Marcin_Matejko Posted January 18, 2025 Author Posted January 18, 2025 23 minutes ago, scvrobeson said: Is that paint or foil going over the rivets on the tail? No, some of the rivets are decals attached, while those on the aluminum foil are extruded from the bottom. scvrobeson 1
Marcin_Matejko Posted January 29, 2025 Author Posted January 29, 2025 (edited) A small update: Edited January 29, 2025 by Marcin_Matejko patricksparks, Landrotten Highlander, Javlin1 and 11 others 14
Marcin_Matejko Posted January 31, 2025 Author Posted January 31, 2025 (edited) Sheet by sheet and slowly towards the goal 🙂 Edited February 1, 2025 by Marcin_Matejko scvrobeson, Mal_Belford, LSP_Kevin and 10 others 12 1
Hans Posted January 31, 2025 Posted January 31, 2025 (edited) You are a real artist, Marcin! A sculptor of aircraft. Edited January 31, 2025 by Hans Marcin_Matejko 1
scvrobeson Posted February 1, 2025 Posted February 1, 2025 Amazing! How did you mold the foil for the corrugations across the surface? Matt Marcin_Matejko 1
Marcin_Matejko Posted February 15, 2025 Author Posted February 15, 2025 Thank you 🙂 Quote How did you mold the foil for the corrugations across the surface? I hand-emboss individual panels on a specially made matrix. It took me many hours to make the entire Wilbault cover to scale. There are almost two hundred different panels that had to be made and fitted to the model. In fact, I made many more, not all of them worked out and ended up on the model. Although all the panels are similar, each one is different. It was terribly tedious and boring work, luckily I have it behind me now. to be continued😉 Madmax, galgot, LSP_Kevin and 15 others 15 3
Madmax Posted February 15, 2025 Posted February 15, 2025 Now that's dedication... Brilliant work Marcin! Marcin_Matejko 1
scvrobeson Posted February 15, 2025 Posted February 15, 2025 Amazing patience and craftsmanship to produce each individual panel Matt Marcin_Matejko 1
SwissFighters Posted February 16, 2025 Posted February 16, 2025 Utterly inspiring! Thank you for sharing Tony Marcin_Matejko 1
Mal_Belford Posted February 16, 2025 Posted February 16, 2025 WoW.....How the hell could i miss this... there are alot of cool stuff happening in this thread.....wow. ill go back to my lego bricks after this. Marcin_Matejko 1
Uncarina Posted February 17, 2025 Posted February 17, 2025 Brilliant! I really admire your dedication. Cheers, Tom Marcin_Matejko 1
Marcin_Matejko Posted February 20, 2025 Author Posted February 20, 2025 (edited) Thank you 😀 A small update because I managed to do a little something😉 This time there are small details, which means that the end of construction is getting closer to be continued😉 Edited February 20, 2025 by Marcin_Matejko SwissFighters, Mal_Belford, LSP_Kevin and 10 others 13
s00ntir Posted February 23, 2025 Posted February 23, 2025 Uzi..jesteś kosmitą... Taki jeden z dawnych zlotów w beretce 7ŁDP 😉 shadowmare and Marcin_Matejko 2
