brahman104 Posted February 13, 2015 Share Posted February 13, 2015 I can't believe you just went and replaced all those lovely linkages with even more lovely metal ones! I must say they are absolutely outstanding and look every bit the part. So I'm going to ask the question again.... How did you simulate the rod ends on the linkages? Squashing again? Brilliant Mark, absolutely brilliant! Craig dodgem37 1 Link to comment Share on other sites More sharing options...
Guest Posted February 13, 2015 Share Posted February 13, 2015 GOOD GRIEF !! ...........Harv Link to comment Share on other sites More sharing options...
Mal_Belford Posted February 13, 2015 Share Posted February 13, 2015 Uep...There is a genius in a mad man......it looks damn good when i look at all this ...loking forward to see paint. /Mal dodgem37 1 Link to comment Share on other sites More sharing options...
JRutman Posted February 13, 2015 Share Posted February 13, 2015 I am reminded of Noel Redding on "Axis Bold as Love" stammering out right before "You Got Me Floatin'"......".uhh..... uhh .....I...... I...don't believe it!" Que Jimi J dodgem37 1 Link to comment Share on other sites More sharing options...
Wolf Buddee Posted February 14, 2015 Share Posted February 14, 2015 Wow Mark! I think you're very quickly getting to the point where you'd better lay some paint down or you're not going to be able to reach everything, even with the ol' airbrush. The paintwork is what will really bring this beast to life too. Just crazy Bro! Martinfb, his family, and I went to the Boeing Museum in Seattle this weekend and when we spotted a Mustang your build became the topic of discussion. Martin got so excited he broke in to a jig! Martin had never tried Mustang before, apparently it had a very metallic taste! Now to get this thread back on track I managed to get a couple of pics you might be interested in. The first is a lifting ring at the back of the gear reduction housing. I'm not sure if it's worth adding but I never knew about this detail. The other is a pic of the supercharger solenoid. You can see that it's mounted on the supercharger housing below the pivot point for the magneto timing advance lever. Hopefully these will be of use to you. Keep up the fantastic work Mark! Cheers, Wolf KiwiZac, sandokan, Mal_Belford and 2 others 5 Link to comment Share on other sites More sharing options...
Martinnfb Posted February 15, 2015 Share Posted February 15, 2015 (edited) Exciting times indeed, however when Wolf began removing that poor 50cal. , I suddenly realized that this place needs a better security. Edited February 15, 2015 by Martinnfb Link to comment Share on other sites More sharing options...
322SqnNL Posted February 16, 2015 Share Posted February 16, 2015 Stunning work. Having just squeezed every last possible ounce of detail into a 1/72 Spitfire cockpit I can only imagine how this must be that much more nervewrecking to get everything right. dodgem37 1 Link to comment Share on other sites More sharing options...
Ironwing Posted February 16, 2015 Share Posted February 16, 2015 Mark Late to the party, but Ive just gone through your entire thread. This is masterful execution and attention to detail. Wonderfully done.... Best Geoff dodgem37 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 16, 2015 Author Share Posted February 16, 2015 Thank you, Jamme. Thank you, Marcus. Thank you, Brother Bear. Thank you, Loic. There are indeed a number of powerful builds going on now. It's hard for me to keep track of them all even when 'Following' them. Thank you, Richard. Your builds look pretty danged good! I especially like that soldered aluminium piping at the Oil Reservoir on your Mustang. Thank you, Craig. Yes, I squeezed them really, really hard in a pair of pliers. These are the smallest Silver -Nickel rods by Albion Alloy. I believe they are .003 diameter. They are harder than aluminum (the softest) or brass (medium hardness). Good grief is right, Harv. I'm even saying that to myself, Charlie Brown! Thank you, Mal. But I don't know for which one, madman or genius! Right ON!, Jerry! Thank you, Wolf. Would it be wrong of me to say I'm not going to paint it? Just kidding. I do one thing at a time. When I finish scratch-building I'll hopefully solve the painting problems. I will lose track of what I need to do in this phase if I start to think out of it. Aside from tidying things up I'm finished with the engine. I don't know if it's complete. I just know I'm finished with it. It will be good to move over to the Oil Reservoir area and Firewall. Got 'em and got 'em in. That lifting ring just barely. 1.5mm inside diameter .015 solder. Whoo Boy! Thank you, Wolf. 'I suddenly realized that this place needs a better security' Hide you wallet, here comes Wolf! Thank you, 322SqnNL. Actually, this phase hasn't been nerve-wracking at all. Except for the Distribution Lines everything has gone smoothly. It certainly hasn't felt like 'work'. I can't imagine working in 1/72nd scale. It's so small. I sure would like for you to post your Spit. Thank you for stopping by and commenting, Geoff. Means a lot. Finishing the linkage rebuild. Filtered Air Door and Ram Air Gate link. Forgot the Hot Air Door Control. Will get on that. Other side of the Filtered Air Door and Ram Air Gate link. Upper: Propeller Governor Control System. Lower: Top lower is to Filtered Air Door; Lower lower is to Ram Air Gate link. Propeller Governor Control System sunny side. Pencil notations. The right link is supposed to be toward the bottom and the left toward the top. I made it this condition so I would not have to find the angle for the left side to fit over/around/thru/whatever! the Intercooler pump. .015 diameter solder lifting ring with returns squished flat on base with hex nuts on flats. Solenoid with electrical to Switch Box on Firewall. Supercharger Intercooler coolant line to lower firewall. Probably could be a bolt lower, but I'm going with this. Break Time! But not for long, I hope. Thank you for following along. Sincerely, Mark red baron, Sparzanza, Girlscanplay2 and 5 others 8 Link to comment Share on other sites More sharing options...
Mal_Belford Posted February 16, 2015 Share Posted February 16, 2015 Mark......Seriously...this is madnes..are you on the run from a locked security instution hospital or something and refuse to take your medication...... GEEEZ this looks fantastic in all this frenezy in detailing...i love it. /Mal dodgem37 1 Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2015 Share Posted February 16, 2015 EXCELLENT !!...........Harv Link to comment Share on other sites More sharing options...
JRutman Posted February 17, 2015 Share Posted February 17, 2015 keeps getting awesomer and I don't know if that is actually a word. Nice to see Geoff is back from where ever the heck he's been. Maybe he can join back in the P-51 fun now that I started on one as well. J dodgem37 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted February 17, 2015 Share Posted February 17, 2015 Mark, to be honest I gave up on my P-51 build, especially because of the engine section.I had also hard time to decide what to hide and what to leave exposed. At the end I did glue the cowling dead on solid. Your build is simply amazing, it is a source of motivation and inspiration that I need so badly nowadays.Thank You for that Sir.Martin Link to comment Share on other sites More sharing options...
dodgem37 Posted February 17, 2015 Author Share Posted February 17, 2015 Thank you, Mal. If it weren't fun it would never be done. Thank you, Harv. Thank you, Jer. There can never be too many Mustang builds. You have to post yours. Thank you, Martin. I must confess. (Uh Oh) I too gave up on this build. I used the excuse that the Group Build was over. Part of the reason I was looking to stop is that I already have the Dragon Mustang in my display case (and 2 Bf 109's). Building this kit would mean I would have another Mustang. And it just seemed silly to me that of all the aircraft types I want to build I've got models of only 2 aircraft types in my display case. So I dropped the build for awhile to purge myself of the thought, which was holding me back, and moved on from it. So, early on, I too thought about closing the engine compartment as the thought of detailing the engine as I had detailed the other assemblies was weighed down. Now it's not. Now, I am unencumbered by the thought process. Thank you for sharing with me that what I'm doing is a source. That you think that what I do can be of some help is very meaningful to me. Thank you, Martin. From me, and from all of us. Sincerely, Mark Mal_Belford 1 Link to comment Share on other sites More sharing options...
322SqnNL Posted February 17, 2015 Share Posted February 17, 2015 I'll see about posting a few in my 1:32 Revell Mk22/24 topic. It's a Mk.XIVc that will be getting a sweet D-Day striped 322 (Dutch) squadron livery. Won't be doing too much weathering as 322 got their XIV's brand new from the factory right before the event took place. dodgem37, on 16 Feb 2015 - 11:55 PM, said: Thank you, 322SqnNL. Actually, this phase hasn't been nerve-wracking at all. Except for the Distribution Lines everything has gone smoothly. It certainly hasn't felt like 'work'. I can't imagine working in 1/72nd scale. It's so small. I sure would like for you to post your Spit. Break Time! But not for long, I hope. Thank you for following along. Sincerely, Mark dodgem37 1 Link to comment Share on other sites More sharing options...
