Zero77 Posted December 20, 2014 Posted December 20, 2014 (edited) Hi, This is the last build i've finished. It is the Special Hobby A5M2b, built OOB, with one of the 2 schemes from the box as well. It is a pretty good kit, with nice details, but not always easy to deal with. Indeed, there is a few traps and the instructions are not always clear. But with a bit of work you can get something nice. I've add a bit of details (especially wires) in the cockpit, and had to redo all the iternal structure with styrene strips because the parts from the kit were unusable with the resin parts (it did not fit at all). The dials on the instruments panel are from MDC. I've drill the back bulkhead to make it hollow, and drill some areas in the floor as well. For the engine, i've used the kit sparking wire, supplied as a PE part, but it look good. I've laid a few coats of Mr Surfacer with a brush on the wires to make them looking more tri-dimensional. I've replaced the pushrods with 0.45mm nickel silver rods from Albion Alloy, which have been blackened with the Uschi burnishing solution (and it works, even if it is not brass). The cowling struts are made with 0.33 nickel silver rods, and i had to flatten one end in order to glue them on a tiny bracket glued on the engine crankcase. It is very fragile, but no choice. As an early A5M based in China, i wanted to get this kind of golden color, and my own interpretation of it is that it is actually a tinted varnish (or a clear varnish that became yellow when weathered), certainly the same kind than the Ame-iro seen on the A6M's. The best way to get the same aspect was to get the same way. So i've started with a coat of alclad, and then a coat of custom made tinted varnish. The recipe is approximatively 70-80% satin clear, 5-7% clear yellow, 5-7% clear orange and 10-15% smoke, and you should get something that is clear brownish. Just before spraying the varnish, i've used some AK chipping product, to make a few scratches and chips on the wing roots and cockpit sides. Then i've used custom made masks for the Hinomaru, and painted the tail with the same red (a mix of gunze flat red, vine red and a bit of insigna red). And then it was the drama.... Some paint (varnish + alcad) came off with the masks..... Usually, this kind of issue is not a big deal to repair, only a few touch-ups and everything is ok. But in this case, i have this varnish and it is impossible to make an invisible touch up, as the varnish is clear and any touch up would build it up and make it stronger and stronger around the peeled off area. So after a few days of thinking, i decided to mask all around the damaged area, to sand it clean and to repaint those area from scratch. The repair is not invisible, but i can live with it ! The decals from the kit are very good, and especially thin. That can even become a problem as they have a tendency to fold on themselves, and they become very sticky on the surface pretty fast, and then it is very difficult to make them move. I think micro set on the model before placing the decals must be avoided, but micro sol on placed decals is ok, and the decals react well. Then the weathering was done with a wash of Flory model dark dirt to highlight the panel lines, and then some enamel AK washes, followed by a coat of satin varnish. The exhausts have been painted with shades of rust colors with a coat of AK chipping product to make a kind of rust crust. The WIP thread : http://forum.largescaleplanes.com/index.php?showtopic=52933 Here are a few pictures in natural light : Edited December 20, 2014 by Zero77 SinuheH, Hubert Boillot, EmperorKai and 4 others 7
Zero77 Posted December 20, 2014 Author Posted December 20, 2014 And others with artificial light : SinuheH, Uncarina, mywifehatesmodels and 2 others 5
Zero77 Posted December 20, 2014 Author Posted December 20, 2014 SinuheH, mywifehatesmodels, Uncarina and 1 other 4
Zero77 Posted December 20, 2014 Author Posted December 20, 2014 I hope that i have not sent to many pictures. I never know what is the good amount. Thanks for looking ! Hubert Boillot, Tnarg, mywifehatesmodels and 2 others 5
mywifehatesmodels Posted December 20, 2014 Posted December 20, 2014 YIPEEE! This is one of the best Claudes I've ever seen. No, I think it IS the best I've seen and is my favorite, for sure. The details are incredible and the WIP was a joy to follow. :bow: John
Tnarg Posted December 21, 2014 Posted December 21, 2014 Don't ever worry about "too many pictures". Your work is wonderful. Thanks, Tnarg
alain11 Posted December 21, 2014 Posted December 21, 2014 Hi I agree !! very nice exotic plane , very interesting weathering , clean job (windscreen fitting)......that's awesome !!!!!!!!!!! Alain
Guest Posted December 21, 2014 Posted December 21, 2014 On 12/20/2014 at 11:37 PM, mywifehatesmodels said: YIPEEE! This is one of the best Claudes I've ever seen. No, I think it IS the best I've seen and is my favorite, for sure. The details are incredible and the WIP was a joy to follow. :bow: John Took the words out of my mouth.......harv
LSP_Kevin Posted December 21, 2014 Posted December 21, 2014 Congrats on finishing your fantastic build Nicolas! Your build thread was a joy to follow, and the result you have produced is terrific! May I publish it on the website? Kev
dodgem37 Posted December 21, 2014 Posted December 21, 2014 Danged Good Show! Love those scratches, chips, and things! Sincerely, Mark
Zero77 Posted December 21, 2014 Author Posted December 21, 2014 Thanks guys ! Yes Kev, of course you can publish it !
Hubert Boillot Posted December 21, 2014 Posted December 21, 2014 Great result Nicolas ! Following your build of the Claude was a pleasure, and the outcome is fantastic ! Hubert
LSP_Kevin Posted December 23, 2014 Posted December 23, 2014 Here you go Nicolas! http://www.largescaleplanes.com/articles/article.php?aid=2223 Kev
