share Posted April 15, 2019 An odd decision indeed. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 15, 2019 Share Posted April 15, 2019 Been there, done that! Lovely work so far, Max. Kev Link to comment Share on other sites More sharing options...
LSP_Ray Posted April 15, 2019 Share Posted April 15, 2019 Maybe because with raised detail at the true joints, it is easier to deal with the joints away from that detail? Doesn't answer why their are 4 parts, though... Link to comment Share on other sites More sharing options...
mozart Posted April 16, 2019 Author Share Posted April 16, 2019 (edited) Another small feature of the RATG Harvards was the addition of a grille on the front of the intake on the underside of the forward fuselage, as can be seen here in a wartime photograph and two that I took in Gweru in 2013: Once again I used a thinned piece of mesh from a Bf109 kit, then I cut an open rectangle from ten thou plastic card, sanded to make it more scale in appearance: Also worth noting in the flying Harvards is the tailwheel. The faired "oleo", if that what it is, is completely missed on the KH kit so will be scratchbuilt along these lines: Busy few days coming up so little modelling time sadly! Edited April 16, 2019 by mozart LSP_Kevin, Lothar, sandokan and 5 others 7 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 16, 2019 Share Posted April 16, 2019 Looks great Max! Pilot really looks the business. I was thinking of a camo bird when I read Rhodesia. I had just picked up one of Roden's "Rhodesian War "Cessna 337s. Looking forward to more progress! mozart 1 Link to comment Share on other sites More sharing options...
