monthebiff Posted May 2, 2015 Posted May 2, 2015 (edited) After spending the last 18 months building a couple of Spitfire's I thought it was time for a change of direction so for my next WIP I am going with this Starting with the cockpit I have made a start on adding all the non pre painted brass from the Eduard set which is quite extensive with most of it being pretty useful. Thanks for looking and your comments are always very welcome. Regards. Andy Edited October 7, 2015 by monthebiff jgrease, 109, tomv87 and 2 others 5
wazza21 Posted May 2, 2015 Posted May 2, 2015 Looking great so far Andy. I have this one in the stash so I will be watching closely for when I start on wingy things again after my floaty things addiction wears off... Uncarina 1
LSP_Kevin Posted May 2, 2015 Posted May 2, 2015 Nice project, Andy. Looking forward to following your progress. Kev
sluggo Posted May 5, 2015 Posted May 5, 2015 Nice work. Just acquired this kit recently. I'll be keeping an eye on this thread.
moldmkr78 Posted May 5, 2015 Posted May 5, 2015 Been eyeing this one at my LHS for awhile now. I made need to pick it up. It's great to see the AM stuff for this kit as well.
monthebiff Posted May 6, 2015 Author Posted May 6, 2015 This kit has a few shape/size issue's namely regarding the prop/spinner, engine cowling and wheel spat's and so I decided to purchase the very nice correction kit from Brian L Fawcett models and Patterns and have spent this afternoon taking a few comparison shots for you guys to show how badly out the Trumpeter parts are: First off are the prop blades which on the Trumpeter kit are far to short and stubby as seen on the right of the picture. And the correct size/ shape spinner compared to the under size Trumpeter part on the right. Next up are the correct shape wheel spats with once again the incorrect shape Trumpeter part on the right And finally the engine cowl and as you can see the there is quite a big difference once again I definitely recommend this update set, the quality of the casting is second to noe and the corrected shape will make a huge difference to the look of the finished bird. Regards. Andy Uncarina, EmperorKai, Zero77 and 1 other 4
Out2gtcha Posted May 6, 2015 Posted May 6, 2015 Nice! Link to where you purchased the set? It looks like great set to have
Out2gtcha Posted May 6, 2015 Posted May 6, 2015 *FOUND IT* Looks really nice actually............ http://www.fawcettmodelsandpatterns.co.uk/1-32-junkers-ju-87-b2-r2-correction-set
monthebiff Posted May 6, 2015 Author Posted May 6, 2015 Beat me\Out2gtcha and yes its really nice quality........recommended. Regards. Andy
monthebiff Posted May 10, 2015 Author Posted May 10, 2015 Spent a bit of time today deciding which pilots seat to use either the very thick and overscale kit part or the Eduard etch part which is maybe a little to thin. decided on the etch part in the end and this is what I have ended up with, a lick of paint and some HGW harness's and it should look pretty good. regards. Andy
DougN Posted May 11, 2015 Posted May 11, 2015 (edited) Just FYI, the Brian Fawcett spinner is not quite the correct shape/size either (too bulbous). Here is a comparison (from a different build) that illustrates this: The Spinner comparisons: 1.Trumpeter, 2. Brian Fawcett Correction, 3. Henri Dähne I've thought about getting the BF correction set for my upcoming build as the rest looks pretty good, but have a couple other options in mind I'll try when the time comes first to see if I can correct it myself. Doug Edited May 11, 2015 by DougN Zero77 1
monthebiff Posted May 19, 2015 Author Posted May 19, 2015 Not had to much time on this one lately but now have the cockpit assembly finished and ready for painting, I decided to not add to much extra wiring with just the obvious stuff around the radio added for interest. Hopefully get some paint on this weekend, comments/ criticism always welcome. Regards. Andy jgrease, Mal_Belford and 109 3
LSP_Kevin Posted May 19, 2015 Posted May 19, 2015 Nice cockpit work Andy! I don't generally enjoy working with PE, so I'm especially impressed with how neatly you've handled all that metalwork. Kev
