I have the other boxing - the ICM kit combined with all the Special Hobby detail parts makes for a pretty impressive package.
Look forward to seeing this come together Stefan!
Iain
Iain
Yes, and the best part is that this boxing are CHEAPER then the original, plain ICM!
I paied about €10 ($9) LESS for this Maxed-out kit then the bare plastic ICM!
This box is fantastic value!
Stefan :beer:
Edited by Phantom2
  • 2 weeks later...
Hi All!
In this boxing we find the quite new ICM kit from Special Hobby and as this is the “Hi-Tech” edition there´s a LOT of extra goodies in the box!
Best of all, this boxing is cheaper then the original, plain, ICM kit!
I paid about €10 less for this kit compared to the ICM kit!
Fantastic value in this box!
Here´s what we find in the quite large box.
One large, box-siezed frame with the well-moulded fuselage halves (already removed) and some smaller parts (seats and cockpit parts).
IMG_1041
IMG_1049
This is not a small chopper, fuselage parts are 30cm (1´) without the tail part!
IMG_1042
”Real” positive rivets!
IMG_1045
One large frame with lots of smaller parts….
IMG_1046
One large frame with rotor blades, tail parts and a smattering of smaller parts and hatches.
IMG_1048
Two smaller frames, loaded with small parts and weapons…
IMG_1047
The glass parts are among the best I have ever seen in a kit!
Crystal clear and absolutely no distortion, scratches or any other imperfections!
IMG_1050
IMG_1051 (2)
IMG_1051
Two large sheets with pre-cut masks (Eduard?) and a small acetate sheet.
IMG_1054
Two etched frets, one is pre-painted  with instrument panels and seatbelts (Eduard)….
IMG_1055
One large decal sheet with no less than four interesting options to build.
IMG_1056
I will build this chopper as a blue “Navy” machine from US Navy Test Pilot School, Jacksonville, 1974.
IMG_3462
The Instruction booklet follows SH new format and is quite clear and easy to follow.
I don´t like that SH uses Gunze colours, but at least they give you the real name on the paint, so it´s easy enough to translate to your preferred brand.
In the bottom of the large box we find two smaller boxes, one with all the 3D printed parts and one with the resin parts.
IMG_1040
I´ll present the contents of the boxes as the build progresses.
Wow, this is a very complete box indeed and there´s no need for any AM
Stefan  :beer:
Edited by Phantom2
22 hours ago, Alex said:
That is a VERY complete kit!
I’ll say. They give you both tails, so you can build either an early variant with the rotor on the port side, or a later one with the rotor on the starboard side.
...and you also get two types of chin turrets (single and double barrels), two types of skids (one "skinny" set and one "beefed up" set, two different tailfins.
Can be more, but that´s what I can see now..
I have started glueing parts together, update will be coming soon!
Stefan :beer:
  • 1 month later...
Hi All!
As this is a ”Hi-Tech” kit Special Hobby have given lots of extra detail parts and they come in these small boxes.
IMG_1040
In the little blister is an 3x3cm (approx. 2,5 x 2.2in.) square of 3D-printed parts, and it´s packed full of small detail parts!
You must study the parts (and the attachments) and be very careful when you start removing them as the parts are extremely brittle and breaks very easily.
Don´t ask how I know…  :unsure:
The parts themselves are very well detailed and well done, but they are very brittle, so handle with care!
IMG_1053
In the Larger, yellow box we find lots of resin parts, just as well made and detailed.
IMG_3460
When all parts are cleaned up and removed from their plugs, You have lots of small parts on the bench.
IMG_3461
My choice for this build is the chopper from US Navy Test Pilot School, Nas Jacksonville, 1974.
Yes, this will be a late Navy chopper in the dark blue scheme with a white rotor head (mast/sail?) and the tail rotor on the right (starboard) side.
This one;
IMG_3462
I have another Cobra-kit, the original from ICM, and that will be an early Vietnam version.
From this Special Hobby boxing you can build 2 early or 2 late versions (tail rotor to port or starboard, single or double barrel gun, different skids...), so you have to decide before you start building.
The first thing to do is choosing and then gluing the correct tail piece to the corresponding fuselage half.
IMG_3467
I have glued each tail halve to the  side halves and before the glue sets, I taped the fuselage halves together and let this dry a couple of days.
IMG_3468
More to come soon!
Stefan
Edited by Phantom2
  • 2 months later...
Hi all!
Assembling the components of the engine compartment….
IMG_3469
Parts 36 and 37 have only a very small surface to hold them in place, this will never be enough!
I glued some 0,5mm plasticard as backing to give the parts some support on the inside.
IMG_3615
 A lousy picture from the front…
IMG_3617
The cannons will be glued at the end of the build.
The winglets are assembled and the pylons are in place.
IMG_3618
During the assembly I found that some parts are incorrectly marked in the instructions!
IMG_3622
My machine is a late version, so I must use the riveted (reinforced?) stabs.
I have the original, "early version"  kit from ICM so I could figure out which parts to use on the later ship I´m building.
More to come soon!
Stefan   :beer:
