256 -
Everything posted by Dan Paxton
1/32 HPH Models AC-47 'Spooky' Gunship
Dan Paxton replied to Crossofiron's topic in Works in Progress
Not sure if you have an AirCorpse library account. they have all kinds of info on DC-3/C-47 aircraft.....drawings, diagrams, blueprints.... It would be worth your time with this build. -
Oooooooohhhhh....... Following this for sure! -
1/32 MH-53E Sea Dragon - 3D printed / scratchbuilt
Dan Paxton replied to Starfighter's topic in Works in Progress
The Picture of the mechanic sitting on the door and the milky substance flowing down the fuselage.....that is an engine flush, the milky stuff is called gas-path and cleans the the turbine blades and guide vanes inside the engine. We did the same thing on our AH-1's. Gas-path, if not washed off, will stain CARC paint.....it makes a heavy faded color, very light base color if you will. Great pictures BTW, I can almost smell the sweet smell of hydraulic fluid, oil and JP-8........ -
Ooooooohhhhh big helicopter.....AKA the crowd pleaser........love it. I may have missed what type of printer you have..... -
1/32 Tamiya F4U-1a Corsair - Boyington's 17740
Dan Paxton replied to Thunnus's topic in Works in Progress
Magnificent build so far sir, thank you for taking us on this journey with you.....I ALWAYS learn from you masters..... -
F-104D Starfighter - 57-1315 - AFFTC Edwards AFB, 1960
Dan Paxton replied to Out2gtcha's topic in Works in Progress
I actually got to see a west German F-104 fly over while stationed in Germany during the late 80's. Sunofagun that was loud. maybe 500 feet up and 600(?) Knots....it was awesome! I love watching you build and enjoy learning new tricks along the way. Keep up the fascinating work!- 238 replies
- italiari
- starfighter
(and 1 more)
Tagged with:
CONTINUATION OF MY 1:20 SCALE SCRATCH BUILT B17G (RADIO ROOM)
Dan Paxton replied to fozzy's topic in Works in Progress
Fozzy.......sir...... impeccable as always. You're going to convince me to actually start my Mitchel project someday, aren't you?!?! -
I'm so glad to see you back in the workshop sir....fantastic stuff here as usual -
F7F-3 Tigercat - BuNo 80405 - VMF 312 MCAS - El Toro, CA 1946
I'm in awe. just found this gem!!! Cheers Dan -
Yep, I'm in awe yet again. What software are you using to design the major components? Excellent work Cheers, Dan
- 237 replies
- 3d printing
- marauder
(and 1 more)
Tagged with:
I'm teaching myself CAD using Fusion360 and love your renderings. are you drawing them yourself or is there some magical place that does those? Eventually I plan on scratch building a 1/20 scale aircraft......doing the AirCorps library blueprints and scaling them to 1/20......its a big project, but it keeps me occupied. how do you get the individual pictures of your drawings? You are an artisan Cheers, Dan
I use Fusion 360 for my CAD program. Its free, its simple to use, there are tons of how to videos. CAD is a learning curve. No 2 ways around that. But when you get a drawing saved and you need to make improvements on that particular part, its simple to go back into the CAD file and make your changes. For a 3D printer, I'm starting with the Snap-maker. Small print area and it doesn't do fine small details (-1 mm) well. but its a good introduction to the technology. I've used a 3D printed part as a blank for forming annealed aluminium parts.....with good effect in my tests. Cheers, Dan
Peter, I know this is a bit late, but for shaping annealed sheet stock around a complex curve, would a 3D negative print be used to form the part? Excellent work by the way Cheers, Dan
And she wasn't even Swedish!!! Cheers Dan
1/24 Scratchbuilt Grumman XP-50 Skyrocket
Dan Paxton replied to Jim Barry's topic in Works in Progress
Motivating to say the least. I'm using Fusion also to help design my build......lots of research before I start printing or building......oh and I need to learn how to anneal and shape aluminium. Watching with anticipation sir! Cheers, Dan -
Fantastic craftsmanship sir Cheers, Dan
Stunning Cheers, Dan
HK Model B-25J Backdated to a B-25C/D, Fingers Crossed
Dan Paxton replied to patricksparks's topic in Works in Progress
Love the work sir. I have an odd obsession with the 25.......doing tons of research on the J model as I'm looking to scratch one in......1/20scale Love your work here, hope mine will look remotely as great as your craftsmanship..... Cheers, Dan -
Fozzy, I take a break from the forums for a while and then this happens......It is sure great to see you building once again. I promise I will start building sometime soon on the Restoration project I have in mind. I keep getting great ideas and inspiration from you and all the other scratch building kings around here. Been spending most of my time working with a CAD program to give me scale drawings of what I need for my build.....not easy as I had to learn CAD first! But I think it will help in getting my project going once I start cutting and shaping. Learning how stuff works is the most difficult part...how does the nose gear attach to the bulkhead; what are the linkages that make it turn..... You sir are a genius in this realm of building something from nothing.....I bow in your presence Cheers Dan -
Heavy Mod - 1/18 21st Century Toys P-47D Razorback
Dan Paxton replied to JayW's topic in Works in Progress
UHHHHH uhhhhhh ooooohhhh ahhhh ooooohhh Cant speak, drooling here Dan- 435 replies
- P-47
- Thunderbolt
(and 1 more)
Tagged with:
No words.....just magnificent Dan
Sir! Looking awesome As a crew member on Helicopters, I can say you are doing a full on excellent job! my two cents about weathering.... Ruder pedals and the floor just aft of them would be worn down from constant use....the cockpit is often referred to as the office and the floor of the office was the hardest place to keep clean, often worn and chipped paint from flight boots constantly scuffing and moving on..... the cargo area.....the edges of the floor by the door would have worn paint from thousands of entries and exits. sometimes you would get spray paint and cover the exposed metal and sometimes that paint wasn't the right color or to new (hadn't faded) often multiple applications create a buildup of paint..... Again GREAT JOB Dan
Phenomenal.....
Speechless........
