stusbke Posted May 27, 2006 Share Posted May 27, 2006 Hi guys well I have a few other projects going these days and one of them is this one. Like I promessed to Boness here she is Im using the 1/32 revell F-4F boxing and the tweak list I found here, I got to work. Some of you guys will know this build from the ARC Gb a few months back since this was the reason to start this kit. I never get to finisch a kit before the Gb ending date Starting with the seats wich are great OOB but they could use some extra detail. So I started working on the added detail to the sides and replacing the seat belts with styrene and adding that all up you end up with these Ive put the OOb seat next to it so you see the difference And yes I was this mad twice last one And as Boness I to replaced the cockpit with a scratch attempt. emphasis on attempt With the seats in I also added some detail to the wheel wells, next one im building I'm replacing them entirely The main gears also got some detail Well thats all for now I hope to have some more now in te near future ooh and before you ask I didnt have a punch and die set at the time I did the side consels and such, I might end up rebuilding the whole thing again. Time will tell Any suggestions are welcome here since this is my first real full scratch cockpit here Greetz STB Frederick Jacobs Link to comment Share on other sites More sharing options...
Klaus H Posted May 27, 2006 Share Posted May 27, 2006 absolutely fantastic level of detail! i just love these seats. i thought that i am in love with the su 27 and mig 29 seats we were alowed to watch on this forum, but i think i get devorced and ask your seats to marry me. i understand you use plastik for the cables on the gear. is it just stretched sprue? do you use hot water to bend it? a very interestig project which has to be watched for shure. cheers klaus ... stunned.... Link to comment Share on other sites More sharing options...
Haggis Posted May 27, 2006 Share Posted May 27, 2006 Wow, more great scratch building from LSPers. How did you manage to get the seat harness to drape so realistically? Link to comment Share on other sites More sharing options...
JCote Posted May 28, 2006 Share Posted May 28, 2006 That is some very fine, crisp scratch-building. Can't wait to see more. Cheers, Jean Link to comment Share on other sites More sharing options...
stusbke Posted May 28, 2006 Author Share Posted May 28, 2006 Thanx guys appreciate it Klaus H; about my gears, I did not use streched sprue for my gears but the thinnest styrene rod on the market, it works like a charm, its only been a few months sice i discovered the use of telephone wire as detailing gears and stuff, So as of now im kinda sticking to that one. Its very flexible IF you use long pieces (10 cm or 3.49 in) at a time this way its way easier to bend it in to shape, no water needed its just so flexible its amazing, I can even bend 90 degree corners with it only you gotta watch out not to rush it or it will break. Also gluing it is a tricky thing as the tamiya glue tends to solve the evergreen and make the bend corner verry fragile. Any way heres another picture of the gear Haggis; about the seats, well basicly the same as with the gears if you keep your evergreen strips long enough they bend like nothing I ever seen and its easier to work with. I first glued them on to the seat and then just took the four ends and made a knot with them around the headrest, wich I saw on a picture somewhere, it looks cool and its different from Stock seats so mine are surely unique . Also as you can see in the pictures they are reversing sides and coming down behind the oppesite seatbelt, this also makes glueing them easier. I cut them under the headrest and then I added some buckels on them as you can see in the third cockpit picture with the seats in. it was a tempting job but I was verry pleased with how they turned out. I learned a lot on these seats knowing that an aftermarket seats isnt always needed to have a great seat. I also tried this on my F-18 but to be honest this trick doenst work well on that type of seat I guess the harness of it isnt suitable for it I think. Well thats all for now Hoping for some more in progress soon Greetz STB Frederick Jacobs Link to comment Share on other sites More sharing options...
LSP_Matt Posted May 28, 2006 Share Posted May 28, 2006 Again. Wow... thanks for the tips on the phone cable and evergreen. I suppose they'd take paint better as well. Lovely work...can't wait to see it with paint on. Cheers Matty Link to comment Share on other sites More sharing options...
stusbke Posted June 3, 2006 Author Share Posted June 3, 2006 Sa 3/06/2006 I got round to sit at my bench again for longer then 15 minutes and I decided to try something out wich i can use for future builds as well I got working on the exhaust and I made the flaps, well the masters anyway so i can remake them in alu sheet later on. any way the exhaust OOB lacks the detail that is all around in the exhaust of the phantom so I decided to add it myself rather then buying a resin set. I first started off sanding the existing raised details off. Then I added pieces of styrene rod and placed plates over them then I cut a lot of triangles and put those on too. then came on the plates and the triangles to hold them when doen with that job it looks like this Ive completed one so far so here's a picture next to the OOB one on the airframe it looks like this I also temporarely installed the flaps so you get the idea on how I wanna pose them Last one thats all for now i hope to finisch these up soon so I can start on the exhaust pipes greetz STB Frederick Jacobs Link to comment Share on other sites More sharing options...
Klaus H Posted June 3, 2006 Share Posted June 3, 2006 very very well done! its true that you dont need to buy resin sets if you dont want to. all those resin parts have been mastered from someone and so it should be possible to get the same results with styrene anytime. and the best of it is.... you are much more proud of it once it is finished and it is pure modelling joy. its called modelling, not assembling anyway. looking forward to read from you cheers klaus Link to comment Share on other sites More sharing options...
Ironwing Posted June 3, 2006 Share Posted June 3, 2006 Superb workmanship... Link to comment Share on other sites More sharing options...
alaninaustria Posted June 3, 2006 Share Posted June 3, 2006 This is some beautiful work..... I am really impressed! Keep up the great work! WOW! Cheers Alan Link to comment Share on other sites More sharing options...
Gene Posted June 3, 2006 Share Posted June 3, 2006 Stunning work Frederick! Excellent distillation of key elements of a FS aircraft into scale, Just Beautiful! Link to comment Share on other sites More sharing options...
stusbke Posted June 3, 2006 Author Share Posted June 3, 2006 Thanx guys you make me blush. I feel like I improved myself but still im far from the level then some of the regular builders here. But he at least im enjoying it very step of the way, and indeed klaus I will be proud of myslef when i can say all added detail is scratch greetz STB Frederick Jacobs Link to comment Share on other sites More sharing options...
Stef (#6) Posted June 3, 2006 Share Posted June 3, 2006 Hello there, Outstanding job; really interesting especially the work on the seat and exhausts .... Please keep on posting ! Cheers Stef (#6) Link to comment Share on other sites More sharing options...
Jens Posted June 4, 2006 Share Posted June 4, 2006 great work! Link to comment Share on other sites More sharing options...
PietvWdV Posted June 4, 2006 Share Posted June 4, 2006 I am loving this Fred. I am the same as you when it comes to AM stuff, but you have got some good stuff there mate!!! Thanx for bringing us this build, and welcome to LSP from me if I havent said hello already! I love the can things you did.(what are they called? Exhausts,burners?). Excellent. I will be stealing your tricks with great pleasure! Link to comment Share on other sites More sharing options...
