Zero77
LSP_Members-
4,545 -
Days Won
28
Calendar
Everything posted by Zero77
Lol, that's funny you ask... Some Aires sets fit nicely, others are aweful. The F-104 cockpit is certainly one of the worst fit ever. Mine took me almost as long to fit than to build the whole model. I talked about this in the WIP, iirc... However the casting and details are so beautiful that it's "almost" forgiven.
Amazing paint job ! I love the many little touch-ups, that's very realistic. Was it the Tamiya kit?
Bravo Revell Germany P-51D Canopy Replacement
Zero77 replied to modelingbob's topic in LSP Discussion
Bob, did you get only the canopy or also the windscreen? Did you mentioned the sprue letter in the form? -
Wow ! That's amazing ! Glad i have not glued the windscreen yet on mine ! Do they request any proof of purchase or something? I have two kits in the stash, bought at the same time. -
EZ Line is called the right name. It's actually very easy. Just make sure to untwist the EZ line before gluing it. You can just let it fall and thread it slightly through fine tweezers. With Prim elastic line a twist is even more noticeable, though it's also easier to untwist. With a bit of care you can get no twist at all.
Announcing our next Build Guide featuring the HpH 1/32 Fw 189!
Zero77 replied to LSP_Kevin's topic in KLP Publishing
Probably ! -
The build looks amazing. However, i'm very sorry to say that, but i'm not able to read anything more than a few lines of text and a few pictures on a screen. Even a very long review is often too much for me. I'm an old paper kind of guy. -
Indeed that resin is incredible ! Very nice original subject, cant wait to see it progressing !
I-16 type 24 - Cpt Tsokolayev - Ladoga lake 1942
Zero77 replied to Zero77's topic in Ready for Inspection
Thank you guys ! Here a some more pictures, now it's finished with the PAK-1 gunsight from North Star Models. It's a very nice resin + PE set, but it's so tiny and delicate that you have to hold your breath when you build it. (The piece of masking tape on the paint jar is 6mm width) And the cute little plane with outdoor light : -
Wow, that plumbing job is just impressive !
I have two sets of the Eduard/brassin exhausts. Perfect casting as usual, but they are VERY skinny. Definitely too skinny, i can even say anemic. I then drilled the kit exhaust, and they look nice, too, but lack the detail of the resin, and are also pretty skinny compared to what i see on the pictures. So yesterday i ordered two of these 3D printed exhaust. They look better in proportion.
Hello, I've just seen that Italeri released a new box of their F-104G/S with a new sprue, with an Orpheus reccon pod and 2 chaff dispensers.
10€ for 8 is really a bargain ! Very nice !
Very surprising, but the coat of paint is flawless ! No cheating allowed with this kind of finish !
I always received my parcels from Russia. Very nice stamps by the way ! (they put stamps even on boxes. a LOT of stamps !) -
And incredible detailing job !
Wow, the quality of that kit looks awesome !
Lost (stolen?) parcels always make me crazy... -
I've made an order (Ebay) on early march, various resin and a decal set (Begemot Yak-3, great set by the way !). Sent I got a working tracking and received the parcels (resin from Ukraine, decals from Russia) in about 3 weeks. But the Pak-1 gunsights were missing. So the Ebay North Star seller resent them but as a very small parcel there was no tracking either. After 5 weeks without any delivery, he offered me a refund. He told me it would be better to not make small order as them seem to usually get lost by UkrPoshta. North Star is very good quality resin parts. -
Thanks Martin ! Another difficulty in the build that i forgot to mention, is the exhausts. It's not very easy to position them correctly. The instruction are not very clear and if you want to make it with the engine cowling closed, you have to get them in the perfect position. The only solution is to dry fit the cowling panels with tape and move the exhaust tubes while they are curing until you get what you want. I broked them almost twice each. -
Yes, they are pretty good and lay down very nicely. I've sprayed a mist of satin varnish all over as they are glossy. -
Thanks ! Yes i should add a bit of weathering on the underside. However, the artificial light really eat it, and for example the tires are actually really dusty (Mig pigment russian earth) but on the close up picture it's barely visible. It also lacks a bit of soot at the gun mouth, especially in the nose. The build was very pleasant and straightforward. The cockpit is not very detailed from the box, but there is so few visible even with the doors open... The only little difficulty is the main part of the fuselage all around the cockpit as the upper part is separate, and the seam must be filled and sanded clean. You have to glue it very flush before. I said it was the ICM kit, but it was the Revell boxing (no difference). I also have another ICM type 24 kit in the stash and a type 28.
