shark64 Posted July 5, 2013 Share Posted July 5, 2013 This is truly amazing. I really love this. Oliver Link to comment Share on other sites More sharing options...
Ripaman Posted July 5, 2013 Share Posted July 5, 2013 Very nice Peter, can I ask where did you get your drawing? Regards Richard Link to comment Share on other sites More sharing options...
Martinnfb Posted July 5, 2013 Share Posted July 5, 2013 Peter, I am running out of superlatives. However this is a symphony of perfection, post, by post I have been amazed by your skill set and daring and precise execution of your work. Hats down. Cheers Martin Link to comment Share on other sites More sharing options...
airscale Posted July 6, 2013 Author Share Posted July 6, 2013 Thanks chaps - great to get encouragement Very nice Peter, can I ask where did you get your drawing?RegardsRichard Richard - I had the local printer (prontaprint) blow up some plans - reputedly the most accurate of the Sea Fury, from an October 1983 edition of 'Scale Models' - cost about £10, I just gave them the scale wingspan in mm and they got it bang on.. The hardest part was finding the original 30 year old plan itself and the magazine (ebay is your friend...) TTFNPeter Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted July 6, 2013 Share Posted July 6, 2013 The work on this thread is so good it hurts. Sincerely, Mark Link to comment Share on other sites More sharing options...
airscale Posted July 16, 2013 Author Share Posted July 16, 2013 evening all.. ..just a baby update as just back from India and only got a little done.. ...I skinned the other side of the elevator in brass and tried really hard to get as fine a trailling edge as possible - what do you think? ..I guess I won't really know until I prime it - speaking of which does anyone know how to prime brass like this - is there some sort of etch primer or something as I noticed mr surfacer doesn't really like sticking to it? TTFN Peter Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 16, 2013 Share Posted July 16, 2013 ..I guess I won't really know until I prime it - speaking of which does anyone know how to prime brass like this - is there some sort of etch primer or something as I noticed mr surfacer doesn't really like sticking to it? Gunze makes a metal primer that, oddly enough, they've decided to call Mr Metal Primer. I've been using it, but the jury's still out on its utility for me. It's clear, and dries clear, so you can't really tell if it's staying on or not! And I've noticed that acrylic paint can still be encouraged off the metal part after using it, so it's no panacea. But on balance I reckon it's probably still more effective than Mr Surfacer. I believe Tamiya makes a similar product. Kev Link to comment Share on other sites More sharing options...
KOTR Posted July 16, 2013 Share Posted July 16, 2013 I usually give my PE parts a short bath in a mild acid before priming them. There's also a metal primer by Tamiya, but I haven't used that yet... Link to comment Share on other sites More sharing options...
airscale Posted July 26, 2013 Author Share Posted July 26, 2013 evening all, got a little bit done today - first time at the bench for a few weeks (sigh...) ..started looking at the wing radiator intake - the kit is wrong here as it has the bottom of the wing flat, with a very square snub nosed leading edge. You can see on the real wing the intake that it protrudes below the wing and has a flap area at the rear - also the leading edge has an aerofoil section... ..and on the kit.... nothing... ..i made a couple of brass templates of the right shape so when I sand it all to shape the brass should preserve the cross-section. Also added some card to get the flat wide edges that can be seen on the real one.. ...fixed them into place... ..added some chunks of plastic to avoid it all being filler... ..taped up to mask green stuff getting everywhere and got busy spreading it about.. ...took the masking off while the putty was still soft and have the basic shapes to work with... ..I get to leave this to go off for a while as I am off to Hong Kong & Manila again on business on Sunday, so this should all be rock hard and workable when I get back. Thank goodness I have Mrs airscale to look after the store ... TTFN Peter Landrotten Highlander and Derek B 2 Link to comment Share on other sites More sharing options...
Guest Posted July 26, 2013 Share Posted July 26, 2013 Thank goodness, another update finally ! As always, amazing work Peter............harv Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 26, 2013 Share Posted July 26, 2013 Excellent problem-solving Peter! You're ability to identify a problem and conceive its solution is amazing. Talk about making the others jealous! Kev Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 26, 2013 Share Posted July 26, 2013 Just can't get enough Keep 'em coming :popcorn: Link to comment Share on other sites More sharing options...
airscale Posted August 7, 2013 Author Share Posted August 7, 2013 evening chaps.. been a while but time to get going again... ...before I went to the far east, I had roughed out the wing radiator fairing that is wrong and mainly missing in the kit from green stuff - this had gone off so started to shape it with a sanding stick.. ..soon had near enough the sort of shape I was after... ...set about the other side... ..the shapes and fairings in this area are quite complex - Steve offered to take some pics of the Sea Fury in his care a while back and got some great shots that really helped - I am sure he won't mind me sharing to show what I mean.. ..and after some primer I could see what I had to work with - pretty poor show actually, a hole and a bubble to take care of, but on the whole it turned out ok... ..until next time my friends.. TTFN Peter Landrotten Highlander and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 10, 2013 Share Posted August 10, 2013 Peter....lovin every update my friend! Stunning workmanship indeed Cheers Anthony Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 10, 2013 Share Posted August 10, 2013 Peter....lovin every update my friend! Stunning workmanship indeed Cheers Anthony Indeed! Kev Link to comment Share on other sites More sharing options...
