BiggTim Posted May 17, 2017 Share Posted May 17, 2017 Dang, I want one of these kits! Link to comment Share on other sites More sharing options...
LSP_Ron Posted May 17, 2017 Author Share Posted May 17, 2017 Thanks all, Those are actually the intake pipes, I discolored them figuring the heat from the cylinders would burn any oil etc onto them but they would be cooler farther away from the heads. The exhaust on these didn't have manifolds, it just poured out the valve exit. It's an amazing piece of engineering for the time period. Joel_W and Shawn M 2 Link to comment Share on other sites More sharing options...
LSP_Mike Posted May 17, 2017 Share Posted May 17, 2017 Looking nice Ron. I too, have one of these, and yours is the first time I've seen one even started. Good stuff. Joel_W 1 Link to comment Share on other sites More sharing options...
Joel_W Posted May 17, 2017 Share Posted May 17, 2017 Looking nice Ron. I too, have one of these, and yours is the first time I've seen one even started. Good stuff. Mike, To have a model like this and not build it, makes little sense to someone like me,whose not a kit collector, but rather just a old time builder of plastic bits & pieces. Joel Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 17, 2017 Share Posted May 17, 2017 Engine looks outstanding, Ron, really nice. Link to comment Share on other sites More sharing options...
Snowbird3a Posted May 17, 2017 Share Posted May 17, 2017 Thanks all, Those are actually the intake pipes, I discolored them figuring the heat from the cylinders would burn any oil etc onto them but they would be cooler farther away from the heads. The exhaust on these didn't have manifolds, it just poured out the valve exit. It's an amazing piece of engineering for the time period. Ron, any thoughts of dis-colouring the cylinders as well ??? like this; https://c2.staticflickr.com/6/5542/11693052886_b27224b1d0_b.jpg I tried it 1/48 with some thinned blue sprayed on and the cylinder tops masked off. Cheers, Tony Link to comment Share on other sites More sharing options...
LSP_Mike Posted May 18, 2017 Share Posted May 18, 2017 Joel, I rotate 5-7 kits on/off my bench at any given time. Sorry Ron, still watching. Joel_W 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted May 19, 2017 Author Share Posted May 19, 2017 No Tony, everything is done now for paint on the engine and don't want to risk ruining it. I finished the guns, I think they would really scare their opponents! I also managed to clean up the main fuse tubulars and get them primed and painted and the floor board varnished. Time to start assembling the fuse now. Gazzas, 109, Starfighter and 5 others 8 Link to comment Share on other sites More sharing options...
Joel_W Posted May 19, 2017 Share Posted May 19, 2017 Ron, Those MGs are simply amazing. Can't wait to see the fuselage come together. Joel Link to comment Share on other sites More sharing options...
LSP_Ron Posted May 20, 2017 Author Share Posted May 20, 2017 Thanks Joel, I just noticed that the ammo feeds are not right, I have to scratch a front/top plate with an oval slot, they were not open troughs like these are. Should be an easy fix LSP_K2 1 Link to comment Share on other sites More sharing options...
Wolf Buddee Posted May 20, 2017 Share Posted May 20, 2017 Lookin' good Ron! The parts are obviously easy to see so no working with a visor or magnifying lamp eh? I'm surprised you didn't go with a natural metal tubular framing with heat discolouration at the weld points. A little bit o' clear blue and red over some burnt metal. Would o' looked real cool. What did you paint the fuselage framework with? I believe the instructions say the fuselage frame parts are ABS plastic. Did you find yourself some wire spoked wheels? Cheers, Wolf Link to comment Share on other sites More sharing options...
Gazzas Posted May 20, 2017 Share Posted May 20, 2017 Great work Ron. Link to comment Share on other sites More sharing options...
LSP_Ron Posted May 20, 2017 Author Share Posted May 20, 2017 Thanks all, I find the size of this a bit awkward to be honest. Tricks with washes etc in 1/32 don't work that well in 1/8th. That's a good idea Wolf but the general conciseness is that the fuse tubulars were a green grey not NM. That's also consistent with WnW's Fokker D.VII So I went with a Tamiya lacquer primer followed with MM RAF Interior green thinned with lacquer thinner. That should bite into the ABS and stick. No wheels yet but I have a lot of time to find or make. Ron Link to comment Share on other sites More sharing options...
Wolf Buddee Posted May 20, 2017 Share Posted May 20, 2017 I was just thinking about the tubular frame in NMF for visual interest. If I recall correctly, I believe the heel plates on the cockpit floor were edged with wood strips. I don't know if that's a detail you're already aware of. You know, the last time you picked up a model, the Tamiya Mossie, I couldn't help but start mine as well. I hope I stay focused on my Camel build and leave the Dr.1 kit alone, LOL! Wouldn't it be great if WNWs chose to do it in 1/32nd? Cheers, Wolf Link to comment Share on other sites More sharing options...
LSP_Ron Posted May 20, 2017 Author Share Posted May 20, 2017 And we both haven't finished the Mossie! Wow Yes the heel plates need some wood grain edges as do several other plastic bits. They are not glued, I just popped them on the floor after spraying AS-12 for the pic. There are many fixes required for this kit. Like missing leading edge ply on the wings, missing ply turtle deck behind the cockpit, missing lower front fuse sheet metal, missing sheet metal on the forward cockpit..... I will attempt them all but....I'm not going to let this stall if I can't overcome how to address these issues. Link to comment Share on other sites More sharing options...
